Old 09-11-2010, 07:48 PM   #1
1978 Argosy 30
West Monroe , Louisiana
Towing Question
I need to know if a 2006 Jeep Commander V8 with a towing limit of 6500 lbs can pull an Argosy 30' with a dry weight of 4380 lbs and max of 6400 lbs? Will this be to close to the towing limits? I have pulled a lot of trailers of varying sizes and lengths while in the army but for the first time I have to look at the load limits and handling capabilities for myself.
Any input will be greatly appreciated.
bdl002 is offline   Reply With Quote
Old 09-11-2010, 07:57 PM   #2
_
welcome bd'
possible? yes
sensible? no
can you? yes
would i ? no
_______
now that u've joined us and learned how to post,
take a bit of time and look over the 1000s of questions about "rig combinations"
and the myriad of answers related to those combos.
then either try it or not.
OR post more details (travel frequency/distance/destination/rigging/financials) and so on...
my answers would still be as above but the extra info might help others reply.
cheers
2air'
Old 09-11-2010, 08:36 PM   #3
The answer to your question, somewhat depends on other things.
Such as, what is the rear end ratio?
Will you install a transmission oil cooler?
Both of those make a huge difference of what you can and cannot do, with any vehicle that will be considered for a tow vehicle.
Old 09-11-2010, 08:59 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Like 2airishhuman said "possible Yes" You would need a really good equalizing hitch and sway control and some exceptional brakes. It would take a lot to set it up but it is doable. Now would most of us here do it. NOPE. Iv'e seen a few older Grand Cherokees on their sides because the trail was to long, But they were SOB's not AS.
IF possible I would look into something a little bigger.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-13-2010, 08:47 AM   #5
1978 Argosy 30
Thanks for the help. This has really helped me make up mind on what to get for a TV.
Another towing question ipso_facto Our Community 34 08-28-2010 03:47 PM
Towing Question monkeypants Tow Vehicles 9 11-26-2009 05:57 AM
Question on Towing??? World Travel Tow Vehicles 44 01-02-2008 08:45 AM
Towing Question Dano57 Tow Vehicles 28 09-08-2007 09:47 PM
Another towing question Dbraw Tow Vehicles 18 07-11-2003 06:24 PM
