Old 06-12-2013, 06:32 AM   #183
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Our 2013 25FB International Serenity door label shows a GVW of 7,300 pounds with two axles rated 3,600 pounds each or 7,200 pounds in total which is less than the GVW of the trailer. The factory scaled weight coming off the production line was 5,665 pounds. Thus the payload at the factory was 1,665 pounds.
The 2013 International Parts list shows a 3,800 pound axle is used on the 25', 27' and 28' models (heaviest GVW of 7,600 pounds on 27' and 28') plus both Eddie Bauer models (27 model has GVW of 7,800 pounds) while two 3,000 pound rated axles are used on the two 23' models with GVW of 6,000 pounds. The 30' models got two 4,500 pound axles with a GVW of 8,800 pounds. The US model 19' gets a single 4,300 pound axle with a GVW of 4,500 pounds.
The factory literature said the tongue weight is 833 pounds, the Shureline scale reports 1,175 pounds ready to camp and the axles were carrying 5,880 pounds per the CAT scales. That should imply the trailer was at 7,055 pounds loaded leaving 245 pounds of payload available.
During that trip, we added three 6 gallon containers of fresh water to the tank (about 150 pounds) without dumping the black or gray water tanks.
I looked at the 2013 Classic parts book for axle ratings and found that all three models use the same two 5,000 pound rated axles. The 27FB has a GVW of 9,000 pounds while the two 31' models have a GVW of 10,000 pounds.
I think the door labels may not reflect the actual capacity of the installed axles. But the part numbers tell the truth.
One needs to do thorough research on the trailer weights before selecting a new TV and ensure the discovered information works properly with an existing TV.
Old 06-16-2013, 12:25 AM   #184
Luigi123's Avatar
2018 30' International
2014 30' Flying Cloud
Los alamos , New Mexico
Have the new F150 with the 6.2 3.75 gears should be able to handle my 27FB on order???
Luigi123 is offline   Reply With Quote
Old 06-16-2013, 03:53 AM   #185
Rivet Idiot
AirHeadsRus's Avatar
1999 34' Excella
On The Lake , Georgia
It will be fine. Very good truck tv if set up properly.
Annette ...... Canopener Party Planner
AirHeadsRus is offline   Reply With Quote
Old 06-16-2013, 07:01 AM   #186
richinny's Avatar
2011 34' Classic
what model?
what will it weigh with all the options included?
do you carry much in the truck bed?
will you have a topper added?
what is the truck rated to tow as configured?
Ricky
Old 06-16-2013, 07:23 AM   #187
Plainfield , New Hampshire
Don't risk your life. There are very few vehicles that will properly pull and STOP a 30 ft Classic which requires 10000#. There is a good reason that vehicles are rated with different GVWRs which are clearly posted on the driver side door post or in the glove compartment. Also the trailer itself has a GVWR. It has to do with weight of tow vehicle, size and power of engine, transmission gears, axle gears, whether vehicle comes with trailering package, STOPPING power of brakes, tongue weight of trailer, weight of trailer, and of course whether you load the tow vehicle properly and whether you load the trailer properly e.g. over axles correctly, keep tires inflated correctly, etc. etc. Don't try to outsmart all of this.
MikeAir is offline   Reply With Quote
Old 06-17-2013, 05:38 AM   #188
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I don't feel my life is at risk at all...the OP said "propensity"...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-18-2013, 07:03 AM   #189
switz's Avatar
2014 31' Classic
Images: 8
A common oversight with the smaller TVs is that smaller TVs lacks the braking capacity to stop the fully loaded rig going down the mountain road if the trailer brakes malfunction. Remember, the trailer has electric brakes (even the Airstream hydraulic disk brakes are electrically actuated), not surge brakes like a boat trailer.
Old 06-18-2013, 07:35 AM   #190
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I am leaning towards 3/4 ton in my case...considering 28 or 30' models...but after running some numbers, we have 2 kids growing family, and I have brothers and a sister that at times will want to camp...and I can already see that the payload will risk many times going over or overtly going over....
How much do generators weigh?
PharmGeek is offline   Reply With Quote
Old 06-18-2013, 07:38 AM   #191
SteveH's Avatar
Common Sense , Texas
Depends on the size, but 60 pounds is a good estimate, and then there's the fuel.
Regards,
Steve
Old 06-18-2013, 07:56 AM   #192
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Depends on what you buy of course. I have 1 3000is and 2 2000i. The 3000 is my favorite because it lives on my boat and has a wireless remote start. If I had to move it every time I used the boat I am not so sure I would be so fond of it. The 2000's live in Rubbermaid ActionPackers always pickled and read to deploy for camping or Hurricane emergency use. Oil and cross connect cables plus surge protectors, back feed cables and extensions cords stay in the action packers with the gensets. If you do get a generator be sure to add an hour meter if not so equipped.
Honda 3000is 134 lbs. Dry
Honda 2000i 46.3 lbs. Dry
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 06-26-2013, 08:13 PM   #193
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Ram 1500 #18,350 max towing capacity? Now that is towing large!
I saw this this evening.
Name:	Screen Shot 2013-06-26 at 9.04.58 PM.png
Sounds a bit far fetched.
A mistake?
Lance
Top is offline   Reply With Quote
Old 06-26-2013, 09:24 PM   #194
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Attachment 189386
A mistake?
Hi, I just searched that sight and the Dodge Ram 1500 will have that tow rating with the Cab and Chassis 3500 option.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-27-2013, 06:45 AM   #195
dznf0g's Avatar
Oswego , Illinois
I think they may have meant GCWR...consistent with the Cab Chassis pages. The math would just about add up to GCWR.
-Rich-
Old 06-28-2013, 04:26 AM   #196
Luigi123's Avatar
Thanks everyone-awesome community to see the "help and advice" out there. I eventually found the answer I was looking for as my Airstream of choice is either the 25fb or 27fb both arriving at the dealer in September. My TV will be sorted out by then. Considered an "experienced model" AS; however, like the new wrap around windows on the newer models and hope to purchase one time prior to retirement to avoid "2 feet " wants later on.
1/2 ton
