Old 01-28-2011, 12:14 PM   #15
1972 21' Globetrotter
nc , North Carolina
Originally Posted by r carl View Post
Try 3- 6x2x1/8 rectangle tubes the full length of the trailer from coupler to bumper with 5x2 tube under the frame above the axles to spread out the load. Its a frame that wont sag and it supports the walls. The ends of all the tubes have plates welded on to keep out critters or whatever.
your right rcarl, it is 6x2 and 5x2, very strong. i forget without looking a spec's thanks for update.
rock60 is offline   Reply With Quote
Old 01-28-2011, 05:48 PM   #16
lylesgl's Avatar
2007 27' Safari FB SE
Springfield , Virginia
Checkout the AirSafe hitch. I purchased one and dropped my WD bars from 1200 to 800lbs. The ride has smoothed out tremendously. No more open drawers or popped rivets inside/outside the camper.
lylesgl is offline   Reply With Quote
Old 01-28-2011, 06:37 PM   #17
2015 27' Flying Cloud
Portland , Oregon
Send a message via AIM to hhendrix Send a message via Yahoo to hhendrix
I have a 2009 27' FB Flying Cloud that I had towed with a 2001 F350. Originally I had the 1000# bars but switched to 600# bars after reading discussions here about stiff TV suspensions and potential effect on the AS. I will say that the ride with the 600# bars was much better, easier on the AS, the TV, and the occupants.
hhendrix is offline   Reply With Quote
Old 01-28-2011, 07:39 PM   #18
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
and the occupants.
Humans or critters? (Some would ask, "what's the difference...")
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 01-28-2011, 08:20 PM   #19
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
TV's
I recently assisted my friend install the Pro Pride hitch on his 31' Classic, and he tows with a one ton Dodge--SRW. ( 1K WD bars).
We rode over rough back roads, freeways, and normal street driving. We hardly knew the trailer was attached!! Ride was smooooothe!
I ordered a 3P hitch!
Zigidachs is offline   Reply With Quote
Old 01-30-2011, 04:06 AM   #20
JFScheck's Avatar
Rockville , Maryland
Images: 33
Yea - those 3P Hitch's ROCK...
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 01-30-2011, 06:59 AM   #21
SteveH's Avatar
Common Sense , Texas
And that could be part of why they weight half again as much as an Airstream and are so hard to pull.
Regards,
Steve
Old 01-30-2011, 07:07 AM   #22
nc , North Carolina
not realy, they weight about the same. i have owned a 27, 28,21, foot airstream and two 34 and two 30 ft avions. weight is close the same.
Old 01-30-2011, 07:24 AM   #23
SteveH's Avatar
Maybe not yours for whatever reason, but I traded a 22' Argosy for a 23' Avion, and it was significantly heavier, and MUCH harder to pull. My TV at the time, an '88 Suburban, pulled the Argosy easily, but I was totally dissatisfied with the way it pulled the Avion. So much, that I sold the Avion.
It was, however a nicely built trailer. If I had to live in one, I'd rather live in an Avion, but don't want to tow one.
Regards,
Steve
Old 01-30-2011, 07:38 AM   #24
r carl's Avatar
Lin , Ne
My 1985 30ft Avion has a gross dry weight of 5840lbs and a tongue weight of 630lbs and a GVWR of 8550lbs. I thought those specs were good, should I get a F450 to pull it instead of my Tahoe? My owners manual shows a car pulling it.
Old 01-30-2011, 07:52 AM   #25
SteveH's Avatar
Specs are one thing, actual weights are another. If it were mine, I'd actually weigh it to find out for sure.
Sorry, but I can't think of a nicer way to say I don't believe those specs. :-)
Regards,
Steve
Old 01-30-2011, 07:59 AM   #26
r carl's Avatar
Lin , Ne
1985 Sales Brochure
Old 01-30-2011, 08:30 AM   #27
SteveH's Avatar
Nope, I looked but I didn't see a cat scale ticket anywhere in there.
Regards,
Steve
Old 01-30-2011, 08:48 AM   #28
nc , North Carolina
r carl , the split axles and spring setup was the best setup on a trailer.
i think they done away with it in 88 or 89. i wish my 89 still had them.
i used to watch the triple axle on the 34's i had in the mirror as i rolled across some speed bumps, it was like the trailer never moved. the only advantage i see in the axle setup now days on airstream and avions is you don't have to use a jack to change a tire, that should show you something, its not the tv that beats the hell out of the trailer its the axles.
heavy tow vehicle, towing capacity
Need help to tow 31' land yacht in town (portland, or) pdx437 Our Community 4 03-06-2011 02:13 PM
Tow Vehicle, new-vs-used??? batman Tow Vehicles 26 02-10-2011 10:51 AM
what can we tow w/ older trucks? nurngen Tow Vehicles 7 01-29-2011 12:48 PM
Scion XB as tow vehichle? imbeanie Tow Vehicles 19 01-20-2011 06:49 PM
New Tow Vehicle - 2010 Dodge 2500 sgray Tow Vehicles 13 01-11-2011 07:41 AM
