Old 01-23-2019, 05:44 PM   #1
2015 25' Flying Cloud
columbus , Georgia
Towing capacity??
2011 Tundra - GVWR= 6900
2015 25FC GVWR= 7300. Dry weight is 5700.
Plan is 4-5 hour trips at essentially no elevation (middle Georgia)
We will only be adding about 600 pounds of gear max.
Can I tow with this Tundra ?
Shazam is offline   Reply With Quote
Old 01-23-2019, 05:50 PM   #2
2018 28' International
Fayetteville , Georgia
Maybe. Maybe not. You need to consider the tow rating of the truck, max tongue weight of the truck, axle weight limits, payload, gross vehicle weight rating, etc. I expect you will be OK, but your pinch point may be payload or tongue weight.
And many folks tow above rated limits.
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 01-23-2019, 05:59 PM   #3
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
You're in good shape with that Tundra & AS. Use a WDH to reduce tongue weight & enjoy the adventure. I have a 25' FC also & tow with a Titan/Cummins diesel however, we do mountain trips, Rockys etc & need the torque.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 01-23-2019, 06:09 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Maybe.
You have not provided enough information to say for sure, because there is a lot of variation of equipment and capacities.
For example, this is the range of capacities for a 2011 Tundra:
Towing capacity: 4,500 to 10,400 lbs
Payload: 1,450 to 2,090 lbs
Horsepower: 270 to 381 hp
ps:
Read the owners manual for the tow vehicle.
Alan
Old 01-23-2019, 06:13 PM   #5
1994 34' Excella
Warren , Manitoba
How does a WDH reduce tongue weight? Where does the weight disappear to? I have always read, understood, and used the WDH to "distribute" the weight of the hitch. You need to know all the things that brick1 mentioned, as well as the CGVW (combined vehicle weight rating). Just because someone says "i do it", dosen't mean that it is correct or legal. Best to be legal, just incase you are involved in an accident. You don't want anybody to point a finger and sue, as insurance companies love to find ways to not pay or recoup their payouts. JMHO
WBCCI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 01-23-2019, 06:52 PM   #6
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
Well, the tongue weight doesnít disappear. But the WDH will take some of that tongue weight and transfer to the tow vehicle front wheels and some to the trailer wheels. Thatís why you should weigh the rig.
KK4YZ is offline   Reply With Quote
Old 01-23-2019, 07:14 PM   #7
columbus , Georgia
Warn- This is all the info I have available - It is 381HP, 5.7L
GVWR- 6900. - I assume this is what you mean by towing capacity?
CBWell- Excellent point about potential legal ramifications.
I also have an Equalizer WD hitch
Old 01-23-2019, 07:50 PM   #8
2017 28' International
Baileys Harbor , Wisconsin
Does it have a tow haul mode? If it does I think you will be fine. The tow haul mode is helpful to keep the transmission from overheating as well as slowing and breaking.
My suggestion is take it on an hour trip somewhere and see how it handles on regular roads and freeways. The biggest thing with a marginally powered truck is accelerating in traffic. I have an F150 Ecoboost rated to over 12,000lbs for my 28’ Serenity which weighs about 7200lbs loaded. It’s nice to be able to have some acceleration.
Daquenzer is offline   Reply With Quote
Old 01-23-2019, 07:52 PM   #9
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
You need to know tow vehicle's GCWR (gross combined weight rating).
Gear ratio of the drive axle has a lot to do with this, as does engine size.
There should be a chart in the owner's manual that gives GCRW based specifically on the equipment in the tow vehicle.
My guess, based on the info you have shared so far, is that it will do ok towing in the flat lands.
Does your vehicle have a brake controller that will activate the trailer brakes?
There should be a sticker/placard on the drivers door jamb that gives the payload capacity and axle rating.
You must do the math. When you find all of these specs AND then weigh the vehicles, then you have what you need to calculate the suitability of the tow vehicle:
GVWR (door placard)
GCWR (door placard or owners manual)
Payload capacity (door placard)
Hitch capacity (owners manual or hitch manufacturer's data)
Both Axles capacity (door placard)
Tire's load capacity at ? PSI (tire manufacturer's chart)
Alan
Old 01-23-2019, 08:26 PM   #10
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
FWIW, I have towed our 34' Airstream with a 2009 F150 5.4L using a ProPride WD hitch (also eliminates sway. I didn't enjoy the Equalizer I had at first). We base out of the Atlanta area, so similar to Shazam. This combo has been to New Mexico, up to Wyoming, the Virginia's and points between without any problems.
The Tundra you have is a larger more powerful package than my truck. Properly set up, you should have many enjoyable years of towing.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 01-23-2019, 08:37 PM   #11
gandttimes's Avatar
2014 25' FB International
2007 20' Safari SE
2005 19' Safari
Qualicum Beach , British Columbia
GVWR = Gross Vehicle Weight Rating.
GCWR= Gross Combined Weight Rating.
Subtract the first from the second to find the weight of the trailer you are capable of towing.
Payload is going to largely tell you the weight of the trailer tongue ( equalized) and passengers and cargo you can carry.
Should all be available on door sticker, manual and website.
I would suspect with the engine you have and Toyotas final drive ratio you should be fine.
gandttimes is offline   Reply With Quote
Old 01-23-2019, 08:57 PM   #12
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Towing capacity??
I have an 08 Tundra with the same engine and transmission. I can assure you that you will have plenty of power. My GCWR is 16,000 lbs, yours I suspect is similar.
Like A W Warn said you need to do the math to determine how legal you are. The tightest criteria to meet, I believe, will be the rear axle weight rating. You have to weigh your rig to determine the weight on the rear axle. Then compare this to the maximum rear axle weight allowable on the drivers side door jamb. It is probably about 4,100 lbs.
Attached are photos of my drivers door jamb stickers showing the GVWR, payload and axle ratings.
DanClick image for larger version
ID:	332276Click image for larger version
Old 01-23-2019, 11:29 PM   #13
waninae39's Avatar
2017 22' Sport
NCR , Ontario
contact andy at canam rv
he is the #1 RV towing guru in CAN/USA
he has a old jetta that pulls a very big AS
thus he should be able to get yours to work
waninae39 is offline   Reply With Quote
Old 01-23-2019, 11:30 PM   #14
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Does the Tundra have the tow package? Meaning a tow/haul mode along with transmission cooler and larger radiator. Among other things.
Probably not equipped with tow mirrors. Unless they were installed after original sale.
What's your preference? Over capacity TV or under capacity? AlinCal Towing, Tow Vehicles & Hitches 132 11-07-2018 08:36 PM
Towing capacity of 345 chopperbob General Motorhome Topics 11 09-06-2017 02:24 PM
Bmw Towing Capacity Please Help ACHALAT Tow Vehicles 4 02-03-2006 07:42 AM
Towing Capacity of the 360 swebster Airstream Motorhome Forums 37 06-01-2005 04:54 PM
Towing Capacity of 1995 30' Land Yacht Motorhome autoist General Motorhome Topics 4 07-23-2004 01:51 PM
