Old 10-12-2014, 08:41 AM   #15
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Originally Posted by Ahab View Post
Your fine, as the posters above are recommending. Don't listen to morons.
LOL, brilliant.
MICHAEL
Old 10-12-2014, 11:29 PM   #16
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Tow Vehicle Woes
More than capable for the task, brakes are more than good enough too.
Period.
Trailer brakes are pretty reliable, a simple rule regarding them is to test them every time you start driving, and if they don't work, stop and fix them.
Even so, I haven't seen a vehicle made in the last few decades that was not capable of locking every tire down under any condition. If you were to lose trailer brakes, the limiting factor is not going to be lack of brakes, but lack of traction.
In this regard your Tahoe is as good as any 3/4 ton truck and many one ton trucks.
Old 10-13-2014, 04:13 AM   #17
Wayward's Avatar
Cary , North Carolina
enjoy - no worries
Plenty of truck!
I tow a 25' FB with a old 1/2 ton. It has a 4.2L V6 which requires use of 3rd gear in the mountains.
It was a stock truck when we bought the Airstream. I put on a good brake controller then towed for a while to see how it did. Ended up adding larger diameter load E range tires. Then changed the rear axle gear to 4.30 and put on Monroe sense-matic shocks.
The rear gear change was a huge improvement.
It runs Redline synthetic lubricants.
I also tow it with a 3/4 ton truck which has a bigger motor but is definitely a bit more truck than the Airstream needs.
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
Can you tow a 31' with 12 a bhp tow vehicle? goatfarmer Member Introductions 6 06-30-2010 10:40 PM
Tow, tow tow your Airstream Hhthorny Towing, Tow Vehicles & Hitches 11 04-12-2008 12:06 AM
Armstrong A/C Woes on 71Sovereign MikeT Furnaces, Heaters, Fireplaces & Air Conditioning 1 06-14-2002 12:09 PM
