Old 10-18-2008, 10:47 PM   #1
Goldsboro , North Carolina
Towing Question, need help asap, thanks!
Hi this is my first post here and I'm sure it won't be my last. Any input would be great, and the quicker the better. Within the next 24 hours I'm supposed to be picking up my first Airstream (it's a 25ft 1971 Tradewind), and my question is about the towing. It's about 3 and a half hours away and there aren't any mountains in between us, but I also am not going to be able to hook the brakes up to it. Is it safe to just rely on the breaks of the truck if I drive extra cautiously? Thanks! Sam
againstfifte is offline   Reply With Quote
Old 10-18-2008, 10:50 PM   #2
Absolutely not.
You cannot control what others may or may not do, that can cause you to loose control, faster than you can blink an eye.
Old 10-18-2008, 11:13 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
No! don't do it.
Hi, unless you are towing this trailer with a Kenworth or similar truck, the answer is no. Adding an extra 4,000 to 6,000 lbs to you vehicle's brake system is an accident waiting to happen.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 10-19-2008, 03:25 AM   #4
JDL
JDL's Avatar
2005 19' International CCD
T , Oregon
Bad idea.
You really should not do this.
The trailer may try to pass the tow vehicle.
JDL is offline   Reply With Quote
Old 10-19-2008, 05:07 AM   #5
Images: 59
Common sense aside, it's also illegal to tow a vehicle weighing more than 4000 lbs without trailer brakes.
In Virginia and South Carolina, the weight limit is 3000 lbs.
Ask your insurance agent.
Old 10-19-2008, 06:22 AM   #6
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Sam,
I think you get the idea from the previous posts!
Is there a mechanical problem with the trailer, or is it just that you don't have a controller in the TV? (forum speak for tow vehicle).
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 10-19-2008, 06:25 AM   #7
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Well, it happened to us.
We picked up the new '77 checked the brakes pulled all the wheels, tried it on some dirt left marks etc.
It was 225 miles to get it home, it started raining no brakes
The last 100 miles were a dangerous aventure.
The Durango my friend used to do me a favor towing it had to give 200 extra feet to stop.
It was stupid to continue, but he did.
Don't do it
'77 Sovereign Intl 31' CB
Old 10-19-2008, 06:30 AM   #8
Wayward's Avatar
Cary , North Carolina
WELCOME to the forum!
Yup - hook up the brakes.
It does not take long, especially if you have a truck or SUV. Most are prewired for the rear connector and controller so it is just a matter of getting the right adapters.
Test out the Tradewind's brakes with the manual feature on the controller to be sure they are actually working before you hit the highway.
...........Scott
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Old 10-19-2008, 07:54 AM   #9
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I would hook up the brakes if you can,,, I did tow my 28' 1968 ambassador home with out trailer brakes.. I keep it a 55-60 mph and had no problems stopping it.... It is just over 4000 lbs dry... Probably Illegal in Colorado.... My new Sequoia has the over sized brakes and did a good job...
BUT:::: I now have a brake controller and let me tell you,,,,, it makes all the difference in the world.. Not sure what your TV (tow vehicle) is Hook it up if you can, but if you can't just take it slow and leave a lot of distance between you and the guy in front of you....
I guess I'm willing to take some chances others here aren't, but it is a lot safer to have it hooked up.........
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-19-2008, 07:55 AM   #10
just jd.
5cats's Avatar
2007 20' Safari SE
San Diego , California
trailer brake laws, anyone?
Check out AAA's reference to trailer brake laws, by state.
According to this, North Carolina requires an independent brake system if gross weight exceeds 1000 pounds. That isn't much!
Interestingly, riding is permitted in the towed vehicle while in that state.
Cheers,
-jd.
2007 20' Safari SE/LS // 12063 //CA-5// ("ex") 2916
5cats is offline   Reply With Quote
Old 10-19-2008, 08:04 AM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome to the Forums. We're glad to have you with us.
We would like to see you and your new Airstream with us for a while. Towing your new Airstream without trailer brakes on the highway may prevent this from happening.
It is EXTREMELY dangerous to do what you are proposing. It is much less expensive to pay someone to deliver your new Airstream on a flatbed than to replace your Airstream and your tow vehicle. Not to mention the possibility of injury to yourself and/or others.
Brian
SuEllyn & Brian McCabe
Old 10-19-2008, 10:34 AM   #12
Phoenix , Arizona
Trailer Laws
Cheers,
-jd.
How accurate is this chart? It looks like it would be illegal
to tow a new Airstream in some states, brakes or not due to the width. Looks like 8ft limit in some states and new
Airstreams are 81/2 ft width.
DesertDog is offline   Reply With Quote
Old 10-19-2008, 10:48 AM   #13
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Someone pulls out in front of you and it's all toast.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-19-2008, 10:59 AM   #14
99Limited34's Avatar
1999 34' Limited
Darien , Wisconsin
Don't do it, you'd be an accident looking for a place to happen....
1999 Airstream 34' Limited (The Cottage)
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
99Limited34 is offline   Reply With Quote
airstream, brakes, safety
Hi, question about towing. coolbabe All Argosy Trailers 11 07-30-2008 12:57 AM
Question on Towing??? World Travel Tow Vehicles 44 01-02-2008 08:45 AM
Towing Question noises from hitch kdh0519 Hitches, Couplers & Balls 22 07-09-2007 09:58 PM
OH NO! ...Not another towing question blucloud Off Topic Forum 4 02-11-2006 05:29 AM
A towing question... sequoiacoast Hitches, Couplers & Balls 5 11-28-2005 05:00 PM
