Old 08-05-2004, 09:14 AM   #1
Craftsman
Guest
Posts: n/a
Question Towing Necessities for my 2001 Chevy
Well, I have a flight out of BWI on Monday to Ft. Lauderdale to pick up the 2001 4X4 2500 Suburban that I bought on ebay. I'll drive that back to Baltimore(900 miles) rest up andt hen drive to MI. to pick up the 31" 1976 Sovereign that I bought through a tip from Rog 0525. I orderd a pair of McKesh mirrors, a Prodidgy Brake Controller and I'll buy a new battery to take with me. Is there ANYTHING else that I should take with me ( besides tools)? Special electrical connectors etc.? This will be my first time pulling any trailer. Any advise is more than welcome? It's a 600 mile trip home.
Jack
Old 08-05-2004, 09:33 AM   #2
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I carry a cross lug wrench, emergency triangle warning markers, wheel chocks, an air pump, some hitch lube, fuses, a hitch pin. I also have my lynx leveler blocks which could be used to raise the tires in case of a flat. I do also carry a small bottle jack. Other things to think about, a spare tire and wheel, and sway control.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-05-2004, 09:47 AM   #3
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Jack, there was a thread here somewhere about tools to carry on long trips. I'll see if I can find it for you. For a vintage trailer such as the one you are picking up, I would travel heavy the first time out. Some Olympic rivets, pop rivet tool, and a drill with 5/32" bit would not be out of order, just in case a piece of belly skin decides to go south while you are on the highway.
I would also bring some spare grease for the new hitch (sometimes they are noisy as they work in), a national campground guide, and I'd join the "Blue List" that is maintained on this forum for emergency help.
Also bring your car charger for the cell phone and make sure you have a good nationwide calling plan ... My motto when traveling is that with a cell phone and a wallet full of Gold cards you can't go far wrong!
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 08-05-2004, 09:56 AM   #4
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
During your rest-up prior to picking up the trailer, have the Prodigy and the Suburban's wiring done back to the hitch and have it thoroughly tested. That will make troubleshooting any 12v lighting and/or brake issues with the trailer much easier when you get there as you won't have TWO new sets of wiring to troubleshoot.
You didn't mention your hitch setup, but I wouldn't tow it without a weight distributing hitch with sway control, even with the Sub 3/4 ton. You can expect about a 700lb tongue weight with your 31' trailer. Check the receiver hitch dead weight limits on the Sub. Most Class III receivers have a 10,000/1000 lb limit WITH weight distribution and only a 5000/500 lb limit without. Choose the weight distribution/sway system that fits you best; you've undoubtedly read the opinions expressed in all the threads here about them. Frankly, although I think some are better than others, they all work adequately.
Make sure that you have a recent bearing repack on the trailer, and that the tires are good enough to tow it home with. There's nothing worse than having to replace half the side of your trailer 'cause a blown tire tore it up on the way home.
Have a great time!
Roger
Old 08-05-2004, 10:04 AM   #5
87MH's Avatar
1978 31' Sovereign
Images: 292
Originally Posted by Craftsman
....Is there ANYTHING else that I should take with me....
Duct Tape..........lots of it.
Plan to stop often and early.....leave after the rush hour, and stop with plenty of light left. Pull in every rest area you can - do a walkaround, put your hand on each tire as you visually inspect them and feel each bearing assembly and wheel/drum contact area - anything over 20 degrees above ambient needs an inspection to determine why it is running a high temp.
Oh, don't forget the camera with lots of film/storage......
Post pics for the rest of us.
Luck
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 08-05-2004, 10:18 AM   #6
JohnG's Avatar
Bungie cords...............
If you find a broken awning arm on one of the small windows or the back you can sometimes just use the very small bungie cords to hold the awning in place so it dosen't get lost or break off.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-05-2004, 10:19 AM   #7
JohnG's Avatar
Oh Yea, I forgot. You can also wrap them arond the awnings to keep them in place in case the snap is broken. You might want to bring some rope too ......Never hurts to have all those odd things.
John G
Old 08-05-2004, 11:28 AM   #8
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Jack, if you want, I can provide overnight courtesy parking at my daughter's home so you can get an early start on your trip home. She is just a few miles froom the pick up location. That's where I keep my Caravel. You won't be able to fill the LP tanks until you get new OPD valves installed, but we can hook up the water and electric. This would give you a little time to get acquainted with your new coach before you hit the road.
If you want to give me a ring when you know when you're going to arrive, I'll meet you at the seller's home and lend a hand in the hitch up.
Bring some blankets if you're going to stay overnight.
Bon voyage.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 08-06-2004, 09:07 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Trip
Pick up a copy of "The Next Exit" which lists truck stops, gas stations, repair stations, dump stations, rest areas, restaurants, etc. It was invaluable to me on my trip from TN. to AZ. and back when I went out pick up my '77 31' Excella. A hammer and cross lug wrench sure came in handy when I blew a rear curbside tire. I had to beat an outrigger down in order to remove the tire and then limped 45 miles on 3 tires into Amarillo, TX. I did a little more work on it while Discount Tire mounted new Carlisle ST tires on all 4 rims.
Don't forget extra fluids for the Suburban just in case.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-06-2004, 09:34 PM   #10
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
This is very important. If you have a chance, before leaving to pick up your trailer, have the differential fluid changed, and synthetic gear lube installed in both differentials. The synthetic doesn't break down due to high temps like the standard stuff does. I have a friend with a Dodge Ram 1500, that lost his differential while towing his trailer. Also just today had a visitor from Wisconsin show up at my door with a blown rear end in his Chevy Express van, also from towing his travel trailer. The rear end got so hot it boiled the gear lube out.
A new transmission filter, oil change, and fresh coolant won't hurt, if the seller hasn't done this for you already. This is assuming the truck already has a trans cooler installed, if not, that would be mandatory.
After thinking for a few more minutes, a spare serpentine belt for the engine would be a good idea, too.
I will stop now, before I have you dragging an extra truck along...
Have a safe trip.
Old 08-06-2004, 09:47 PM   #11
Rog0525's Avatar
Images: 11
I keep a can of Fix-A-Flat in my Jimmy. I've never needed it for a trailer tire but it came in real handy one time for allowing me to get off a busy X-way to a safe tire changing area.
Rog
Old 08-06-2004, 11:10 PM   #12
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Not sure if this will help or not. Maybe some others can chime in.
Very often we hear about the windows shattering on trailers that have been sitting for a while without being moved on their maiden trip home.
It happened to the PO of my trailer and I inherited it with sheet metal taped over the wrap windows.
Mostly the fixed windows that don't open like the front wrap windows and the side oval windows.
I was thinking it may be a good idea to hit the gaskets on those with a heavy dose of silicone spray to loosen them up a little so they can take the vibration better before you move it the first time.
This is just an idea I have, so I don't know how valid it is.
What do you guys think?
-Tim
theVAP - Airstream Podcast
Old 08-07-2004, 06:38 AM   #13
Silvertwinky's Avatar
South Shore , Kentucky
**One More Tool**
There has been a lot of tools mentioned on this thread; one versatile tool I always try to keep handy is made of plastic. Yep, the ole credit card. When all else fails I find it a relief to know that you can always call for some help.
Visit our church on the web!
"A safe camper is a Happy Camper"
Bill & Donna
Air Forums Member # 2360
Silvertwinky is offline   Reply With Quote
Old 08-07-2004, 06:41 AM   #14
Well Preserved
1993 21' Sovereign
I don't think it would hurt anything, and it would probably be a good idea to open and close all the windows and doors that will do so.
Another idea I had after signing off was to make sure the TV antenna and roof air shroud are secure, you don't want to lose those items going down the road.
towing with a chevy 1500 leighmiller Tow Vehicles 11 05-09-2008 04:07 AM
2001 Chevy recall in 2005 Question sovereignrwe Off Topic Forum 1 04-18-2006 09:12 AM
Towing with a Z-71 Chevy? Paulk Tow Vehicles 7 06-20-2005 09:23 AM
Towing with Chevy 6.5 TD j54mark Tow Vehicles 6 08-11-2003 10:09 AM
Towing with a 2001 VW Eurovan MV.... crazylev Tow Vehicles 23 02-07-2003 10:35 PM
