Old 04-05-2014, 01:58 PM   #1
1987 33' Argosy
Colorado Springs , Colorado
towing an old trailer with an old truck
I have a 87 Argosy 33'. I'd like to match it with a truck of roughly the same vintage for the aesthetics.
I have a 77 Chevy K10 "Heavy Half" 1/2 ton pickup (350 cid engine, Turbo 350 transmission, 4x4) but it is kind of a beater and am pretty sure it isn't up to the task.
Any suggestions? What were the tow vehicles of the day in 1987?
tworavens is offline   Reply With Quote
Old 04-05-2014, 02:09 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Suburbans and pickups. Cars were downsized in about 1979-1980. Some 1980's cars would work for a shorter trailer.
Bill
Just my personal opinion
Old 04-05-2014, 02:14 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
It's probably doable. The one thing that I would want, though, is a tow vehicle with disc brakes for a trailer of that size. I'm not sure what years the pick-ups went to discs. There are kits available to retrofit disc brakes.
Brian
SuEllyn & Brian McCabe
Old 04-05-2014, 03:00 PM   #4
SteveH's Avatar
Common Sense , Texas
IIRC, GM trucks had disc brakes in the front in the 70's, but did not get them in the rear until recently....something about corrosion.
Regards,
Steve
Old 04-05-2014, 06:50 PM   #5
andreasduess's Avatar
1984 34' International
Toronto , Ontario
1984 Airstream advertisement. Not disagreeing with anybody, perhaps expectations were different those days.
andreasduess is offline   Reply With Quote
Old 04-05-2014, 08:01 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Big drum brakes work pretty well, and even my 08 Silverado uses drum rear brakes.
Old 04-05-2014, 09:12 PM   #7
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
An '87 Ford diesel pickup F-250 will handle it with no problem and the 6.9 is a very reliable diesel engine. Not the power of the new turbo diesels, but has much better mileage and less maintenance issues than the newer diesels. The gas rigs from the same era are plenty good to tow an AS regardless of brands, but the main issues are the trannys and rear end ratio's. You want a 4:10 or 4:30 if it is an automatic or a manual with a "granny" gear first gear.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 04-06-2014, 01:25 AM   #8
1988 Argosy 32
Lomita , California
I tow A 1988 argosy 28' With F-250 Diesel 6.9 = 421 cid no turbo, 4x4 We call it The
Beast, and it is.
Got it new in 1985 used to tow A 28' x 12' Farlon up and down the west coast. it was way way Heavy,
Came with Front disk brake's and rear drums, Works for me for the last 29 years.
Rebilt trans for heavy towing, added LARGE trans cooler (needed)
Added 1 rear leaf spring each side.
I runs great
Wolfe is offline   Reply With Quote
Old 04-06-2014, 05:29 AM   #9
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
In 1985 I took a trip to Florida with a 32' Argosy and a 1985 Oldsmobile Delta 88. It worked very well, a little more cross wind effect than an Airstream but certainly an excellent towing trailer for not being all Airstream. Most of these that we sold went on 1/2 ton Suburbans with 3.73:1 axle ratio and a 350 engine. They had 15x8" rims with 235/75R x 15" LT tires.
If you are going to get a period truck try and find one without four wheel drive. All the 4x4's of that era had straight front axles the rear drives had independent front suspension which handled and rode dramatically better. Also if you find a great truck with the wrong axle ratio you only have one ring and pinion to change.
I hope this helps.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 04-06-2014, 05:37 AM   #10
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Restore the '77 and tow with it.
I know a guy with a red and white '74 in nearly mint condition, but he won't sell...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
best 10-20 year old truck for towing 21' globetrotter? ssfletch Tow Vehicles 22 06-07-2010 07:55 PM
Best Old Trailer for 2006 Tacoma V6 Truck? barbara4rb Member Introductions 3 06-03-2007 08:25 AM
New Reese System for old truck and Trailer JLD Hitches, Couplers & Balls 12 03-17-2003 07:46 AM
