Old 02-06-2013, 01:27 PM   #141
CarCollector's Avatar
1964 26' Overlander
Gold Bar , Washington
We will be using a 67 1/2 ton Burb and a 63 1/2 lifted Chevy 4x4 truck to pull our 64 Overlander from time to time. Both of them could easily do that job.
What we use right now for towing is a 1985 diesel 3/4 ton Burb with lift and 4x4. It's rated to only do 8,000 lb or so and we've already put OVER 15,000 lb behind it and it pulled that without a problem. Lots of vehicles can pull more than they are rated for. It's not the issue of pulling said weight, it's the issue of stopping said weight. If you have trailer brakes, tranny cooler, and update your rig's brakes you could probably pull way more than it's rated for.
My boyfriend built my rig to pull as much or more than a 1 ton rig can pull from the factory. Next on it's list is a new motor with turbo and new rear and front end gears, then we are talking 1 1/2 ton rating. (insert evil laugh here)
1964 Overlander pulled by 1985 diesel Suburban 3/4 ton 4x4 w/ 4" lift & 35" tires.
Also: 2008 Sebring convertible; Camaros: 83 Z28, 78 Z28, 78 (7 yr olds); Trucks: 67 Suburban, 63 Chevy 1/2 ton (10 yr olds), 60 GMC 305 v6
CarCollector is offline   Reply With Quote
Old 03-13-2013, 04:35 PM   #142
SteveH's Avatar
Common Sense , Texas
Just an update here on this Ram truck....replaced the front shocks and the steering damper today with Bilstein's. One of the harder shock replacement jobs I've done, but man-oh-man, what an improvement. Sooooo much better. Those stock shocks are junk.
Regards,
Steve
Old 03-14-2013, 11:34 AM   #143
crispyboy's Avatar
1994 30' Excella
alexandria , Kentucky
SteveH,
How many miles were on the stock shocks? Your signature says you have a 2012 model.
How did the ride change?
I have 40k on my truck and I was thinking the current stock shocks have always been mediocre at best.
Hensley with adjustable stinger
WBCCI # 3072
crispyboy is offline   Reply With Quote
Old 03-14-2013, 11:45 AM   #144
SteveH's Avatar
Originally Posted by crispyboy View Post
SteveH,
I just bought the truck a few months ago, but it was a "Demo" model, or something like that, and has about 22K miles.
I don't think the stock shocks had gone bad so to speak, but were inferior and not up to the job of stabilizing such a heavy truck with so much unsprung weight. Again, my opinion.
The only thing that I noticed about the ride was increased stability, steering stability, and response. I did not change the rear shocks as it has been my experience really stout shocks on the rear of the vehicle just increases ride harshness with little improvement in stability.
Regards,
Steve
Old 03-14-2013, 12:39 PM   #145
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Steve,
Did you go with the yellow/blue or the 5100 series that silver/black? I put the yellow/blue on my '08 at around 50k miles but didn't change the steering damper and probably should have. I didn't see any increase in harshness from the new rear shocks.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 03-14-2013, 12:57 PM   #146
SteveH's Avatar
Rick, The Bilsteins I found available for are truck yellow/blue front shocks, but the steering damper is 5100 series silver/black.
The best price I found with free shipping was from Summitracing.com .
Regards,
Steve
Old 03-14-2013, 04:23 PM   #147
crisen's Avatar
Fairbanks , Alaska
Also check out Geno Garage for stuff for your ram/cummins Dodge Cummins Turbo Diesel Parts and Accessories - Geno's Garage
I see they only have the damper in the 5100 also.
Rick
Old 03-15-2013, 08:14 AM   #148
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The front shocks were replaced when the front airbags were installed as the mounting location was moved outside of the usual shock location inside the coil spring. The rear shocks were left stock.
There is not much one can do to make an over four ton empty weight four wheel drive truck handle like a sports car that weighs less than half that much.
Old 03-15-2013, 02:55 PM   #149
Jared129's Avatar
1976 31' Sovereign
2014 28' Flying Cloud
1992 34' Excella
. , Maine
Reading this thread makes me feel much better about purchasing my new truck Now if only all the snow will melt so I can have the AS ready before our first (ever) rally in April!
Jared and Heather
WBCCI # 4998
AIR # 24449
Jared129 is offline   Reply With Quote
Old 03-15-2013, 03:03 PM   #150
SteveH's Avatar
Switz, I'm not claiming sports car like handling, but I am claiming a MAJOR improvement. An improvement to the point of doing as well as my last truck, an '08 GMC 3/4 4X4 with independent front suspension.
Basically, I was unsatisfied, and now I'm happy.
Regards,
Steve
Old 03-17-2013, 10:09 AM   #151
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
The BILSTEIN is pretty well the strongest consensus choice on low cost replacement shocks for DODGE. One can go to the aftermarket for custom-valved KING or FOX shock absorbers (from CARLI or THUREN FABRICATION), but the cost rises to several hundred dollars apiece. I'd say that once one has the rig completely kitted out that this final step may be worthwhile (based on comments from other truck owners who'd narrowed down their truck spec & use to their ideal).
GENOS GARAGE is the default aftermarket supplier for all years of DODGE diesel trucks. Plenty of others out there, but this would be the best place to start any research.
Old 03-22-2013, 01:28 PM   #152
SteveH's Avatar
Just got thru installing this: BD-Power Performance Dodge Steering Stabilizer
And some urethane sway bar bushings.
It's even better.
Regards,
Steve
Old 03-26-2013, 12:45 PM   #153
crispyboy's Avatar
1994 30' Excella
I went with the one from Hellbent steel more as a preventative maintenance measure for the steering box. I thought it was a worthwhile upgrade to tighten up the steering.
Dodge Ram Steering Stabilizer - Hell Bent Steel
WBCCI # 3072
Old 03-26-2013, 01:45 PM   #154
SteveH's Avatar
Looks like the exact same product.
Regards,
Steve
1/2 ton
