Old 05-07-2008, 09:44 PM   #1
leighmiller
Profile:  Fallston , Maryland
towing with a chevy 1500
Hello all, I am an airstream virgin. I have been looking for just the right vintage model airstream for a couple of years now. I have looked at a few in person, a whole bunch online, and have picked my friend's brain who restored a 1965 Caravel. I had settled on looking for a 1970 Tradewind or Ambassador. On a whim I low balled a bid on ebay on a 1970 Sovereign, and guess what? I am driving out to pick her up this weekend. Now I am in a panic. I am not sure whether to dance for joy or cry. I either have a huge dream AS or a BIG pain in the ..... I have never towed anything in my life!!!! I have, two potential V8 tow vehicles. One is a 2006 Ford Explorer. I am pretty certain it is not heavy enough to do the job despite what the tow specs say. I also have a 1995 Chevy Silverado 1500 Z71 extended cab 4x4. Can I tow a 1970 Sovereign safely from Ohio to northern Maryland with this truck? I will be on the PA turnpike. There are some hills but nothing extremely steep. What do I need to do to get her home? What gear should I drive in? I am already having a brake assist put on and the Chevy does have the factory installed tow package. I know the weight for a 70 Sovereign is supposed to be around 4960 empty, but am not sure of the tongue weight. The GVW inside the door of the truck say 6200lbs. Do I need a sway bar and if so what kind? Please, no lectures about how I have lost my mind, I am already well aware of that fact.
Thanks for any advice y'all can give me
leighmiller is offline   Reply With Quote
Old 05-07-2008, 10:23 PM   #2
Campaz
Profile:  1987 23' Sovereign
Tucson , Arizona
You should do fine with the Chevy as a tow vehicle. I checked the A/S website and it lists the '70 31ft Sovereign with double bed @ 4960lbs. It has a tongue weight of 490lbs. The hitch ball height is 19in.
A suggestion, if you have never hooked up or towed before would be to find a good RV dealer in the trailers area and have them sell you a hitch and set it up for you. Perhaps the seller would deliver the A/S to the dealer for you.
Have them look over the "running" gear, tires, brakes, etc. They'll know what to look for. You will need at least an equalizing hitch. You might also want some sway control. Be prepared to spend a few bucks. Good Luck be safe.
Campaz is offline   Reply With Quote
Old 05-08-2008, 06:04 AM   #3
moosetags
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Welcome to the Forums from the Florida Panhandle
We're glad to have you with us. Congratulations on you new baby.
I agree with campaz. The Silverado should be able to handle the job, but you will definitely need an anti-sway weight distributing hitch system when you tow that airstream cross country. If you make that long tow without one, you will very likely never want to tow anything again, turning your new Airstream into a very expensive piece of yard art.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 05-08-2008, 06:11 AM   #4
Silverhobby
Silverhobby's Avatar
Profile:  1956 26' Cruiser/Overlander
1957 26' Overlander
1962 22' Flying Cloud
Vale , North Carolina
A competent dealer can install an equalizing hitch, sway control, repack wheel bearings, and the like. Best of luck to you and welcome to the FORUMS.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 05-08-2008, 01:06 PM   #5
SteveH
SteveH's Avatar
Profile:  2001 25' Excella
San Antonio , Texas
I agree with everyone above. Get yourself a good WD hitch, get some help with the setup of the hitch, and have the running gear of the trailer serviced.
Welcome to the forum.
Old 05-08-2008, 01:25 PM   #6
ROBERT CROSS
THE FRANTIC BANANA
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 31
Thumbs up Welcome Aboard.
Yes, the 1500 is your best option, and ditto on what the others have
suggested.
Probably the BEST thing you could do...Take your Airstream friend with you!!
GOOD LUCK and Stream Safe.
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 05-08-2008, 01:49 PM   #7
Steve & Susan
Steve & Susan's Avatar
Profile:  2005 28' International CCD
Willoughby , Ohio
Hello!We've ALL had our first towing experiences and yours need not be frightening.We also tow with a C-1500 (although not a 4X4) and have not had problems.We use Overdrive (automatic transmission) on flat stretches and let the transmission tell us when that is not sufficient.I agree with everyone who says you need a weight distributing / anti-sway hitch set-up. We use Equal-I-Zer and have had no problems with it.Since you have not towed before..Just remember, that's gonna be an additional 2.5 to 3 TONS behind you - take off slower, give yourself LOTS more stopping room, make your turns wider and keep it at 60 mph. Also, get some towing mirrors - that TT behind you will obscure your vision with your regular mirrors. Changing lanes/passing requires that you know where the AS end of your AS is - towing mirrors will help. Let the truck down-shift on those long uphill grades on the PA Pike if it needs to - there's nothing wrong with climbing those babies at 50mph instead of 60 mph. And let the engine compression keep you at 60 on the downhills - resist the temptation to fly down them - even with anti-sway, bad things can happen very quickly if you get above 65 mph.Make sure your AS lug nuts are tightened correctly before you start out and then stop at a rest stop after about 50 miles to re-check them. Also make sure your tires are inflated correctly all the way around.Make sure your umbillical cord doesn't drag on the ground behind your TV, or your chains for that matter.You'll also need a brake controller if your AS has electric brakes so that your TV is not doing all the work. I don't know what the braking system on your AS is - you should check into that.Finally, make sure all of your AS lights work when connected to your TV - flashers, turn signals, brake lights and running lights. Best of luck - maybe take a few digital pictures of your rig at a rest-stop and post them for ust to see! BTW - with that set-up, you'll be running with the BIG DOGS on the highways and you'll need to park with the 18-wheelers at the rest stops.
Steve & Susan
2005 28' CCD, 2002 Silverado-C1500, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 05-08-2008, 02:25 PM   #8
Mikethefixit
Mikethefixit's Avatar
Profile:  1977 27' Overlander
Trotwood , Ohio
There are a lot of opinions but I believe the Chevy is the only choise in this situation. I would find a competant RV Dealer and purchase a Reese TwinCam Straight line hitch. We have a dual cam Reese that we tow with and we have met every high profile vehicle there is on two lane roads with no sway problems. Just take it low and slow to start with, let no one pressure you and you will be fine. Remember Safety is the key ,give yourself lots of room to stop,never follow to close.Always give yourself some place to go in case . Have the dealer help you choose a hitch that makes the trailer tongue level when hooked up.
THE BEST of Luck to U and your new adventure
Roger
Mikethefixit is offline   Reply With Quote
Old 05-08-2008, 06:05 PM   #9
Smokin Camel
Profile:  1972 25' Tradewind
Madison , Wisconsin
I tow my 1972 25' Tradewind with a GMC Sierra 1/2 ton....the same truck different trim! I have the 5.7 engine and it is adequate. I did use a 1500 with a 4.8 to move it once, the 4.8 was okay for a short hall but did struggle a bit on a steep hill.
Don't forget towing mirrors! You will do fine.
Make sure the tires are in good shape and not something 7-8 years old that may blow out.
Before I even moved my TW for the first time I repacked the bearings then replaced the tires.
Give yourself some room for wide turns until you are used to how the trailer tracks when making turns...the rest, you will figure out prety quickly, it is not that hard.
Check out the brake & turn signals, make sure your brake controller sycronizesllllI am sure there are a few other important things you can pick up from reading a few of the threads. Welcome to the cult....I mean club .
Smokin Camel is offline   Reply With Quote
Old 05-08-2008, 10:12 PM   #10
leighmiller
Thanks for all the good advice, I do appreciate it. I have spent the day looking for a weight distributing hitch and sway control, problem is I need the AS to fit it propperly, which is sitting in Ohio. Hope to get measurements from current owner so I can at least get my big puppy to a good RV dealer to adjust the hitch before I hit any serious hills.
Thanks again!
Old 05-08-2008, 10:32 PM   #11
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
You may be able to talk the seller out of his W/D hitch .
I did on all 3 of my A/S purchases. Make sure before you spend the money for new.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-09-2008, 04:07 AM   #12
Steve & Susan
Willoughby , Ohio
Where in Ohio are you picking up your new baby?
Steve & Susan
Towing capacity of a Chevy Silverado 1500 luca_brasi Hitches 11 10-03-2007 09:07 PM
GMC/Chevy Towing Mirrors Cracker On The Road... 6 01-08-2007 04:52 PM
Towing with a Z-71 Chevy? Paulk Tow Vehicles 7 06-20-2005 09:23 AM
Towing with Chevy 6.5 TD j54mark Tow Vehicles 6 08-11-2003 10:09 AM
GMC 1500 Z-71 what mods for towing ? Rod Pease Airstream Trailer Forums 5 01-07-2003 01:32 PM
