Old 10-14-2007, 08:22 AM   #1
Silver Threads
Commercial Vendor
Silver Threads's Avatar
Profile:  1966 24' Tradewind
Kingston , Tennessee
Towing a 27' Overlander with a Jeep Liberty
Hello,
There is a man buying our 1972 Overlander and he plans on towing it with a Jeep Liberty. I am not familiar with the Jeep, but I am thinking that it is not a good idea. Can somebody give me some info to give to this guy? He thinks because it has a 5000 lb towing capacity that it will be suitable to tow the Overlander.
John and Tammy Adams
AIR # 15902
Visit our websites, http://www.freewebs.com/silver-threads/
http://restoringour66tradewind.blogspot.com/
Silver Threads is offline   Reply With Quote
Old 10-14-2007, 08:32 AM   #2
RUSSELL
Desert Fox
Profile:  1985 31' Sovereign
Tucson , Arizona
Thumbs up Hi
As far as I am conserned anything will pull the trailer. The only problem is contorl of the trailer. It will be pushing the jeep around. I can pull my AS with a 1952 jeep but towing it or controling ir is another story. What is he going to do up hill or worse going down hill.
Regards from Russell in sunny Tucson Az.
RUSSELL is offline   Reply With Quote
Old 10-14-2007, 08:39 AM   #3
centennialman
centennialman's Avatar
Profile:  1966 22' Safari
Centennial , Colorado
I own a truck and a Jeep Liberty. I would never consider towing my A/S with the Jeep though. It has enough power to pull the trailer, but, if there was a situation where we would need to stop quickly or if we were coming downhill etc....I would not feel safe. The trailer would be "pushing" the Liberty and we could lose control easily.
It's better to be safe than sorry.
Just my opinion.
Steve
centennialman is offline   Reply With Quote
Old 10-14-2007, 09:08 AM   #4
Ike T
Slackdaddy
Ike T's Avatar
Profile:  1976 Argosy 24
Marietta , Georgia
Not safe
Here's my reasoning why it's a bad idea:
  • Liberty wheelbase is only 104 inches. Very short and unstable.
  • Liberty weight is around 4000 lbs. Doesn't the Overlander weigh more? Talk about the cart bossing the horse.
  • Probably has the 3.7 L engine with automatic transmission. Does the truck really have the cooling capacity for the load?
  • Look at this link on the Jeep website. Jeep - 2008 Liberty - Capability - Performance - SUV - Sport Utility Vehicle Click on the towing link. What do they show? A basecamp, not a 27' trailer.
Show him some photos of what happens when well-matched vehicles and trailers get into extreme situations. Mention how he will be in an extreme situation before he ever starts moving with that combination. Perhaps you could allow him to drive your vehicle a short distance to understand the difference between a Suburban and a Liberty.
If you do sell, I would not let him tow the vehicle off my property with the Liberty. Exchange at a neutral site and walk away.
Just my thoughts.
Falluminum -- Can Opener
1976 24' Argosy
1973 International Travelall 1010
1973 International Travelette 1210 4x4 'Bernard' 164" WB
"Who, that little guy? I wouldn't worry about that little guy."
Ike T is offline   Reply With Quote
Old 10-14-2007, 10:22 AM   #5
Foureagles
Full-timer
Profile:  1971 27' Overlander
above Shavano (pop. 0) , Colorado
I agree that a Liberty is overmatched in trying to safely handle a 27' trailer. I tow my 27-footer with an old full-size body-on-frame Wagoneer. While it's heavily modified for strength, power, braking & handling to deal with even larger loads, it still has a 'mere" 109-inch wheelbase and weighs "only" 5,000 lb, and that means I have to be on my toes at all times.
He could probably get the trailer home at 30 MPH if he lives very close by, but that rig should not be considered for highway use. Did you by chance catch that e-bay item where the guy flipped a 27-footer while trying to tow with an ExTerra? Sounds like a repeat performance in the works here. I missed that auction, so I'd appreciate it if you tell the guy that, if he does crash it, I'll give him 500 bucks for it.
"Don't confuse symmetry with balance". Tom Robbins
Foureagles is offline   Reply With Quote
Old 10-14-2007, 11:21 AM   #6
AlbertF
Profile:  1975 27' Overlander
In the Kootenays , BC
Click on this link for a relevant and interesting thread.
Woodalls Open Roads Forum: Towing with our 2006 Jeep Liberty CRD (turbodiesel)
AlbertF is offline   Reply With Quote
Old 10-14-2007, 11:38 AM   #7
Silver Threads
Commercial Vendor
Thanks for all the great replies. I am going to talk with the guy today, I will let you know what he decides!
AIR # 15902
Old 10-14-2007, 11:51 AM   #8
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
I've got a friend who tows a large popup with a similar size 6-cylinder Toyota Highlander. He hate hills, wind and so much more. He feels his Highlander struggle and think's he's at the max of what it can handle. And guess what? It has a 5000 tow capacity too!
Tow capacity is the most Madison Avenue spec on any TV. It's usually quite inflated, very subjective --- and on top of all that, good safe towing occurs in a range where you don't exceed 80-85% of any spec: payload (load) capacity, tow capacity, GCWR.
This was mentioned before: Glad no one hurt- ebay post
Old 10-14-2007, 11:57 AM   #9
Wayward
Wayward's Avatar
Cary , North Carolina
If I recall the thread on that flipped rig, it was not a TV issue, the guy was towing at interstate speeds with only one sway/WD arm (the other had snapped).
It is certainly possible with a good driver and properly set up WD/swaybars - but there are too many variables to get a consensus on this Forum for the guy towing a 27' with the Liberty.
It is quite possible however that your question has all the elements needed to start another long lively TV debate. And The Answer issssssssssssss - get a 3/4 ton diesel.
2006 Safari SE FB
2000 F150 4.2L
Raleigh, NC
Old 10-14-2007, 11:58 AM   #10
Road Ruler
Road Ruler's Avatar
Profile:  1973 23' Safari
Burlington , South Western Ontario
Images: 41
AlbertF.. The link you provided is an eye opener.
It goes to show that that there is a lot more to the "science of towing" and "tow vehicle analysis", than the tow rating, the wheel base, and dated rule of thumb number crunching.
Road Ruler is online now   Reply With Quote
Old 10-14-2007, 01:22 PM   #11
Silver Threads
Commercial Vendor
Ok, I talked to the guy. I let him know about all the info, and my concerns. He and his son are now going to pick up the camper in his son's dodge 3500 to take it home. He will use this til he finds a more suitable tow vehicle. Again thanks to all for the great advice and information.
AIR # 15902
Old 10-14-2007, 06:25 PM   #12
ROBERT CROSS
"The Frantic Banana"
ROBERT CROSS's Avatar
Profile:  2003 25' Classic
W.N.Y. , "
Images: 41
Thumbs down Is He Kidding!!
[quote=Silver Threads]Hello,
Thanks[/quote
HAVE HIM SIGN A RELEASE.....get it notorized
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
ROBERT CROSS is online now   Reply With Quote
Jeep Liberty towing question.. safari05-25 Tow Vehicles 20 07-22-2006 09:20 PM
Diesel Jeep Liberty and `61 Tradewind henrydahm Tow Vehicles 14 07-17-2006 06:56 AM
Towing with a Jeep Figaro Tow Vehicles 14 02-13-2006 06:56 AM
Towing a Jeep LKappenman General Motorhome Topics 4 09-19-2003 08:33 PM
Towing with a Jeep? Roger and Nancy Tow Vehicles 11 08-19-2003 09:47 AM
