Old 07-31-2007, 09:29 PM   #1
Dano57's Avatar
1979 31' Excella 500
Edmond , Oklahoma
Towing Question
Been away a while and need some quick answers as I return to getting the AS up and running. I need a tow vehicle and a friend has a 2005 Silverado 4wd with a 5.3L Vortec engine, 4 speed auto and a 3.42 rear axle he wants to sell me. I will be towing a 1979 31 foot Excella with it, what is your opinions? I think that the Excella has a GVW of 8100 pounds and the specs say that the truck is rated for 8400 pounds. I think it is marginal but don't know if I should make a deal on it? It is loaded and I know he'll make me a good deal, so...?
Dan
Under Renovation,
As yet to be towed!
Dano57 is offline   Reply With Quote
Old 07-31-2007, 09:33 PM   #2
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
3/4 ton would be better.
4WD will burn more fuel and not be used very much.
klattu is offline   Reply With Quote
Old 07-31-2007, 09:36 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
8100 lbs seems pretty high. Are you sure of that figure? What is the dry weight of your trailer? My 1972 Sovereign is about 5,300 lbs, I can't see yours weighing that much more than that.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-31-2007, 09:50 PM   #4
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
My understanding is you should not exceed 80% of the tow vehicles rating. Here's the weight chart for various A/S trailers - looks like your OK.
http://www.dwmorrison.com/weights-1.pdf
Old 07-31-2007, 09:59 PM   #5
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Not big enough. The Gas? engine is too small for that load. Especially in the hills.
Michelle TAC MT-0
Sarah, Snowball
Old 07-31-2007, 10:02 PM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I agree that the 8100 seems high. My 1979 Safari has a dry weight of 3900 and a gross weight of 5800, 1900 higher. Using that for your Sovereign would add 1900 to the dry weight of 4800 to get 6700 not 8100. In 1979 the tow vehicle of choice was a full size car with a large V8.
Bill
Just my personal opinion
Old 07-31-2007, 10:05 PM   #7
bobkelly's Avatar
2003 22' International CCD
Whittier, California , Depoe Bay, Oregon
Since you are asking, the truck may be marginal for a 31 footer. Some important truck facts weren't posted initially. The year and model 1500, 2500, 2500D, wheelbase, length of bed, trailering package with heavy duty cooling, etc. The rear axle ratio is not ideal either. Can you hitch it up and give it a test drive?
2003 22ft CCD Int'l
2005 GMC Yukon Denali
WBCCI #2960
bobkelly is offline   Reply With Quote
Old 07-31-2007, 10:16 PM   #8
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, as is, this truck is too marginal; You would have to, at very minimum, change both differentials to 3:73 or 4:10 ratios.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 07-31-2007, 10:19 PM   #9
Dano57's Avatar
Edmond , Oklahoma
I'll check on the trailer weight to be sure, if I remember correctly the empty weight was in the mid 4000 pound range and the max weight was 8100. I'll check just to be sure. Yes, I forgot to put it in the original post it is a 1500 crew cab short bed. I think the wheel base is right at 143 inches according to what I have found on the Internet.
Under Renovation,
As yet to be towed!
Old 07-31-2007, 10:45 PM   #10
KeithC's Avatar
1994 34' Excella
1978 31' Sovereign
Mansfield , Georgia
I tried towing my 1968 24' Tradewind with a Ford F-150, 5.0 gas engine, tow package, auto transmission, and found it was way under powered for even moderate interstate highway grades.
On Interstate steep grades my speed dropped to 50 mph floorboarded, and I averaged less than 11 mpg during the trip.
I bit the bullet and bought a 2006 Ford 3/4 ton, 6.0 turbo diesel, tow package. Geeze Louise, what a difference.
KeithC is offline   Reply With Quote
Old 07-31-2007, 10:59 PM   #11
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
In the long run, you are much more likely to be happy with a 3/4 ton something.
Remember that an insufficient tow vehicle is the primary cause of a perfectly good Airstream becoming a very expensive piece of yard art.
SuEllyn & Brian McCabe
Old 07-31-2007, 11:46 PM   #12
USN/LAPD Retired
Safari-Rick's Avatar
North Las Vegas , United States
Moosetags is right.
Better to have more then you need, then need more then you have because you don't have enough!
And there is nothing more worse then having an engine that over heats as you go up a grade (hill).
R/
Safari-Rick
2007 Dodge Ram Quadcab 6.7L Diesel w/jakebrake
"Better to have more then you need, then need more then you have because you don't have enough!"
AIR #: 8129
Safari-Rick is offline   Reply With Quote
Old 08-01-2007, 12:27 AM   #13
1977 31' Sovereign
ORD , Nebraska
I must say I agree with the majority of posts here. The 5.3L with 3.42's should give fairly good gas mileage unloaded, but with your trailer not only will it return poor mileage but will do so at much slower than desired speeds. We pull our 31' with an '05 Duramax and love 65 mph getting 14+ mpg.
Erik
welld.geo is offline   Reply With Quote
Old 08-01-2007, 08:17 AM   #14
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
We had two 5.3l's. One w/ 3:73 one w/4:10. I would not be happy towing a 31' with either of these.
The 3:42 only makes it worse.
As already suggested, you DO want a 3/4 ton for this job...
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Towing Mirrors 53flyingcloud Towing, Tow Vehicles & Hitches 8 01-03-2003 05:28 PM
Towing Specs in trailer life 53flyingcloud Link Archive 0 11-16-2002 06:09 AM
towing with Roadmaster/ Fleetwood Cruiser On The Road... 1 09-26-2002 05:14 PM
Towing COArgosy78 1965 - 1969 Overlander 5 09-05-2002 11:18 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 09:15 PM
