12-17-2012, 03:24 PM
#61
Common Sense
I tried to find the HD on the build thing, but couldn't. It's got to be a totally different truck because all the weights are heavier. Wonder if it can even be done then with existing 1/2 ton axles and suspension parts?
Regards,
Steve
12-17-2012, 04:00 PM
#62
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
my 3/4 ton Dodge would seem to meet all of your listed specs with room to spare. Mine is white, but there are other colors.
12-17-2012, 04:15 PM
#63
Common Sense
Thanks Bill, but I have a 3/4 ton already, and is one of the things I'm wanting to get away from. Any of the maufacturers 3/4 ton will certainly do the job, but I would like the drivability, comfort, and ride of a 1/2 ton.
Regards,
Steve
12-18-2012, 01:09 PM
#64
Common Sense
I went to town and looked at Ford F150's today, and they do have some great specs., however to get the maximum towing capacity and max GVWR, you must get the Supercrew with the 6.5 ft bed. Virtually the same length truck I have now. Their Supercab has suicide doors, so Ford is out of the running at this point.
I did, however, drive a truck with the Ecoboost engine. I was not impressed with the power, but it would be a good option for someone that wants to be able to tow a trailer, and also does a lot of unloaded driving (fuel mileage thing). The truck I drove was the King Ranch edition, top of the line, and the seats are still too short on the bottom.
So Rich, when are those new GM trucks going to be out?
Steve
Regards,
Steve
12-18-2012, 03:17 PM
#65
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Just a thought... If you stayed with a 3/4 and went with a ling bed it would smooth out the ride. My 1 ton dually long bed rides just about as smooth as the 1/2 ton 4x4 with the short bed. Just a thought.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
12-18-2012, 03:36 PM
#66
Common Sense
But darn Bruce, I'd have to build a new garage. My current truck fits in the garage with only 6" or so to spare. And the other thing is, I'd like a truck that is easier to get around town....you know, like being able to actually park in the grocery store parking lot, and not out on the street.
Regards,
Steve
12-18-2012, 03:39 PM
#67
2002 25' Safari
Dewey
Parking in the garage is important to me as well. My Tundra has 1" between the garage door and the rear bumper. I always make take the test drive to my house to make sure it fits before I buy a new truck.
Richard
12-18-2012, 04:15 PM
#68
Oswego
Steve
Specs in January. Trucks start rolling about June....maybe a little earlier.
-Rich-
12-18-2012, 04:36 PM
#69
2024 19' Caravel
Washougal
Hi Steve,
This thread has been wonderfully civil, so I'll give you what I have to show "it CAN be done with a half ton". I'm not advocating any brand over another, but trying to give you some data points for your research.
I have a 2004 Nissan Titan, and currently tow an SOB (28' Arctic Fox) that scales at 7000# when packed for two weeks, and with about 780# of tongue weight. When running the numbers on the Titan, I have 2000# of towing capacity in reserve, and depending on what's packed, plenty of payload capacity. The truck was only offered in Crew Cab configuration when I bought (I have one of the first ones, built in 11-11-03) and the box is the six-footer.
Everywhere from where I live is uphill or downhill, along with windy. I get about 10 MPG when I hold the speed to 55, and 8.5 MPG when I go 60. I have an older Reese twin-cam and have no sway or control issues. In a couple years we hope to have a 27FB behind this same truck, as I've quit driving it daily and now use it just for "truck stuff".
Hopefully that can give you some answers.
12-18-2012, 04:56 PM
#70
Common Sense
Thanks Steamguy. I've been running numbers and running numbers until I'm almost sick of it. Yes, it can be done with a 1/2 ton, but so far I've not found a 1/2 ton that I want that will do it. I trust you have read my desires in a previous post.
My numbers are a little different than yours. My trailer has a GVWR of 10,000 pounds, but I know it really doesn't weigh that much. I have a weight ticket from when I first lisenced it here at 7,280 lbs. Also, I know that with tongue weight, the way I want to equip the truck with a camper shell, and the things we routinely carry, we will have about 1700 pounds in the truck with the amount of the tongue weight that is carried by the truck.
So anyway, it boils down to needing about 8500 lbs towing capacity WITH 17-1800 lbs weight carrying capacity.
One thing that I was encouraged by today looking at the Ford F150s, they use the same tires on even the max tow and max weight capacity trucks, and the same rear spring pack. Believe it or not, they change things like a different oil pump in the engine, and a larger trans cooler for the heavier rated trucks.
Regards,
Steve
12-18-2012, 07:09 PM
#71
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
Steve
I was looking at the specs today for the 2013 1/2 ton GM truck. I was shocked to find out that it has rear drum brakes. That in itself would knock it out of contention for me.
I really like my Tundra. It is a great vehicle. It is comfortable, quiet, refined and powerful. It meets your criteria except for the payload and gas tank size. I think the weak link may be the rear axle. Everything else like the brakes, cooling, motor torque,rear end and tranny seems stout enough except for the rear axle. Maybe Toyota will fix this sometime by increasing the GVWR above 8,600 lbs, so it won't hurt their CAFE requirements.
Hopefully the redesign of the big three in the next year or so will give your what you are looking for, along with a lot of other Airstream owners.
Dan
12-18-2012, 07:43 PM
#72
Common Sense
Yes Dan, I too was surprised to see those drum brakes. Must be the last of the 1/2 ton trucks with drums.
I know the Toyotas are good vehicles, I have one, but not a truck. I have the FJ Cruiser, and I like it a lot. Too bad it won't tow the Airstream.
I have several friends in our unit that tow with Toyota Tundras, one an earlier 31', and another that tows a late model 31'. They seem to do alright, but I know they carry little to nothing in the trucks.
At this point, I believe I'm actually just tired from this exercise, and will put it aside for a while. Maybe tomorrow see if I can do something about the steering play in my truck. (one of the reasons I was looking at 1/2 tons....they have rack and pinion)
Regards,
Steve
12-18-2012, 08:39 PM
#73
Oswego
Actually, Guys, drum brakes have been historically better in "dirty" work truck environments. Especially up here in the north, where salt is used a lot. Rear brakes are exposed to the spray of the entire truck, whereas drums are covered and protected. Not as big of a deal down south. Also, drum/shoes have more contact friction area than disc.
This is one of "those" kind of arguments, but I have preferred drums in my fleet and commercial observations. It will be interesting to see what the new discs are like in the GM announcement the other day.
-Rich-
12-18-2012, 11:39 PM
#74
2009 27' FB International
Los Angeles
We love our Tundra, but don't think I would like to tow anything larger than our International 27FB with it.
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
12-19-2012, 04:43 AM
#75
2005 28' Safari
saline
, Michigan
And it's the front brakes that do most of the work. I don't remember ever changing a set of rears.
12-19-2012, 06:25 AM
#76
Common Sense
Just my opinion, but it's not about how long they last....it's about how well they work.
Every other 1/2 ton truck has disc rear brakes, and GM 3/4 ton trucks have disc rear brakes, as do most all the cars they make, at least all that I know of, but I'm not really into keeping up with car engineering these days. Why don't all those vehicles have the corrosion problems that Rich speaks of?
Regards,
Steve
12-19-2012, 07:17 AM
#77
Oswego
Good question Steve. Cars, don't see the "Grit" that commercial trucks see in the mines, construction sites....etc. Other mfrs have seen issues with discs. It is a challenge to shield them properly and keep the airflow necessary for cool operation at speed and towing, etc. It seems to have been worked out on the HDs in their latest iteration. Remember the HD is a 2011 platform. The 1500s are a 2007 platform. The GMT800, (which came out in 1999) were disc, and there were contamination and corrosion issues. You only get a chance to change the major systems when the platform changes, as in 2014 with the 1500s. They will be discs. There are still a lot of folks....engineers included....who maintain that, due to the operating characteristics of the shoe/drum interface and surface area, that drums are better for low speed, high load work......What do big trucks have? Semi trailers, etc? Why?
Kosm1o, with the advent of ABS (especially the last several years of advanced systems), much more of the work is now proportioned to the rear. ABS allows for a TRUE load sensitive proportioning system. You would still expect, in most circumstances, to get longer life out of the rears, but not like it was years ago.
-Rich-
12-19-2012, 08:07 AM
#78
Common Sense
My current 3/4 ton is an '08, and it has disc rear brakes.
Regards,
Steve
12-19-2012, 08:17 AM
#79
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Short wheel base 3/4 ton Dodge 4/4 with the small back seat and 4 doors that open the right way. Disc brakes all the way around. Rides great on smooth roads. A real tooth rattler on rough roads. We live where the roads are smooth. I also have a older 150 that I used before the Dodge to tow. It worked but not all that well. About the same length as the Dodge. I parked next to a friends max cab Tundra at the last WBCCI luncheon and chatted with him a while after. Same load range E tires as my Dodge for payload and pulling stability. Same size as the 3/4 ton, length, width and height. Cost about 15000 more than I paid for the Dodge. He loves pulling his 28 footer with it. I am always looking at this kind of thread because I might need/want to replace it. Right now I would look at Toyta and Dodge. We live in the suburbs and my wife drives the Dodge as her everyday ride. I tried to get her into a car or something smaller, but she loves driving it and will not give it up. It takes a bit more space to park because of the width and the turning radius limit of the 4/4. When you shop at Walmart and malls that is not a problem. The heated leather seats and the full adjustability of the pedals, seats, wheel, etc. make it easy for her to adjust to her short frame. We looked at long bed Fords before we bought the Dodge. Like driving a small freight train. I would not do it, but there are multiple leaf spring sets that will somewhat smooth out the rear end of 3/4 ton trucks when running empty and still carry the load. About 2 grand, I think.
12-19-2012, 09:18 AM
#80
Common Sense
Yes, if I was forced to trade for a 1/2 ton at this time, it could only be a Ram or a Toyota, with the tilt going toward the Ram for mostly personal reasons. They are the only ones with a medium sized cab with normal opening doors.
Regards,
Steve
