Old 05-25-2016, 04:37 PM   #1
2010 27' FB Classic
N/A , Texas
Towing mirror turn signal not lighting
I need some suggestions.
I have a 2007 Chevy Classic truck with the large towing mirrors that have a turn signal arrow that lights up in the mirror when the turn signal is on.
My problem is that the lighted arrow indicator within the mirror won't light up on the drivers side, left turn signal only. My turn signals work all around and the indicators on the dash function properly except for the drivers side light in the mirror.
I'll be checking the fuses tonight, but it seems that if it was a fuse that the turn signal would not work on the dash or on the outside front and back turn signal lights on the vehicle on that side, and everything is working as usual except the the turn signal LED lights within the driver side mirror.
Have any of you had this problem?
Any suggestions as what else could be causing my mirror light not to work?
Old 12-03-2016, 05:38 PM   #2
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Any luck? This is usually best asked on a truck enthusiast forum.
Stuff like this never seems to be cheap if it isn't a fuse.
Wiring from door to body is a problem on my generation of Dodge truck. Window controls. Etc.
Some guys open the wiring bundle to re solder broken pieces. I figure that it's a matter of time, and that replacing that particular wiring harness is the right way to go.
Old 12-04-2016, 06:17 AM   #3
2012 19' International
Southeastern MI , Michigan
The mirror assembly is easy to change. Just remove the triangle trim piece on the inside of the door, then three (10mm?) nuts and the mirror comes off. New ones are not very expensive.
The arrow is a row of LEDs and, unless there is a connector loose inside the mirror you're probably better off changing the mirror. Replacements are cheap. The ones on my 05 quit working early on but since the rest of the lights worked I just left them until someone took out my mirror.
2018 International Serenity 27' FB
Goodyear Endurance tires
Hensley Arrow hitch
Tow Vehicle: Ford Superduty crew cab 6.2L V8
Countryboy59 is online now   Reply With Quote
Old 12-04-2016, 12:55 PM   #4
2010 27' FB Classic
N/A , Texas
The turn signal LED'S work now.
I read all I could and watched several U tubes that show the removal of the mirror. As I was getting ready to take the door apart and check the wiring and harnesses, I decided to try the turn signal one last time. Good thing, it now works. It's been working for about 5 months with out a hiccup. So far, so good.
These Chevy's heal themselves! Ha,ha
Old 12-04-2016, 01:18 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
How about posting the link to the You Tube I have other questions about the mirror.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Old 12-04-2016, 02:23 PM   #6
2010 27' FB Classic
N/A , Texas
Here's one, I'll send the other link on the next post. Same guy made the u tubes but each one shows something different.
Old 12-04-2016, 02:27 PM   #7
2010 27' FB Classic
N/A , Texas
HowieE,
Here's the other one.
Old 12-04-2016, 02:27 PM   #8
Cool. Let me know when your power windows quit working. I fixed mine in an hour with replacement motor assemblies for $30.
That truck had 330,000 miles on it last time I saw it.
Hensley Arrow hitch
Old 12-04-2016, 02:42 PM   #9
2010 27' FB Classic
N/A , Texas
Thanks Countryboy, I'll make sure I do that!
Mirror / Mirror what type of Mirror? Jeep GC dlkershaw Towing, Tow Vehicles & Hitches 9 12-10-2015 03:14 PM
turn signal light bulb replacement...bulb not turning ArgosyMinuet All Argosy Trailers 2 04-28-2013 09:52 AM
Back turn signal light bulb broke and can not get out ArgosyMinuet All Argosy Trailers 5 04-22-2013 04:36 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
Rear right side turn signal not working s4misfaction Argosy Motorhomes 4 05-27-2010 03:39 AM
