Old 09-11-2005, 05:57 PM   #1
hiker
hiker's Avatar
Profile:  2007 25' International CCD FB
Needham , Massachusetts
Thumbs up Towing 19' Bambi with 2005 Tacoma
We will be buying a 2006 19' SE Bambi Safari LS and are considering options for a TV. We like the 2005 Toyota Tacoma 4x4 long bed double cab but need advice about whether it will comfortably tow the Bambi. The 2005 Tacoma is a 4.0L V6 with nearly the towing capacity of the Tundra. Curb wgt is 4100, Wheelbase 140.9, GVWR 5450, Towing Capacity 6500, GCWR 11,1000, tongue load 650. Do you think, based on the above specs, the Tacoma will do the job? We also would appreciate hearing from 19' Bambi owners about what you use for TVs and how satisfied you are, and whether any of you are towing with a 2005 Tacoma.
hiker is offline   Reply With Quote
Old 09-11-2005, 06:54 PM   #2
SilverRanger
SilverRanger's Avatar
Profile:  2005 19' Safari
1968 24' Tradewind
Milton , Delaware
I use a 1997 Chevy pickup, 5.0L V8 4WD, automatic transmission w/OD, to tow my 05 Bambi. Today I was on a flat road doing 55 MPH with the cruise control on, and the tach was slightly under 1500 RPM. It tows like a dream. It pulls easier than my 5' X 10' utility trailer when it's fairly loaded up.
SilverRanger is offline   Reply With Quote
Old 09-11-2005, 06:59 PM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
SilverRanger,
Wouldn't that be either a 4.8 or a 5.3 V8?
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 09-11-2005, 09:10 PM   #4
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
Hiker...the Tacoma will do it. IMHO, I'd feel better with a V8, but as long as you're not going to take it up the Rockies, I think it will do just fine. The Bambi is rated at about 5000lbs, so you have a bit of wiggle room IMHO, but as for wheelbase, 140 inches is more than enough for a 19' Bambi.
Old 09-12-2005, 01:59 AM   #5
SilverRanger
1968 24' Tradewind
Milton , Delaware
Originally Posted by davidz71
SilverRanger,
It's a 5.0L/305ci 230HP. I believe it was either the 5.0L or the 5.7L V8 up through 1999.
Old 09-13-2005, 08:02 PM   #6
hiker
hiker's Avatar
Thanks Silvertwinkie and SilverRanger. Based on your comments, we decided to look at Chevy pickups because we do want to tow our 19' Bambi through the Rockies. We test drove the 2500HD Duramax and really liked it. The Duramax is more than required to tow a Bambi, but we plan to keep the TV for 10 or more years so we should be able to recoup the diesels' higher up front cost. It's sobering to think about buying a TV that could outlast us.
Old 10-01-2005, 08:03 PM   #7
Barkingdogg
Barkingdogg's Avatar
Profile:  1967 17' Caravel
Newcastle , Oklahoma
towing bambi
Hi,
I have pullde my 67 Caravel through CO. NM, & MO from OK. with a 4.6 V8 Ford 150 with ease.
Barkingdogg
Barkingdogg is offline   Reply With Quote
Old 10-01-2005, 08:35 PM   #8
Kintscher
Kintscher's Avatar
Profile:  2005 19' International CCD
Eugene , Oregon
We have a 2004 19' CCD and tow it with a 2005 Toyota Tundra Double cab V8. We made several trips from California to Oregon this summer and it towed like a dream.
Kintscher is offline   Reply With Quote
Old 10-01-2005, 09:34 PM   #9
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
SilverRanger,
Do you tow with OD on? I tow a 75 TradeWind (5000 lbs loaded) with a 2003 Tundra (4.7 V8) and I always turn OD off. It is my understanding that the automatic transmission will suffer if OD is left on while towing.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 10-01-2005, 10:11 PM   #10
ardenrj
ardenrj's Avatar
Profile:
Just got back from a 2000 mile trip from So. Cal. to Central Oregon coast. I tow my 2004 19 ' Bambi with a F150 5.4 V8 with tow package. This set up really works well. I went up and down lots of mountain passes on this trip and no problems what so ever. Going up hill 55 mph no problem power to spare. Going down hill the truck stays in control. I'd really recommend this set up after going on this trip.
ardenrj is offline   Reply With Quote
Old 10-02-2005, 07:13 AM   #11
85MH325
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Originally Posted by Barkingdogg
Hi,
Barkingdogg
One of the reasons that the vintage Caravels are so popular is that they're HALF the weight of the similar new models!
I think that the choice of going to the full-size pickup for a 19' Airstream is wise. There's a lot more to towing than just dragging the trailer around. Your tow vehicle must be able to stop and maneuver the trailer in adverse conditions as well. The heavier the tow vehicle in relation to the trailer, the better off you'll be. The longer the tow vehicle's wheelbase, the better off you are towing, but wheelbase also limits your ability to back into tight spots.
The new Tacomas are heavier and bigger than their older siblings, but I think you'll be much happier with a full-size pickup pulling a 19'.
Roger
AIR 2053 “A generation which ignores history has no past and no future.” Robert Heinlein
2006 Bigfoot 25B25RQ towed by a 2001 Born Free 23RK moho
Old 10-02-2005, 07:49 AM   #12
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs , Florida
Images: 36
hiker, you will love the Duramax! I have had mine for 2 years, and 32,000 miles. No problems at all, just been to the dealer once, for tailgate straps recall. Nice to have an alternative fuel vehicle, too. Who knows what the future will bring? When gas stations run out of gas, the usually still have diesel, as it is not in demand as much.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-02-2005, 07:31 PM   #13
Barkingdogg
Roger
Oh I agree,
I would not want to pull the 2400 lb Caravel with any thing less than the F150 or engine smaller than the 4.6 liter (v-8). I think this is a full size PU.
Barkingdogg
Old 10-03-2005, 12:37 AM   #14
SilverRanger
1968 24' Tradewind
Milton , Delaware
Originally Posted by azflycaster
SilverRanger,
I tow with the OD on only when on relatively flat terrain. I could be wrong, and don't proclaim to have any expertise in towing, but it's been my understanding that it's okay unless the transmission is downshifting frequently. I just took a 2,500 mile trip and the engine rarely revved over 2,000 RPM unless accelerating on a hill. I stayed under 60 MPH most of the time and never had a problem.
1961 - 1963 Bambi Serial Number Guide Andy R 1961 - 1963 Bambi 35 07-27-2008 10:38 PM
Towing Experience app Towing, Tow Vehicles & Hitches 9 04-19-2004 09:51 PM
Newbie AS Bambi Owner! KY Girl Our Community 12 10-27-2002 09:06 PM
Towing cars CBBOB Airstream Motorhome Forums 13 07-24-2002 08:15 PM
Bambi II is a Caravel... VintageRV 1964 Bambi II 0 02-24-2002 07:55 PM
