02-18-2016, 12:57 PM
#21
1975 Argosy 22
Eugene
, Oregon
Each engine has an RPM rating for peak HP and peak torque, if it isn't in your manual, look it up on line. When climbing a steep grade, try to keep the engine at or near peak torque, while maintaining a safe speed. If your instruments include a TEMP gauge, keep your eye on it, if it starts to get too hot, ease up on the gas and drop a down gear. The previous advice about "the gear you climb should be the gear you should use to descend" is a good rule of thumb. Your truck has instruments for a reason, learn how to use them. Using your gears will save on your truck and trailer brakes as well as your engine.
02-18-2016, 01:37 PM
#22
1962 28' Ambassador
1961 19' Globetrotter
Mesa
These have been excellent suggestions and well explained. Thank you all!
Hittenstiehl
02-18-2016, 01:49 PM
#23
2003 31' Classic
Terra Alta
, West Virginia
Remember as you start down a longer grade downshift and start slow. You can always go to a higher gear and speed up but slowing down if decending too fast can be a problem. Going up is not your big problem.
#24
2009 28' International
Pacific Palisades
Going uphill , start by letting the transmission select the gear. BUT, if you find it "searching" a lot--going back and forth between drive and 3rd or 3rd and second, manually select the lower gear. Constant shifting may overheat and/or wear your transmission excessively. Adjust your speed to where your rig feels comfortable within the torque range and note the RPM's on your tach for future reference. If you need 2nd to maintain uphill, try not to run near redline for any length of time, and definitely watch both the engine heat gauge and transmission heat gauge if you have one. Obviously, ambient air temperature is going to have a large effect here--its makes a difference if you'r climbing in 50 degree or 100 degree air temps flowing over your radiator(s).
Have a conversation with your engine servicing people--see if you can find one who tows with your vehicle and ask for their specific advice as to what rpm range you should use for more extended periods of time, and whether any engine or transmission heat gauge increases are OK or not OK for your engine and transmission over the long haul. Because automatic transmissions are actually quite delicate (in that they do not have a good tolerance of any foreign matter in their lubricating fluid), consider changing your transmission fluid annually if you tow 10K miles or more per year--a cheap preventative measure.
Over time, you will learn what grade of hills your rig is comfortable climbing at which gear and which rpm.
For downhill, do note the % of grade signs when they are posted. If the downgrade is marked 6 or 7%, for safety you might want to make sure you're in the right lane, slow to 45 mph, and shift into second (if that's within the acceptable RPM range for your vehicle--otherwise, slow more.) If you go to 40 or below, be sure to turn on your flashers. As you go down the hill and take your foot off the accelerator, if the truck slows down a lot using just the engine, you might consider shifting up to 3rd and see if the engine holds against the hill, again with no braking. And if it holds easily in 3rd, then shift up to Drive and see how that works. Soon you will learn at what slopes you need to be in which gear to utilize engine braking while getting the best controlled speed over the ground and not taxing the engine by being way high up in revs. Generally, engine temp is not an issue going downhill, but transmission load is always to be considered.
You should be using your brakes only occasionally, and lightly. Going downhill (or in hilly country in general) you may want to set your trailer brakes for a bit more aggressive braking--too strong for driving in bumper to bumper traffic where it would jerk you a little bit every time you touch the brakes, but not so strong that the trailer brakes ever lock up. By having the trailer brakes a bit stronger, you assure yourself that the trailer brakes are taking the full weight of the trailer and not pushing the tow vehicle down hill. My wife and I both prefer an aggressive enough setting that the trailer exerts an ever so slight drag on the tow vehicle (she actually feels safer while driving with a more aggressive setting than I feel is safe.) This lets it serve as a "sea-anchor" and helps keep the rig tracking straight. A light use of the brakes keeps them in reserve if you need an emergency stop. If you're braking all the times, they may be building to a glaze-over from heat and reduce efficiency.
Of course, going downhill it will take you much longer to stop, so you should allow that in following distance--no time to even think about tailgating--but I'm sure you know that!
If you crest the top of a hill in third and then shift to drive and as you start going down, the engine allows the rig with your foot off the accelerator to accelerate continuously, brake softly and firmly to bring the speed down to a level at which you can downshift to 3rd, and do the same thing if it's still happening in third so that you can safely downshift into 2nd. At this point, you will most likely be doing about 40 mph--if you're going much faster, you may be approaching redline on the tach. This is fine for short periods, but probably is not a great idea for long periods of time, so the slower speed at more moderate revs in the low gear is better for your rig. and again, hazard flashers if you're doing 40 or under.
Typically, if we don't know the slope as we crest the top of the hill, we will downshift one gear from drive (we have a 5 speed, so that means 4th on our "manumatic" transmission) or 3rd if it's obviously fairly steep looking, and then brake and downshift as described above if necessary.
Of course, a headwind will help you slow somewhat, and a tailwind will push you down harder, but all of the guides above should help you find the approach that is most comfortable for you to find good uphill and downhill "sweet spots" in your tachometer range to keep your engine and transmission running in a comfortable range while maintaining a safe and controllable speed uphill and downhill. Brake as necessary before entering downhill curves so that you go through them at a speed lower than the posted curve limit until you learn what your vehicle will comfortably handle. (We find that our rig is quite comfortable at the posted curve speed limit on steep slopes, but we always brake to just under so that we can negotiate the curve without brakes and come out at a speed not greater than the posted limit.)
02-18-2016, 02:15 PM
#25
1998 34' Limited
Lawrenceville
, Georgia
Your Ford probably has a tow/haul switch which may help with engine braking on downhill grades, depending on the model. Either way, it changes the shift pattern and protects the trans from overheating etc. to some degree.
As previously stated, you can "help" the truck make decisions on an uphill grade if it is changing up and down frequently and traffic keeps you from varying your speed to compensate, by shifting to "3" which will hold it in a lower gear. "2" is just a lower version of that and you would rarely use it unless you were stuck in traffic on a hill at speeds around 30 mph.
On many Fords, depending on year, "2" will also start you off in a higher gear which is usually only helpful if you are trying to get going in extremely slippery conditions. You can check this on your vehicle by starting forward on an uphill in "2" slowly and then switch into "1." If your vehicle is made that way, you'll feel a little jerk as it moves to low gear.
"1" is the lowest gear and most effective for engine braking, but only at low speeds. Your vehicle won't downshift into low unless you are travelling at about 25 mph or less. Where you might use it is if you are descending an extremely steep, longer incline, maybe with a trailer, and want to keep your speed very low to protect your brakes. If that were the case, you would switch into "1" at the crest of said incline and use your brakes as little as possible, but enough to keep your rpms at a reasonable level.
Good travelling and much happiness to you and yours!
02-18-2016, 02:48 PM
#26
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
"avionstream The tranny should down shift itself to third then second. If the engine is revving too high, slow down to lower rpms. Anyone, is this correct?"
Any vehicle/transmission/TV equipped with a tow/haul and a PCM,(powertrain control module), will choose the proper gear.....if you feel its rong, look to the engine power/torque specs and drive to the sweet spot.
02-18-2016, 03:42 PM
#27
2000 30' Excella
2014 30' Classic
Princeton
, Iowa
I have the same truck with a 30' Classic. Going up hill just leave it in drive and watch you Trany heat cage. I get real nervice at 210 degrees. When it starts to get close to that I ease up a little. Down hill decide your maximum speed you want to go and start at that speed. I use a gear that puts the tach at 3000 RPM's. I am conservative.
02-18-2016, 06:17 PM
#28
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario
, Ontario
I'm have been driving for over 56 years now, rallying, long distance driving, a licenced Aircraft mechanic, (A.M.E.) towing several RVs and so forth.
I have now a Ford F-150 EcoBoost, with 'tow-haul', but I prefer to manually shift it with the neat little buttons on the side of the shifter. Why????
Because I prefer to DRIVE the vehicle in accordance with what the vehicle is telling me; and NOT what some little 'office-bunny' in a cubicle who has proven that he/she has no idea of what my current situation is on the road.
'NWGETTAWAYS' IS RIGHT; along with Jeff; the best RPM to run your engine under load is at the peak torque of the power curve, all other things being equal.
However, not all things are equal, and under load it's best to keep your RPM up to allow for better engine cooling; especially going uphill with an RV. Use a lower gear and let the engine do it's job.
Going downhill, same thing. Use engine drag to keep your speed down, and control it with occasional braking.
I usually prefer to run at 2500 RPM with any vehicle, as I feel that it is the most efficient speed; and I'm fortunate in this respect, as the 3.5 EcoBoost max torque is at 2500.
My F-150 has a 3.55 final drive, and I normally use 4th. speed on the secondary roads, and 5th. on the 400 series highways. (Akin to U.S. turnpikes)
I never use 6th. gear, as it's too long legged, and overworks the engine at far too low an RPM.
I cannot see the logic in many of these manufactures offering 8 and nine speed trannys, as the engine RPMs would be just too low; unless they are offering final drive ratios of 4.56 up to 5.30 or so.
The engine needs to 'swing' at it's most efficient speed, and the ancilliary services need speed too. water pumps especially, generators, power steering, air conditioning pumps and so forth,
To those who would rely on the auto transmission doing it's job all the time, I say this:
Get to know your tow vehicle, and LISTEN to what it's trying to tell you.
The vehicle is the FINAL AUTHORITY on what it wants for best performance; listen to it; pay attention to it!
The first thing you would do in a new vehicle is read the directions and follow them; THEN learn to do it the right way, and enjoy many years of good motoring on the RV road.
02-18-2016, 07:15 PM
#29
2014 27' Flying Cloud
Stowe
, Vermont
If you have tow haul mode use it. Do not use cruise control up or down hill.
02-18-2016, 07:27 PM
#30
1962 28' Ambassador
Mesa
Lots of good info and most of which we were doing. But now we are better educated and informed .Only objection so far is its a Chevy not a Ford.
Hittenstiehl
02-19-2016, 07:55 AM
#31
2012 23' FB International
Woodstock
, Ontario
Generally I don't have a problem with downgrades. I just slow down at the crest and with the OD 'off' the truck holds pretty well. Judicious use of brakes to keep the speed under control keeps them cool. My TV is a 4.7 Dakota so it doesn't have a massive engine holding things back. I can't remember the last time I needed to use second gear in a down hill run, and I do a lot of 7% grades in Northern Ontario.
Up-hill is as noted several times above is a matter of finding the optimum torque range in your engine either manually or letting the engine look after itself. I pull at about 2700 rpm with OD off, but that is no where near the torque peak on the 4.7. If I want to make a steep hill with any reasonable speed I need to get up to 65 at the bottom of the hill which takes the engine nearer to 3000 rpm. About half way up on a long hill the engine simply gives up and shifts right to second and 4500 rpm. At that point as everyone notes, you just stay on it, and possibly lose speed on some hills. The 5 speed in the Dakota has a "passing gear" that is optimal on some grades but it won't stay in that gear even though it is in a sweet spot for RPMs and torque. I'm thinking about having the tranny reprogrammed.
JCW
02-19-2016, 08:17 AM
#32
1972 31' Sovereign
1975 31' Excella 500
Benton
, Arkansas
Towing, Grades, Hills, PRND321
When going up hill you want to lock into the highest gear you can to maintain a safe and prudent speed without having the transmission constantly up shifting and downshifting.
As a rule I will pull up hills up to 4500 rpm, but if the hill is very long and very steep I will hold the lower gear and take my foot out of the accelerator to about 4000 rpm.
Going down pick a speed and gear where you are not constantly on the brake pedal. On a long and steep grade you want to use the brakes no more than about 5% of any downgrade. Less than 5% is even better.
You can learn your vehicle by stopping at the bottom of a grade, if you can smell your brakes downwind, you used them too much. Adjust accordingly.
Brevi tempore!
02-19-2016, 09:25 AM
#33
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
If you choose to not use tow/haul mode and down/up shift your trans manually, be sure to do it with the selector in M manual mode and not with the selector in D. Manually shifting with the selector button while towing in drive alters the learned shift patterns of the automatic transmission. In other words, the office bunny in your transmission becomes confused and can start creating some hard shifts on the down grades.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
