Old 09-18-2006, 07:29 AM   #1
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Tow Vehicle Tires
Olivia, our primary tow vehicle, is going to need a new set of tires in the near future. Olivia is a 2005 GMC Yukon XL 2500 4x4x4 (4 wheel drive and Quadrasteer). She is runnning on her OEM tires which are Bridgestone LT245/75x16 Load Range E (10 ply). I was looking at the Bridgestone Revo which comes in a load range E and is highly recommended on the Quadrasteer Club Website. Most of the Quadrasteer guys are not towing anything heavy (like an Airstream) though. I was thinking about going to 265's, but my GMC dealer recommends against it because of the 4 wheel steering. Our TV tows the Airstream more than it doesn't.
I am looking for input from the AIR Group on TV tire experiences and suggestions.
SuEllyn & Brian McCabe
Old 09-18-2006, 08:52 AM   #2
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
look for a tire tread that has continous rubber at the outer edges instead of an open tread pattern. less tendancy to squirm and wander when you have a load on it.
i had firestone steeltex E's as my oem set that worked well and really was the first set of firestones i did not hate.
i replaced them with a set of goodyear wrangler ATD2's load range E. simlar design and good performance after 20K miles.
john
you call them ferrets, i call them weasels.
Old 09-18-2006, 01:54 PM   #3
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
We had the Firestone Steeltex tires (made in Canada) on our old Suburban, and they were very solid for years. Finally worried about the rubber and switched to Michelin LT tires, which were also good and solid, and seemed to have better wet traction...
Current Excursion has OEM Goodrich Rugged Trail T/A's in Load Range E, and they ride very hard at higher pressures, but are also doing the job... If they go, I'd probably replace with Michelins again, just because...
John McG
Condoluminum
Condoluminum is offline   Reply With Quote
Old 09-18-2006, 02:06 PM   #4
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I've got 40K on my OEM tires. When they go, they will be replaced with the same, if still available. Looks like the original set, (Bridgestone) is going to make 55, if not 60K.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-18-2006, 05:16 PM   #5
TIMEMACHINE's Avatar
Huntington Beach , California
Recommend Revos
Switched from Goodrich (can't remember model, they were OEM) to Revos last year on a Ford Expedition. Great tire, smooth, round (easy to balance), great all weather traction and long wearing. The Expy drove much better after installing the Revos, the steering was especially light and maintained a straight track on the freeway. The Michelin Cross Terrain is also a great tire, although I don't know if there is an E rated version.
John
TIMEMACHINE is offline   Reply With Quote
Old 08-14-2011, 02:33 PM   #6
AxelBruijnis's Avatar
1978 31' Sovereign
Gasselternijveen , drenthe
Send a message via AIM to AxelBruijnis
QS Tow Vehicle Tires, what did you end up buying ?
What kind of tires did you buy?
I will need a new set soon, on my 2004 quadrasteer suburban
and although i would like to have slightly bigger tires, for cosmetic reasons, I am not sure if this will improve tow-behaviour.
I currently have Michelin XLT LT245/75R16/E that came with the truck.
thanks,
Axel
1978 Sovereign 31 Mid Bath
1969 Overlander 27
2000 dodge 2500 diesel
AxelBruijnis is offline   Reply With Quote
Old 08-14-2011, 02:54 PM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
[QUOTE...... i would like to have slightly bigger tires, for cosmetic reasons, I am not sure if this will improve tow-behaviour.
thanks, Axel[/QUOTE]
Our 06 Burb was optioned at the dealer with LTX 265/75R16 M/S E.
They look a little better and have been trouble free.
POI...if you go oversize don't overlook having the PCM re-programmed for the taller tire.
DIC, (mpg readout and speedo etc.) will be more accurate.
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-14-2011, 03:06 PM   #8
1978 31' Sovereign
Robert ,
Thank you for your response,
i do have a Hypertech "Max energy" , that can modify the sub's computers for other tire sizes.
(I did get it for modifying engine management for higher octane fuel , 95 is the lowest they sell here )
Axel
1969 Overlander 27
Old 08-14-2011, 03:21 PM   #9
Axle,
You got the best programmer, been using HT products for years.
A lot of great options for towing!!
PFC
"Tahawus"
RLC
Old 08-14-2011, 04:27 PM   #10
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
I have pulled Airstreams with various tow vehicles since 1996. I really had good luck with the OEM tires that came on your Suburban. So much so, I replaced the same tires that came on my 2005 2500HD Chevy with them. I have also had great luck with Michelin Loadrange E MS, and Goodyear Wranglers.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 08-15-2011, 09:05 AM   #11
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
The latest Fourwheeler magazine has a bunch of articles on towing. One of their articles was on the Hankook MaxiVantage F19 trailer tire. It is a 14 ply G rated tire capable of 3,330 lbs at 105 psi, and I have seen these on some commercial trailers. I will seriously look at getting these tires when I replace them on my AS.
Pap
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 08-15-2011, 01:52 PM   #12
1978 31' Sovereign
Pap
i was looking for Tow vehicle tires.. not trailer tires..
About your 14 ply trailer tires.. make sure the ride of the airstream won't get to harsh , you may loose some rivets.
Axel
1969 Overlander 27
Old 08-15-2011, 07:25 PM   #13
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Please Do Not USe 14 Ply Tires on Your Airstream
Pap
The Airstream prefers a 6 ply ride
Ken L
1966 Tradewind 24
Old 08-17-2011, 08:13 PM   #14
pappy19's Avatar
Right on, sorry I didn't read the thread correctly. On my TV I personally like Michelin's E rated as they have given me the best service. As to the AS tires, I have read some more since I wrote about the 14 ply's and will stick to the recommended 6 plys. Hope this clears up my errors.
Pap
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
Sovereign weight and Preferred tow vehicle JLD 1974 - 1979 Sovereign 24 06-26-2017 10:17 PM
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 06:11 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 07:04 AM
introduction // need help deciding tow vehicle jmeredith Our Community 9 09-29-2002 05:39 PM
Towing a small 60s trailer with a SUV... Andy R Tow Vehicles 15 03-30-2002 07:57 PM
