Old 08-04-2008, 06:30 PM   #1
kepko
Profile:  hubbardston , Massachusetts
towing ford ranger
i have a 92 land yacht 36
if i choose to tow a ford fwd automatic ranger pickup with a tow bar because the 454 is already overburdened,,,do you put the automatic trans in neutral or do i disconnect the drive shaft every time????
can i damage the automatic trans???
do i have to have a manual trans???
thanx
kevin
newbie
kepko is offline   Reply With Quote
Old 08-04-2008, 06:35 PM   #2
purman
purman's Avatar
Profile:  1968 28' Ambassador
Cedaredge , Colorado
The owners manual should tell you, or you could call ford...
Old 08-04-2008, 07:49 PM   #3
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Kevin,
It will depend on the specific vehicle. Many years of the 4x4 with the manual you could tow 4 down with the transfer case in neutral. IIRC it took a special relay installed in the fuse box. I had a 1994 manual 4x2 and it was not recommended to tow 4 down for very far without dropping the drive shaft.
Best recommendation is to ask your Ford dealer. FWIW they do make a disconnect kit that goes in between the drive shaft and one of the drive yokes but IIRC it costs almost as much as my last Ranger did.
Aaron
WBCCI #2449 AIR #2495
Old 08-04-2008, 10:34 PM   #4
mustang
mustang's Avatar
Profile:  1971 31' Sovereign
Kent , Ohio
You better drop the drive shaft. When the tranny is turning and it is being turned by means other that the motor the front pump will not pump proper fluid and you will tear it up. You also need to make sure you have the fron hubs removed. I think even if you put the transfer case in N you will hurt the transfer case. I just watched a towing show called Wrcked on speed channel and they just disscussed that. Hope this helps
mustang is offline   Reply With Quote
Old 08-05-2008, 05:54 AM   #5
overlander63
Rivet Masher
overlander63's Avatar
Profile:  Bay Area , California
Originally Posted by mustang View Post
You better drop the drive shaft. When the tranny is turning and it is being turned by means other that the motor the front pump will not pump proper fluid and you will tear it up. You also need to make sure you have the fron hubs removed. I think even if you put the transfer case in N you will hurt the transfer case. I just watched a towing show called Wrecked on speed channel and they just disscussed that. Hope this helps
The front hubs on the Ranger, Explorer, and Aerostar (yes, they made them in 4wd) are the auto engage type, and can both be damaged by towing 4 down, they can also rotate the other drive components, and cause damage to them. Removing them is very easy, just remove the tire/wheel assemblies, and pull off the center hub. As far as keeping dirt and gunk out of the mechanism, maybe you could get a worn-out set of them, and gut them. Put the gutted pair on when towing.
overlander63 is online now   Reply With Quote
convex towing mirrors for the ford superduty..... 2airishuman Towing, Tow Vehicles & Hitches 12 06-30-2008 10:01 AM
V6 Ford Ranger and Argosy Minuet Dan S Towing, Tow Vehicles & Hitches 21 03-30-2007 08:37 AM
Ford towing information thenewkid64 Tow Vehicles 1 10-26-2004 10:31 PM
Towing With Ford Windstar Auld Scot Tow Vehicles 6 06-08-2004 05:51 PM
Towing With a 1974 Ford F100 melprice Tow Vehicles 6 07-08-2002 11:28 AM
