Closed Thread
Old 01-23-2009, 04:29 PM   #71
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Originally Posted by Jimandrod View Post
The 25' and the 28' Flying Cloud / Safaris both weigh in at a GWVR of 7300# - it's pretty safe to compare the two interchangeably. Any differences as to how they feel behind a TV would probably be negligible .
Another point you raised that I've wondered about is when you said "It's possible a 1/2 ton Brand A could be superior in some or many regards to a 3/4 ton Brand B." It makes me wonder how the 1/2 ton Brand A (Tundra) stacks up to the 3/4 ton Brand B (F-250). I'd love to know how the Tundra would perform (compared to the 250) hauling our 28' Safari through the Rockies.
All in all we're very pleased with the new F-250. It's towing capabilities are amazing!
The difference between the 25' and the 28' depends on which 25'. Tongue wt. on the 25 FB is 720#, 25 is 860#, 25 SS 750#, 28, 830#. That was important to me because of the limits on payload for the Tundra. GVWR for the 25 FB, 25 SS and 28 are all 7,300# and the 25 is 7,000#. Of course we never fill our FB to the brim, or think we don't. I tend to agree there's not much difference, but tongue wt. on the 28' is about 15% more than the 25 FB, and maybe that does make a difference. Another variable is how much each person loads into their trailer.
Glad to hear your combo works for you.
Gene
Gene is offline
Old 01-23-2009, 04:43 PM   #72
nasons's Avatar
1991 34' Limited
Riverhead , New York
tundra
hi and wlcome.. i have 2007 tundra and tow 31ft excella it is the best tv. brakes are the best of any truck..tranny the best ..payload 1495 not 1/2 ton 3/4 ton..you can drive it all day long and never mget tired..if you have a crew max like i do up-grade the tires. this truck turns the mountains into prairie.
nasons is offline
Old 01-23-2009, 06:19 PM   #73
Jimandrod's Avatar
2008 28' Safari SE
Placitas , New Mexico
Originally Posted by CrawfordGene View Post
...and we Toyota owners generally boast of reliability (with a few recent and notable exceptions)....Gene
Gene - as I mentioned in a previous post, IMHO the Toyota cars that I've had have been the best that I've ever driven or owned. What are the notable exceptions that you're speaking of???
Jim & Rod
Air 10899 since 1/06
WBCCI 2484
Jimandrod is offline
Old 01-23-2009, 08:15 PM   #74
Master of Universe
Gene's Avatar
Jim & Rod, what I meant was not that recent Toyotas were bad, but two people who have posted here recently state they had bad experiences with Toyotas. Sorry for the vagueness in language.
Of course, the early V-6 engines in the '90's had problems and many people got new engines. That's the biggest problem I can remember. When Toyota has a recall, it's so rare it becomes big news. More and more manufacturers are adopting Toyota's system of QC, so the room at the top of reliability is becoming crowded. Generally all manufacturers are much better than they used to be and we can thank Toyota for leading the way. Now if Airstream could adopt the same QC methods, wouldn't that be great?
Gene
Gene is offline
Old 01-23-2009, 11:06 PM   #75
**** , California
Ahhh I knew I had it somewhere... bury'ed in the computers vast memory... sometime back someone did a study... on vehicle lengths (trailers) to wheel bases. I.e short wheelbase and the vehicle becomes unstable... Longer wheel bases and the stability returns... They did a mathmatical analysis of which length should be used for what lengths of trailers... and here it is... of course you also have to take into account the weight of the vehicle vs the towed vehicle... but they went with just the wheel base lengths paramiters because most that have longer wheelbases also have higher vehicle weights which then require also heaver breaks and running gear also... .
Check it out.... and see if you agree.
For the first 110" of wheelbase, this allows you 20' of trailer.
For each additional 4" of wheelbase, this gets you 1' more of trailer.
Here is a chart: Wheelbase Length Wheelbase Length 110" 20' 150" 30' 114" 21' 154" 31' 118" 22' 158" 32' 122" 23' 162" 33' 126" 24' 166" 34' 130" 25' 170" 35' 134" 26' 174" 36' 138" 27' 178" 37' 142" 28' 182" 38' 146" 29' 186" 39' (This guideline was first used by the RV Consumers FHSA and NTSB Group)
GMAs is offline
Old 01-23-2009, 11:09 PM   #76
**** , California
Sorry but I couldn't get the chart to print out in collums... but as you can see the WB relates to the Trailer lenght by picking through it.
GMAs is offline
Old 01-24-2009, 09:20 AM   #77
Master of Universe
Gene's Avatar
GMAs,
Thanks for confirming with the wheelbase chart that Tundras can pull long trailers. The double cab or crew cab short bed is 145.7"=26'. The double cab long bed is 164.6=33.5'.
Gene
Gene is offline
Old 01-24-2009, 12:57 PM   #78
**** , California
Your Welcome... oh by the way.... did I mention that the WB chart was only done for US manufactured Vehicles ONLY.. back then. (guess who participated in the study.. yep good old AS at the research facality set up by the Fed DOT, FHWA At the time it was done most Toys and Dats and Splats.. were still built over in Japan...
Just to clairify it a little... but I would think even today it might hold out true... except for the fact that OURS is probably now being used as parts for some mexicans tractor down in Baja... or who knows... they may have recycled it into your new truck fraim. Just think.. you may be driving around on my old steel... Now thats fitting and conforting to know. (smile)
GMAs is offline
Old 01-24-2009, 01:18 PM   #79
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
So Libo, ain't 'ya glad 'ya started this thread?Hope you're enjoying your new Airstream
We all have good intentions, really we do.
Hey 'fella's this thread ended at post #25
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
“It’s a crooked piece of time that we live in….”
John Prine
ROBERT CROSS is offline
Old 01-24-2009, 02:04 PM   #80
Jimandrod's Avatar
2008 28' Safari SE
Originally Posted by Libo View Post
OK, it's official. Before I even got a chance to read all of your posts we had made a deal on a 28' Safari. So, I guess I will be your test case. I will be towing a 28' with a Toyota Tundra 5.7 V8. I guess my next step is to look in to this famous hitch system everyone is talking about, Hensley. I want to outfit my truck ASAP so that I can pick up my new Airstream. Thanks for all your replies. Lia & Bob
Congratulations! Welcome to the world of Airstreaming! You'll love it.
The 28' Safari is the best layout in the line - but that's my personal bias. We're thrilled with ours.
Let us know how the Tundra goes and make sure you post lots of pictures.
Jim & Rod
WBCCI 2484
Closed Thread
Towing: Tundra vs Sequoia vs Land Cruiser walter1 Tow Vehicles 47 05-29-2014 09:15 PM
2008 Tundra Cruise Control while towing Ray Eklund Tow Vehicles 3 10-16-2008 07:57 PM
Tundra towing 23' vs 25' cyafishin 2006 - 2010 International 18 07-04-2008 06:45 AM
Will my TV work towing a 28' 1968 Ambassador hazhoni Tow Vehicles 8 08-25-2006 01:33 PM
Towing with a Tundra JimC Tow Vehicles 37 08-03-2003 09:00 PM
