Old 07-13-2019, 04:23 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Towing heavy trailer with a 3/4 ton
We have a 2008 Ram 2500 diesel. In great shape with ow mileage. It tows our 34 footer 9900# easy. Dodge says the towing capacity of the Ram is 12,800#. We are thinking about a 5th wheel SOB for full timing. Looking for advice on towing above the 12,800 factory spec. Any modifications to increase towing capacity? Air suspension?
Old 07-13-2019, 04:40 PM   #2
r carl's Avatar
Lin , Ne
Time for a new 1 ton.
Old 07-13-2019, 04:46 PM   #3
Mount Dora , Florida
Suspension is only part of the equation. You still have to be able to stop that rig. Axle bearings might seize. Tires or rims can fail. All sorts of parts are “rated” for capacity.
It’s my opinion that air suspension does exactly nothing to increase towing capacity. It will, however, help you level an overloaded truck.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 07-13-2019, 05:02 PM   #4
kpm
2018 25' International
Mound , Minnesota
Originally Posted by Lumatic View Post
[...] Looking for advice on towing above the 12,800 factory spec. Any modifications to increase towing capacity? Air suspension?
I have faced this situation a couple of times. IMO there is no good answer to this question. Time to have "the talk" with DW about upgrading the tow vehicle.
kpm is offline   Reply With Quote
Old 07-13-2019, 05:19 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Originally Posted by kpm View Post
i have faced this situation a couple of times. Imo there is no good answer to this question. Time to have "the talk" with dw about upgrading the tow vehicle.
"dw"?
Old 07-13-2019, 05:20 PM   #6
2019 27' International
Western , North Carolina
Overload is overloaded.. 1 ton is the answer
2019 International Serenity 27 FBQ “Serenity”
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 07-13-2019, 05:21 PM   #7
kpm
Mound , Minnesota
"dw"?
Dear Wife
Old 07-13-2019, 05:23 PM   #8
2012 19' International
Southeastern MI , Michigan
There are ways to do it. This is probably not the best place to ask.
Countryboy59 is offline   Reply With Quote
Old 07-13-2019, 05:46 PM   #9
brokeboater's Avatar
2003 25' Safari
High Springs , Florida
Spot on. The Ram Cummins forum would be a good place to start.
For my year/model, '06 3500 SRW Quad Auto, my tow capacity is 14,400#. In that year the only difference between a 2500 and a 3500 is one leaf spring. I towed a 15,000# fifth wheel from Florida to Alaska and back, 17,000 tow miles total, without as much as a hick-up.
I'd be interested to hear what your setup in truck wise to see where it ended up with that tow rating but again, this probably isn't the best forum to has that out.
“While you live, shine / Have no grief at all / Life exists only for a short while / And time demands its toll.”
brokeboater is offline   Reply With Quote
Old 07-13-2019, 05:51 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
I would not do something stupid like going way over the 12,800 pound capacity as quoted by Dodge, but might like to push it a thousand pounds or so. I wonder if the manufacturers recommended tow capacity is somewhat arbitrary.
Old 07-13-2019, 08:05 PM   #11
1987 34' Limited
Red Oak , Texas
The penny pinches for the manufacturers have a lot of say in tow rating. Take a '93 Dodge 250 with Cummins & a 3.55 rear axle.
With the 4 speed automatic transmission the GCWR rating is 12,000 lbs
Add a auxiliary transmission cooler and the rating goes up to 14,000 lbs
If it has a manual 5 speed the rating is 16,000 lbs
One of their biggest concerns is if the truck will get through the warranty period without breaking.
thomasg is offline   Reply With Quote
Old 07-13-2019, 08:15 PM   #12
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
"dw"?
“Dear Wife”
Old 07-13-2019, 08:55 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The Dodge diesel forum that I used to frequent has a forum for towing. I think you are going to have to study up and see what limits your model.
Old 07-13-2019, 10:02 PM   #14
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Suspension is a small part of the equation when considering towing capacity. Another issue not mentioned is going to be your cargo capacity and rear axle weight ratings. This takes into account driveline capacities, braking, frame strength, suspension, tires, etc. When you get into the larger 5th wheels they can have heavy pin weights, that by themselves, will exceed payload capacities of a 3/4 ton. Our former Mobile Suites had a loaded pin weight around 4000#s. Had to go straight to a 1 ton dually. And don't pay any attention to published pin weights or cargo capacities in the brochures. Know your specific trucks specs and weigh the trailer at the scales for an accurate pin weight so you know what you are working with in determining if your 3/4 ton is up for the task.
thewarden is offline   Reply With Quote
Hitch adjustments when going from 1/2 ton to 3/4 ton Wanna EB Tow Vehicles 8 08-18-2016 05:50 PM
"Heavy-Half Ton" Pickup Trucks hex Tow Vehicles 7 05-02-2013 12:49 PM
1/2 ton vs 3/4 ton towing? subfan1 Tow Vehicles 7 12-13-2007 03:10 PM
Big 3 1/2 Ton vs 3/4 Ton Trucks Streamer1 Tow Vehicles 40 11-20-2007 10:13 PM
