Old 04-03-2008, 10:18 AM   #1
2008 19' Bambi
corona , California
towing an Airstream with 2008 Range Rover Sport
Towing a travel trailer with a range rover sport. Any success stories? Not getting much help from Airstream or Land Rover dealers. A photo or conversation regarding this matter would be appricated.
allen galkin is offline   Reply With Quote
Old 04-03-2008, 10:30 AM   #2
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
using a chevy... but this looks kewl...
http://picasaweb.google.com/lh/photo/Bwy45BoD5fN5JoZKMvfj1A
boondockdad is offline   Reply With Quote
Old 04-03-2008, 12:23 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Hello Allen -- Welcome to the Forums! Seat of the pants I don't recall much favorable about either Land Rovers or Range Rovers from people who have towed with them. You are entirely correct that auto dealers are usually out of their league in discussing towing anything more than a small boat or popup camper. They
Here are only 2 threads among quite a few mentions:
http://www.airforums.com/forums/f463...ver-32799.html
http://www.airforums.com/forums/f463...ory-17136.html
For more do an advanced search on the word rover only but select the Towing, Tow Vehicles & Hitches subforum.
The Rover Sport payload capacity looks pretty darned low -- 1070 to 1126 pounds depending on engine, optional equipment, etc.
5 meter Langford Nahanni
Old 04-03-2008, 01:22 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
19' might not be too bad....16' would be better.
Old 04-03-2008, 01:34 PM   #5
Darol Ingalls's Avatar
Both Aistream and Rover dealers will avoid making recommendations concerning that combination. That vehicle lacks enough power to be on the road with "bigger dogs" even on its own let alone pulling any type of trailer. Dealers are very wary of liability issues and will only direct you to the owner's manual which is not always that believable. Think wheelbase and weight/horsepower ratio. The old Airstream owners manuals had weight/power recommendations but I can't remember exact figures. You may be able to find an older manual on-line and check it out. Darol
Darol Ingalls is offline   Reply With Quote
Old 09-16-2010, 11:41 PM   #6
1972 23' Safari
1974 25' Tradewind
You may want to rethink the Land Rover as a TV. June 16, 2010 The Land Rover Discovery 4 has been awarded " Britain's best Tow Vehicle"
The Land Rover Discovery 4 Scoops Britain's Best Towcar Award
RichSM is offline   Reply With Quote
Old 09-17-2010, 02:33 AM   #7
rovercamper's Avatar
Grottoes , Virginia
Not sure on the Sport with towing or new Airstream weights but my Disco 3 tows the old 71 TW like it's not there, I think it's around 5000ish loaded. Max braked trailer load for a D3 is ~7700# I've towed trailers near max, and that was a long slow drive, wouldn't want to do that very often! Your Rangie's owners manual lists the tow capacities.
rovercamper is offline   Reply With Quote
Old 09-17-2010, 06:12 AM   #8
Mouse Nest Hunter
RoverOwner's Avatar
1961 28' Ambassador
Sherburne , New York
I've used my LR3 to tow a 3500lb boat through the adirondacks a number of times. I believe the LR3 and RR Sport share a chassis. No trouble with the tow whatsoever. Very stable. I only tow the boat a couple times a year, and if I did it more I would want to install a tranny cooler. Other than that, it's a great tow vehicle.
edit: Looks like the LR3 comes from the factory with a transmission cooler, so I'm sure the Sport does as well. Great tow vehicles for a light trailer.
www.1961airstream.blogspot.com
TAC NY-2
RoverOwner is offline   Reply With Quote
Old 09-19-2010, 08:26 PM   #9
1972 23' Safari
1974 25' Tradewind
I've towed my 72 Safari and 74 tradewind many miles with my 2008 Range Rover Sport. No problems at all. The Safari from Houston through the mountains Durango, Telluride, Ouray along the Million Dollar Highway. The tradewind through Texas, New Mexico and Arizona. The RRS even adjusts fo weight automatically.
Old 09-19-2010, 10:56 PM   #10
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
You need to remember what they were designed for and what they are used for in England to tow with. They were a farm truck. They were designed to tow horse trailers and very small Camping trailers. You don't get them much bigger than 16-20 feet over there. So yeah it's a great TV over there but over here I would put it with the Grand Cherokee. The are dogs. And then there's the reliability factor. It's not know for that. My aunt has had a few and they all had problems.
You will probably been fine but I would try to get the tow ratings for it.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-20-2010, 05:50 AM   #11
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
That's because it's the only british vehicle capable of towing anything. It's kind of like awarding Airstream with 'America's best rounded aluminum monocoque travel trailer'.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 09-20-2010, 08:20 AM   #12
Airstream Germany
aheun's Avatar
2010 International 684
2014 28' International
Limburg , Germany
Well the Range Rover Sport is actually a Discovery not a Range Rover.
But it is an awesome towing car.
We use the Range Sport TDV8 a lot for towing Airstreams and also commercial trailers.
Here in Germany it is rated at 7700 LBS towing capacity which is the maximum anyway for these kind of trailers over here.
Here is a Range Rover Airstreaming Video from last weekend...
Airstream Europe
aheun is offline   Reply With Quote
Old 09-20-2010, 08:57 AM   #13
Dave Park's Avatar
2005 22' Safari
Hyde Park Place , Ohio
Britain isn't like America. When Britain has World Championships, they invite other countries.
TX-16
Dave Park is offline   Reply With Quote
Old 09-20-2010, 09:02 AM   #14
Dave Park's Avatar
2005 22' Safari
And like I thought: other weight category winners were:
Kia 1.6 (not British)
Mazda6 2.2D (not British)
Skoda 3.6 V6 (not British)
Volvo XC60 (not British)
TX-16
Old 09-20-2010, 09:25 AM   #15
Grottoes , Virginia
Me and my boyfriend both own Land Rovers, and will always own Land Rovers. Nothing else would put that permagrin across my mug every time I jump in the drivers seat
Like that passionate feeling many of us have for our Airstream - they are more than just campers, Land Rovers are much more than just a means of transportation. You either get it, or you don't
Just remember that if you get a Land Rover, they like to have some dirt on em!
Old 09-20-2010, 10:24 AM   #16
purman's Avatar
1968 28' Ambassador
The land rover or range rover will tow. no doubt. Personally I live the Defenders. And the older ones. They will go anywhere. Why do you see older Toyotas and land/range rovers in all the 3 world countries. They last for ever and go anywhere.
Jason
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 09-20-2010, 05:04 PM   #17
1972 23' Safari
1974 25' Tradewind
You need to remember the original question.
"Towing a travel trailer with a range rover sport. Any success stories? Not getting much help from Airstream or Land Rover dealers. A photo or conversation regarding this matter would be appricated."
I'm not arguing that there are not better tow vehicles - just that my experience towing my AS with my RRS has been very succcessful.
End of Story.
Old 06-20-2014, 07:26 PM   #18
motoswiss's Avatar
2007 23' Safari SE
Katy , Texas
2013 Range Rover Sport with 23' Safari
Very successful 1200 mile trip this last weekend. Plenty of power but I recommend ensuring the water tanks are emptied.
motoswiss is offline   Reply With Quote
My New 2008 Safari Sport 17' Airstream AirStrmFltRN 2008 Safari SE 48 03-21-2018 11:54 PM
Towing with 2006 Range Rover ghaag Tow Vehicles 15 06-30-2010 01:46 PM
Range Rover Sport w/ equlizer 64Vette Hitches, Couplers & Balls 0 05-04-2007 07:44 PM
Land Rover Sport Beware woodedareas On The Road... 13 11-03-2006 04:32 PM
towing with a 94 range rover maryszka Tow Vehicles 3 02-17-2004 06:36 PM
