Old 03-05-2006, 02:10 PM   #29
Grand Rapids , Michigan
Originally Posted by BigAl
William,
I have the McKesh mirrors and had the same vibration proplem.
I put some quick ties around the strap to make the strap "round" and that solved the noise for me.
Al
Big Al,
Not sure what you mean by this... thanks.
Double D is offline   Reply With Quote
Old 03-05-2006, 02:41 PM   #30
1994 30' Excella
Mississauga , Ontario
By installing quick ties on the strap it bunches up and isn't flat anymore. This prevents it from catching air and vibrating. Mine are installed on a full size van. The doors are tall so the strap is long and doesn't lie flat and tight to the door. Remember as a kid putting a blade of grass between your thumbs and blowing on it? Just like a reed in a wind instrument, it makes a lot of noise. Scrunch it up and you can't get that sound.
Al
Old 03-05-2006, 04:37 PM   #31
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
My vote for Schefenacker
Originally Posted by AgZep
I put a set of Schefenacker mirrors on my Silverado. I think they're absolutely fantastic: http://www.ttt-mirror.com
This is what I had installed on my Burb. Even when NOT towing I notice that I use the convex mirrors a lot. They really eliminate blind spots, and it's just a second's work to yank them in and out for towing. I never knew what I was missing without having convex mirrors.
Tin Lizzie
Old 03-08-2006, 09:34 PM   #32
Al
I must be a bit dense, but what is a quick tie, and how do you attach it to the strap? I'm picturing this taut strap and trying to skrunch it some type of tie-down thing.
Still in fog....
Thanks!
Old 03-09-2006, 07:14 AM   #33
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Still in fog....
Thanks!
I wonder if this is the same thing as a cable tie? I could see rolling the edge of the strap inside the other edge and applying the cable tie to make the strap a cylinder rather than flat.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Towing Experience app Tow Vehicles 9 04-19-2004 10:51 PM
Towing Mirrors 53flyingcloud Towing, Tow Vehicles & Hitches 8 01-03-2003 05:28 PM
Towing Regulations by State InsideOut Towing, Tow Vehicles & Hitches 2 09-16-2002 08:35 AM
Towing COArgosy78 1965 - 1969 Overlander 5 09-05-2002 11:18 AM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 09:15 PM
