Old 07-16-2015, 08:43 AM   #15
bono's Avatar
Mountain View , California
The coding can be done by anybody having the software. Just like coding the lights to EU standard or other features. My coding was done by somebody from Europe - 5 minutes. BMW will tell you that it is complicated, time consuming process. It is not - they should complete installation of the hitch, electric harness and coding in 2.5 hours TOTAL. This is official BMW bulletin.
bono is offline   Reply With Quote
Old 07-16-2015, 09:51 AM   #16
martinez , California
Thank you all for the great info! I will be calling Can am to chat about options and see what they have to day as well. Ill report back soon!
jackvosney is offline   Reply With Quote
Old 07-16-2015, 10:08 AM   #17
txdxrider's Avatar
1976 31' Excella 500
Providence Village , Texas
I understand your position, however I have seen many fried transmissions from not being reprogrammed... It's not complicated - plug into the system - could take 10 min, could take 10 hours - depends on dealer connection to BMW and updates needed for the vehicle....
Let's party with Pirates and Ninja's.....
txdxrider is offline   Reply With Quote
Old 07-16-2015, 10:52 AM   #18
wavelength's Avatar
1999 25' Excella
Western Springs , Illinois
Towing with BMW X5
The main problem with towing with the BMW is the wheel base, it's to short You will find serious control issues when being passed by a semi or in high winds. I towed a 1999 25 ft excella with a Toyota 4Runner and had major control issues. Traded it on a Toyota Tundra and all my issues were resolved
wavelength is offline   Reply With Quote
Old 07-16-2015, 10:54 AM   #19
bono's Avatar
There is no other program to operate the vehicle when they are "reprogramming" the car for the hitch. If you have any other details (apart from what you can hear at dealership), I would be happy to hear.
No sure about other X5, but X5 35d 2011 has the transmission cooler which is operating regardless of the hitch. The newer model F15 35d is just rebadged 30d, so I do not know if it has the transmission cooler.
Old 07-16-2015, 12:15 PM   #20
txdxrider's Avatar
Bono, I worked for BMW for over 10 years, and I am quite knowledgeable on my this.... There are 7 computer modules in the BMW that handle different functions. Can you add a hitch/wiring harness and go- yes - however- the X5 needs to be programmed to recognize the hitch. Basically when the trailer is hooked up and the harness plugged in - the X5 will adjust the shifting and holding patterns of the transmission for towing (similar to the tow/haul mode on pick ups and other SUV's)...
Without the vehicle being programmed the shift patterns will be the same whether towing or not-placing undue wear and tear on the transmission.
As for the original poster.... While you may be fine running with your current set up/not reprogramming, he may not be.... I posted this out there for his benefit, so he can make the best educated decision for himself.
Old 07-16-2015, 12:18 PM   #21
jcl
Vancouver , British Columbia
I have installed the OE hitch and wiring kits and two BMW X models (but not an X5d). In both cases, the OE wiring module in the hitch kit pluged into an existing harness in the rear of the vehicle. It interfaced with the vehicle LCM (lighting control module) since BMW wiring is multiplexed, and is not a straight 12 v for lighting circuits. The module takes a signal from the LCM, and outputs power for the connecting harness to the trailer.
The only coding that was ever required was to enable the vehicle to recognize that the wiring module has been plugged in. On earlier X5 models it was 'plug and play' but later models, with more variety of options, became sufficiently complicated that the module often wasn't recognized by the vehicle, and so coding to tell the vehicle that it was now installed (just tick it off on the inventory list) was necessary. If the coding wasn't done, the lights didn't function properly.
Once the vehicle knows the trailer wiring module is installed, and a trailer is plugged in (automatically sensed), it can utilize the existing Trailer Stability Control (TSC) routine in the vehicle Dynamic Stability Control (DSC), it turns off the rear park distance sensors to prevent continual beeping when in reverse, and it can change the rear camera settings on some models. That is pretty much it. It didn't change the transmission shift settings, or anything else.
Now, the X5D under discussion may be different than all the other X5 models, but I checked the factory training documents for the E70 release, and they do not describe any transmission changes with a trailer wiring module. In fact, the E70 transmission got a new pressure setting to accommodate backing a heavy trailer up a hill, applicable to all models. Similarly, the workshop manuals don't note that the programming changes any settings AFAIK, but they are notoriously difficult to search, so there may be something in there.
If there is documentation on changes to transmission or suspension programming when towing I would like to see it, it would be interesting.
All X5 models have transmission coolers, etc. The hitch kit is simply a receiver hitch, and an interface module for the trailer wiring. Bracing by third parties to better accommodate WD equipment is optional, and is not acknowledged by BMW. That is it. And it tows beautifully, partly due to the good handling engineered into the vehicle.
Jeff
jcl is online now   Reply With Quote
Old 07-16-2015, 01:06 PM   #22
txdxrider's Avatar
Jeff
Jeff, you are correct in the DSC, and option changes, as well as the older (E70) plug-n-play status. In addition the vehicle applies more rear brakes when the trailer is attached versus the standard bias.
Unfortunately I retired from BMW 6 mo's ago and no longer have access to the programming specs.
Old 07-16-2015, 01:14 PM   #23
Road Ruler's Avatar
Images: 38
It is absurd to compare one of the poorest rated TV's a Toy 4 Runner to one of the top rated TV's an X5.
Old 07-16-2015, 03:35 PM   #24
gpt
2014 25' FB Flying Cloud
sequim , Washington
i think all the poster was stating was that the wheel base could be an issue, shorter is not always a great idea no matter the badging on the TV.
gpt is offline   Reply With Quote
Old 07-16-2015, 03:56 PM   #25
2015 25' Flying Cloud
2012 19' Flying Cloud
Stillwater , Minnesota
Since my earlier real world posts are already referenced above, I'll only reiterate here that the 2015 25RB tows wonderfully behind the 2012 X5d. Great combo. Solid as can be thanks to both hitch reinforcement at Can-Am and a WD hitch that nicely accommodates the 7000 loaded AS with 800 pounds on the ball.
PM me if you've any questions. Happy to discuss in detail.
Rod
StillRod is offline   Reply With Quote
Old 07-16-2015, 05:03 PM   #26
bono's Avatar
Regardless of what kind of changes are applied to the car by coding, here is the manual for E70 including instruction re coding. Again, coding can be done by any independent coder. There is nothing magical about this, apart from changing a couple of selections. There is no new engine / transmission program downloaded from BMW servers in relation to hitch coding. This was discussed a few times over BMW forums.
https://www.bavauto.com/Assets/inst_pages/ins370.pdf
Old 07-16-2015, 05:14 PM   #27
2014 27' FB Classic
Cassopolis , Michigan
I learned the hard way towing with a BMW X5 that a trifle too much weight over the rating can bend the undercarriage where the hitch attaches. Unlike American engineers, Germans seem to design pretty close to the rating.
I suggest you find a better tow vehicle, preferably Ford, GM or Ram.
biyak269 is offline   Reply With Quote
Old 07-16-2015, 05:28 PM   #28
bono's Avatar
Interesting, please could you elaborate? What was the weight of the trailer, tongue weight? Did you use weight distribution system? Do you have any photos of the bent?
It appears that there are a couple of X5 owners towing up to 8000 lbs, 1000 lbs tongue weight.
BMW x-5 2012 towing mirror jim huebner Towing, Tow Vehicles & Hitches 8 07-22-2012 04:44 PM
Anyone towing 5,000 lbs with a V8 BMW X5? adwriter73 Tow Vehicles 20 06-17-2010 01:14 AM
Interesting article Re BMW X5 & Towing Road Ruler Tow Vehicles 10 03-15-2009 09:47 AM
Bmw Towing Capacity Please Help ACHALAT Tow Vehicles 4 02-03-2006 06:42 AM
