Old 07-11-2009, 03:37 PM   #1
2008 22' Safari
Greenville , North Carolina
Towing
Does anyone have experience or advice on towing a 22' Safari Sport with a Jeep Cherokee Classic? THe data says it will work but we are concerned it's right on the edge.
rathcoolej is offline   Reply With Quote
Old 07-11-2009, 04:04 PM   #2
2008 25' Safari
Jasper , Georgia
What is the tow rating of a Jeep Cherokee Classic? Is that the Cherokee model Jeep made before the current Grand Cherokee? If it's one of those old ones, I don't think that I have ever seen one towing anything larger than a U-Haul trailer.
Check out Andy's thread on Towing Myths for some good information about
towing capacities.
My advice would be to get a larger tow vehicle if possible.
Check the Tow Vehicle section of the forum classifieds. There might be something
on there you could use.
Paul & Dee
Paul&Dee is offline   Reply With Quote
Old 07-11-2009, 05:41 PM   #3
2008 22' Safari
The official towing capacity for the jeep is 5,000lb the dealer spec sheet for the trailer GVWR is 4,000lb which is why we are asking the question.
Old 07-11-2009, 06:08 PM   #4
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
I have towed m 16 ft trailer with my tractor on it and it was a scary ride. I have seen them pulling 20' trailers but you will need some trailer brakes. I don't have them on mine.
My trailer and tractor probably come in at 4000 lbs. It was at the edge. Mine is a 1990 with the 4.0 v6.
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 07-12-2009, 02:48 PM   #5
The handy accountant
pageclot's Avatar
1976 27' Overlander
Scarborough , Ontario
Images: 21
If the towing capacity is 1000 lb more than the GVWR, you should be ok. The GVWR is the maximum weight of the trailer, so you have 1000 pounds in reserve, which is far from being on the edge of safety.
Ensure you have proper weight distribution hitch, anti-sway devices, an integrated brake controller biased towards having the trailer brakes coming on first, and if the Cherokee seems a bit squirmy, consider installing tires with stiffer sidewalls. Airstreams usually have trailer brakes, and they should be kept in good repair because they may save you on some long downhills (where you are, that would be normal driving, right?).
When on long descents, gear down so the engine is doing most of the braking, and you're not overusing the brakes.
You should be fine. Enjoy!
_____
Kevin and Leah
Accountants who tow sans regret
"I nostri cuori e le menti appartengono al flusso d'aria"
pageclot is offline   Reply With Quote
MPG difference between towing and not-towing? yiesyisyeno Tow Vehicles 11 09-01-2008 02:35 PM
Help with Towing CAAR Hitches, Couplers & Balls 3 07-18-2006 02:42 AM
Towing..? phibbs All Argosy Trailers 6 10-19-2005 01:44 PM
Towing - 1965 65trotter 1965 - 1969 Globetrotter 9 08-10-2003 09:19 AM
Good towing/Bad towing! ViewRVs Hitches, Couplers & Balls 5 03-09-2003 07:37 PM
