Old 03-21-2006, 08:44 PM   #1
Profile:  Currently Looking...
eugene , Oregon
Thumbs up Towing Info Please, on our Honda
We are considering getting a 16ft bambi.
Our tow vehicle would be a 2005 awd honda pilot.
We have a tow package, and it includes a transmition cooler.
Question is...will we be powered enought to tow the little bambi...or not?
PIRATES is offline   Reply With Quote
Old 03-21-2006, 08:56 PM   #2
cosmotini's Avatar
Profile:  2008 27' International CCD FB
Highland , Illinois
Images: 83
Airstream Registry
Hi Pirates!
Welcome to the forum. There are some excellent posts here about how to figure what you can tow. Road King Moe did an excellent writeup on it some time ago and I will try to find a link for you.
In the meantime, I'm sure other members will offer good advice.
Dennis
cosmotini is offline   Reply With Quote
Old 03-21-2006, 09:06 PM   #3
cosmotini's Avatar
Highland , Illinois
Images: 83
Airstream Registry
I couldn't find the post I was looking for but here is a link to a discussion on another forum that may help you get started.
If I find the one I was thinking of, I'll post a link to it.
Dennis
Old 03-21-2006, 09:09 PM   #4
2airishuman's Avatar
Profile:
hi pirates and welcome to airsteamin'
cosmo has given you a great link to read and learn....towing is about numbers....
trailer life lists the v6 pilot at 3500lbs max towing....
you will need to check the honda info to see if this figure is lowered....
with people/gear in the honda....yes that's correct, most tow ratings go down...
as stuff is added to the towing vehicle....
the honda ratings are further confused by having a different rating when towing a boat.......4500lbs......
why i have no clue.......
an empty bambi is 28-2900lbs......loaded is 3500lbs....
so these figures are really close....too close for me....
also you can find for the honda....a gcwr....gross combined weight rating.....
basically that is the max number for pilot and whatever is inside/ontop or behind it.... find this number, then add up the loaded airstream and the loaded pilot....most safety nuts suggest 80% of this figure as an upper limit...
find the trailer you love......then find the horses to pull it....
cheers
2air'
Old 03-21-2006, 10:10 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
My POV
Aaaaargh PIRATES! Welcome to the Forums!!
I happen to believe tow capacity and GCWR are the wrong place to start.
Look at this thread to see how to look at a tow vehicle's suitability. I give full credit to the Road King Moe approach that Cosmotini mentions -- that's where I figured out the full details about three years ago. A careful reading of an honest tow vehicle (TV) owner's manual should just about say the same thing.
Many small SUV websites (and Honda is no exception) leave off critical data. The Honda Pilot specs listed online gives a basic curb weight (or empty vehicle weight without options). Neither a load capacity for the Pilot nor the Pilot's GVWR is listed (ignore the trailer weight until you determine just how much dead weight you can safely load onto the Pilot's axles!).
I would recommend you look at your owner's manual with particular attention to the towing section. The detailed weight specifications will be listed somewhere. Here's the formula: Curb Weight + Load Capacity = GVWR. You want to make sure the proposed Bambi hitch weight, people you intend to carry and other load on board do not exceed the Pilot's load capacity. And here's a catch -- if the tow package is an option not available on the base LX or EX model, you must also subtract the hitch receiver (100-150#) under the back bumper from the load capacity. Airstream lists the empty 16' Bambi hitch weight at 480#; with LP in the tanks, WD gear mounted on the tongue, and any personal gear onboard I don't think you could expect anything less than 600# -- and most likely more. (16' Bambi's GVWR is 4500# and tongue weight will be in the 10-15% range -- 10% is rather optimistic...)
Some frameless monocoque SUV manuals (like the Touareg) specifically advise against using weight distribution gear. It would not be advisable to tow a 16' Bambi without WD gear -- I hope you've been lurking in the Forums because this was discussed just a couple weeks back. You'll have to see whether your manual's towing section gives any advice on WD gear.
BTW - anybody buying a new TV certainly should expect the dealer to let them read the towing section in the manual first!
We're rooting for you to make it into the Airstream owner's world!! Let us know if this has been helpful please.
BobStream
...You really don't know someone 'til you've had recess with them. ...Alex Ziton, age 8
Old 03-22-2006, 01:36 AM   #6
Profile:
hi again pirates.....
don't ya just love clear advice......
this is mostly for canoe stream, but read along.....
so bob we mostly agree the pilot is marginal (a gentle way of saying not adequate)
moe has given us lots of good reading....as i suggested most maker's tow rating don't account for passengers, gear or fuel IN the tow vehicle.....so THE MOST IMPORTANT figure IS the gcwr.....
quote moe.....
"The tow vehicle's Gross Combined Weight Rating (GCWR) is what's important here. It's largely determined by the amount of engine power and gearing, up to a point. The further you are below the GCWR, the better the tow vehicle will perform on hills and in mountains."
so why don't you think the gcwr is a good place to start?
it is the total for tow, trailer, loads in both, accessories, hitch...everything rolling....
now as for honda.....
turns out they don't rate like the ge'em, ford, dodge...but rather like vw.....
so the 3500lbs IS WITH 4 passengers and fuel....a more honest rating....right?
and while the tow rating for the pilot is more honest (includes people/fuel)....the GCWR is still the best number to find and stay under....by 10-20 percent....i cannot find gcwr for the pilot...you will need to..
and the reason for the difference between trailer and boat?.....well honda is one of the few factoring frontal area into the calculations.....and the boat is more aero so......more can be pulled throught the atmosphere.....than a flat nosed trailer....
the touareg isn't frameless monocoque.....infact it IS one of the few hybird designs with monocoque/over rails......and they don't recommend against w/d systems.....it just doesn't raise the tongue rating which is >700lbs already.....right?
the honda also is a hybird monocoque with ft/rr subframe tubular/rails...
now the trailer in question is 3500 max rating loaded.....so tonque weight need not be 600lb or more as you suggest.....but can be 350-400 safely correct? perhaps at 4500 you are referring to the 19 footer not 16?
at 350-400 lb tongue..... w/d isn't need either is it?
and we already know that honda advices against w/d on the pilot and ridgeline, right? and with a tongue well under 500lbs....it isn't needed...
ok pirates.....bob and i may differ on details, and i'm no expert either......
but we agree the honda pilot isn't really ideal for towing a new bambi....even with the 'factory tow package' which is a tranny cooler and....? the pilot is right a the limit.....and with a full load of pork rinds....may be over......
cheers
2air'
Old 03-22-2006, 02:27 AM   #7
Jim Jarzabek's Avatar
Profile:  1950 25' Cruiser
Lebanon , Ohio
Images: 16
"Considering" a key word here....
Good thing you have not already purchased....
Frankenstein says - "Bambi good to camp in"
Frankenstein also says - "Honda too little to pull Bambi"
Frankenstein still insists - "Fire bad!"
Jim Jarzabek is offline   Reply With Quote
Old 03-22-2006, 06:54 AM   #8
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Not really. As 2Air said, it's just too close to the max tow capacity. If there are no passengers, driver, fuel or gear in the Pilot, maybe.
Old 03-22-2006, 07:04 AM   #9
genearnold's Avatar
Profile:  1992 34' Limited
Boise , Idaho
I defer to those with more knowledge and/or experience than I have. However, I'm remembering my friend, Gordon, who towed his Bambi all over the west with a VW Beetle! This was in the late 1960s and very early 70s. He now is more conventional with a later, larger Airstream and adequate TV.
Gene
'92 Limited 34ft; '96 Dodge Cummins 4X2, 5speed
genearnold is offline   Reply With Quote
Old 03-22-2006, 08:19 AM   #10
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
well, I've heard first-hand reports of a Honda Pilot towing a much heavier trailer than that, with very good results. It has alot of horsepower and torque for its size.
Personally, I think these "ratings" are nothing more than arbitrary numbers that indicate more what the factory is willing to absorb in terms of liability than anything resembling the vehicle's true capabilities. They're not based on anything concrete; if you exceed them, you won't turn into a pumpkin. and they already build in a large safety factor. adding your own on top of it is like the signature out there that talks of the glass being "half full" or "half empty"...but really: twice as big as it needs to be.
just take a look at the "ratings" for the chrysler 300. it has a huge power plant...same as in their trucks. but the TR is only 2000lbs. why? same plant in a truck=9000+ rating. I know,I know, frame and suspension matter. but its mostly the powertrain. The marketing department doesn't think this is an issue for the target market, so they just slap on a basic "yeah, go ahead and tow a snowmobile, if you need to" rating, and they don't have to actually test it for what it can really do. but the ratings on trucks go "up up up up" every year, without any perceivable changes to the vehicle itself. Hmmmm.....
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Chuck is online now   Reply With Quote
Old 03-22-2006, 11:26 AM   #11
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
gross trailer weight
My 19CCD has a gross weight of 4500 lbs. I believe that the 16 has a GTW of 3500lbs.
Lew Farber -Certified Master RV Tech (currently on Forums posting sabbatical, but lurking in the background )
WBCCI #1456 and about to resign!/VAC (assoc) #1456/ AIR # 10325
TAC# OR-1
CHARTER MEMBER: FOUR CORNERS UNIT
Old 03-22-2006, 12:22 PM   #12
Lebanon , Ohio
Images: 16
Specs readily available on the internet
Honda 2006 Pilot specs (including towing specs) are here:
@ http://automobiles.honda.com/models/...t&Category=ALL
Airstream 2006 Bambi specs are here:
@ http://www.airstream.com/product_lin...mbi_specs.html
It appears the dry weight of the Bambi is the maximum tow rating of the Pilot 2WD....
As we who have towed all know, the dry weight is never the actual towed weight.... it is much lower than what the trailer ends up to be (with all your supplies for camping & accesories)
If someone is foolish enough to accept the liability of towing a travel trailer that, when loaded, EXCEEDS the manufacturers' stated limits of the tow vehicle..... then that person should have no problem when their auto insurance/auto manufacturer/trailer manufacturer refuses a claim
Ratings exist for a reason, no matter what "armchair engineers" think
Old 03-22-2006, 12:43 PM   #13
Aluminut
I gotta second Jim's comments. I do also agree with Chuck to some extent as well.
My take is that power makes up only one part of the multipart equation.
Wheelbase, brakes, transmission, driveshafts, body/frame all are not just words, but major components to what makes a good/safe tow vehicle. Yes my Impala SS (325+hp, 390ft/lb torque and 3.73s) moved our Safari and I moved it over 3000 miles before upgrading to a 3/4 Suburban. By the numbers and modifications, that Impala could have moved a 34' Airstream. I didn't do it because of the other parts of the equation. Note I didn't say tow the Safari. The reason I say that is because the Safari was equal or greater in weight to the Impala, plus the Impala didn't have the proper wheelbase. The Suburban tows the Safari.
Now I am keenly aware we are talking about a 16' Bambi, but the reality is that one can bring to scale the same priniciples to the combo in question. That said, the rating will clearly be surpassed in a heartbeat and although it's only a 16' Bambi, I don't feel the driveshafts, transmission, unibody, etc are up to the challenge of near 4000lbs once fuel, passengers cargo and the full wet weight of the 16' Bambi. There are several different ways you can calculate it, but to me, they all equal pushing it.
Can the Pilot move the 16' Bambi? Sure, no question it can. The real question is however, can it tow it and are you willing to put you and your passengers lives at possible risk for doing something that many folks, including the manufacturer say might not be a good idea?
Old 03-23-2006, 09:01 PM   #14
TV Load Capacity vs. Tow Capacity
One last word .... (as if!)
2air' -- A good friend has a Toyota Highlander and he feels at the max handling his large Coleman popup. We would all agree these comfortable reliable vehicles are pushing it with a Bambi of any length.
My point commonly is this -- When a TV reaches its load capacity, in the real world it is usually well short of its tow capacity. The exception is unreal; i.e., one lightweight driver and nothing else in the TV. Doing the math I usually find that overmatched tow vehicles (when two people in a TV + internal cargo + tongue weight reaches specified tow vehicle load capacity) are usually only about 2/3d's of the way toward their tow capacity.
The right answer is delivered either way in this thread, but tow capacity can make a tow seem reasonable when the tow vehicle is actually overloaded.
(I would have answered sooner but my broadband was out yesterday. Almost 44 hours without Airstream Forums!! I can quit any time, really I can .... )
BobStream
Towing with a Honda Ridgeline lloydnc Tow Vehicles 26 05-07-2008 08:37 AM
Towing with a Honda Ridgeline? lloydnc Tow Vehicles 9 11-19-2007 07:24 AM
Towing with a Honda Ridgeline air19 Tow Vehicles 17 10-26-2006 10:58 PM
Towing A 19' with a Honda Civic Franco Tow Vehicles 0 09-11-2003 10:21 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
