11-23-2011, 02:03 PM
Portsmouth
, New Hampshire
Towing an Airstream With a Touareg
Is there anyone out there towing an Airstream with a 2011 VW Toureag? If so, what unit are you towing, are you using any type of weight distribution or anti sway equipment? And more importantly, are you concerned that VW specifies no larger than a 2" tow ball is to be used as well as no additional equipment such as weight distribution, etc.?Any feedback would be appreciated. Thanks.
11-23-2011, 02:07 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
11-23-2011, 03:03 PM
Lost in America
2015 27' FB International
2004 19' International CCD
Santa Fe
, New Mexico
Before the masses chime in, tell us which Touareg you own. V6 gas, V6 diesel or V6 hybrid?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017 Chevy Silverado 2500HD Duramax Diesel
11-23-2011, 03:05 PM
1969 27' Overlander
Albuquerque
, New Mexico
Please keep a video-cam handy!!!
I want to watch...
Ed Glenn
11-23-2011, 05:03 PM
Portsmouth
, New Hampshire
The Toureag I have is the 6 cyl diesel, steel frame. Towing capacity is 7700 lbs, max tongue weight is 613 lbs
11-25-2011, 11:44 AM
Lost in America
Santa Fe
, New Mexico
Firrst, do a search for Touareg here and sort through all of the contradicting opinions. But in a nutshell the newer TDI6's are best adapted to 23' or less. You can go longer, but you may exceed your max hitch weight and power capacity on long grades. You can use a weight distributing hitch, although VW says otherwise. It is a German manufactured car and they have different standards in Europe. The factory hitch is overbuilt and can handle the actual 770lb rating and then some (VW will send you a replacement sticker if you want one).
Over 40,000 miles towing with a V8 and V10TDI with a 19' Bambi and a 25' FB and no problems from the flats of Florida to the highest passes in the Rockies.
OK, the non-Touareg owners can now chime in....
11-25-2011, 12:17 PM
2010 28' Flying Cloud
Fort Worth
Does anyone know what kind of AS & tow vehicle that AS Life Magazine publisher Rich Luhr uses? I heard it was some kind of Mercedes but not sure about the AS.
Thanks!
Old Cobra AH-1G Pilot
11-25-2011, 03:11 PM
2007 23' Safari SE
Central
, Connecticut
He has a GL320 Bluetec and a Safari 30' Bunkhouse.
Tom
11-25-2011, 07:02 PM
Portsmouth
, New Hampshire
What is troubling is VW's stating that no larger than a 2" diam ball be used. Air Streams require 2-5/16".VW won 't change their position on this.
11-26-2011, 05:25 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Originally Posted by imaginair
......VW won 't change their position on this.
You can always tell a German...but you can't tell 'em much.
11-26-2011, 08:38 AM
Foothill Ranch
Why would you want to tow an Airstream Motorhome with a VW?
Unless this thread would be better in the Tow Vehicle section for Trailers...
11-26-2011, 04:32 PM
Lost in America
Santa Fe
, New Mexico
Haven't heard that one. But then the manual says "If you plan to tow a trailer, please remember that your car will be performing a service for which it was not intended."
There are also mentions regarding the use excessive speed.
So why did they build V10 diesels with factory mounted tow hitches that can do 170mph and tow a 747?
Your car will not care what size ball it is towing with... only the weight and size of the towed vehicle matters.
11-26-2011, 05:05 PM
Oswego
Germans have lawyers too!
-Rich-
12-19-2011, 03:59 PM
Sioux Falls
, South Dakota
"You can always tell a German...but you can't tell 'em much.
Bob"
Jawohl!
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
