Old 11-15-2006, 10:19 PM   #1
shinybean's Avatar
1964 22' Safari
1969 25' Tradewind
Greenville , South Carolina
Question Towing a '69 Tradewind-Dakota?
Hi,
I am looking at a 1969 Tradewind 25'. My question is, can this be towed with a Dodge Dakota? The stats from the Dodge site for my model year (2003) are:
2003 dodge dakota BASE, REGULAR CAB, 2WD, 6.5 Ft Bed, Four-Speed Automatic Transmission with Overdrive, 3.9-liter Magnum(R) SMPI V6 Engine:
With 3:55 Rear Axle Ratio Axle Ratio [i] You Can Tow 4850 lbs Gross Vehicle Weight Rating (GVWR) [i] = 5000 lbs
Payload [i] = 1200 lbs
Curb Weight [i] = 3800 lbs
Curb Weight Front/Rear = 2223 lbs/2223 lbs
GAWR Front/Rear [i] = 3100 lbs/3106 lbs
Gross Combination Weight Rating (GCWR) [i] = 8800 lbs
If I'm not mistaken, the dry weight of the '69 Tradewind is around 4300 lbs?. Barely within the maximum capacity of the truck at 4850 lbs. Will the truck even remotely tow this AS? Unfortunately, getting a new TV is not an option right now. Any advice would be appreciated. Thanks!
PS. I will have a weight distribution hitch - not sure of the brand or type. It's coming with the AS.
shinybean is offline   Reply With Quote
Old 11-15-2006, 10:26 PM   #2
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 101
It wouldn't be my first choice... You will be underpowered. When you calculate the GVW you have to include the people and stuff in the truck.
But if the trailer is a peach and you love it, a new tow vehicle might be arranged in the future. Airstreams last a looooong time - tow vehicles come and go.
1964 Globetrotter | 2023 Nissan Armada
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 11-15-2006, 10:31 PM   #3
Janet H's Avatar
1964 26' Overlander
OlyPen , Washington
Images: 101
1969 tradewind: 4340 lbs, hitch weight 490lbs
Old 11-15-2006, 11:10 PM   #4
Frank S
peoria , Illinois
Hi shinybean--Your loaded ready for the road weight will be about 5300lbs. You really need at least a 1/2 ton with a 5.3ltr, and a 3.73 rear (4.10 rear is best). If you tow your A/S with the Dakota, it will lug down at every grade, and the heavier A/S tail will wag the dog Dakota. You won't like it.--Frank S
Frank S is offline   Reply With Quote
Old 11-16-2006, 04:01 PM   #5
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
The numbers do not always tell you the true story:
If you take the GCWR (8800 lbs) - Curb Weight (3800 lbs) = GVWR (5000 lbs)
That 5000 lbs includes everything in the truck (people, pets, fuel etc) and the weight of the trailer. Subtract everything in the truck from the 5000 lbs and that is the true safe tow limit.
Richard
Question about my 2000 Dodge Dakota kentlundy Tow Vehicles 16 09-02-2008 09:12 PM
Towing Experience app Tow Vehicles 9 04-19-2004 09:51 PM
Towing Regulations by State InsideOut Towing, Tow Vehicles & Hitches 2 09-16-2002 07:35 AM
Oddball '62 Tradewind? Mark in Modesto Airstream Motorhome Forums 0 09-08-2002 08:52 PM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
