03-23-2014, 06:53 PM
#21
1997 34' Limited
1970 27' Overlander
South of Atlanta
, Georgia
Since your original post asked about the 150/34' combo, we have been happily towing our 34' with a 2009 F150 5.4L V8. I have been very happy with the combo. Initially I had a Reese type hitch and wasn't so happy. When I added a ProPride hitch to the combination it became a very comfortable package.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
03-23-2014, 08:34 PM
#22
1970 29' Ambassador
1959 22' Flying Cloud
1957 26' Overlander
Ashland
, Oregon
Towing a 34ft with an F-150
I'm curious, how would a 2008 f250, 5.4L gas, do with towing a 1970 29' ambassador?
03-23-2014, 08:40 PM
#23
2011 34' Classic
Westchester Cty.NY
, / Miami FL
to ron h: i like my combination. the issue will be payload but if you build it light you'll end up with about 1800 lbs. of payload. it works for me because i ride solo and all i have in the bed are my hoses.
Ricky
03-23-2014, 08:50 PM
#24
1984 34' International
Toronto
, Ontario
Didn't I read somewhere that the max payload for the new 150s is about 3400lbs?
03-23-2014, 09:17 PM
#25
2011 34' Classic
Westchester Cty.NY
, / Miami FL
that might be with the longest wheel base.
Ricky
03-24-2014, 11:32 AM
#26
Ottawa
, ON
It would do fine. I would be sure of having both a WD hitch as well as the anti-sway component, though.
“Courage is being scared to death, but saddling up anyway.” ...John Wayne...........................
03-24-2014, 03:18 PM
#27
2020 30' Classic
Derwood
, Maryland
Yes - you would have read wrong as those are more akin to Heavy Duty \ Super Duty numbers.
Custom ordered Stripped down, 2 wheel drive with 2 doors and short wheel base and max payload package = 2,800 tops....
John "JFScheck" Scheck
2020 30’ Airstream Classic
**I Love U.S.A.**
03-24-2014, 03:32 PM
#28
1960 33' Custom
Athens
, Georgia
there's a couple with over 3000 lbs payload
Regular Cab 4x2 145" 5.0L V8 8200‡ 3120
03-24-2014, 03:41 PM
#29
2006 25' Safari
St. Augustine
It's all about the payload capacity and a 1/2 ton. 1930 lbs is the top for the supercrew with the regular wheelbase. That is my future goal. The new ones may be better as they shed the weight.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
03-24-2014, 04:07 PM
#30
Toronto
, Ontario
Pretty sure it was advertised as above 3000lbs - it was an ad right here on this forum. I remember it because it was surprising. If it comes up again I'll make sure to capture a screen shot.
Edit: Just checked at the Ford website. 2330 for a 4x4 super crew cab, 3100lbs for the regular cab 145 ecoboost.
http://www.ford.ca/trucks/f150/specifications/payload/
03-24-2014, 04:19 PM
#31
1994 30' Excella
Mississauga
, Ontario
since the new aluminum body weighs 750 lbs less that should translate into that much extra payload if everything else remains the same. And my 2011 ecoboost supercab with 8 foot box has a 2740lb payload so 3400lb could be right.
Al
Al and Jean
TAC ON-3
03-25-2014, 05:20 AM
#32
2020 30' Classic
Derwood
, Maryland
I guess it makes sense, sorry guys - Good Math!
**I Love U.S.A.**
03-29-2014, 11:39 PM
#33
1970 29' Ambassador
1957 26' Overlander
Ashland
, Oregon
Thank you aage, I have the wd, and use a sway bar on one side .
It's a bit lacking in power, but gets me there.
