Old 06-23-2010, 07:59 AM   #1
mandolindave's Avatar
Tow vehicle tire pressure Andy please HELP
I just bought a 2009 Chevy 2500 Van, to pull my 3000 lbs Argosy.
I am changing my 1000 lbs weight distribution bars to 600 lbs.
Tire says 80 lbs cold Max. Chevy says 50 lbs front, 80 lbs rear.
( Probably to keep up cargo rating ???)
Dealer sold it to me with 57 lbs front, 72 lbs rear. The ride is rough
AND I worry about it beating up the trailer.
I am thinking 50 lbs front, 62 pounds rear. What would Andy say????
mandolindave is offline   Reply With Quote
Old 06-23-2010, 08:39 AM   #2
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
Dave
Look on the sidewall of the tire.Tire pressures should be stamped there. Follow the mfgrs stamped tire pressure and forget what a car dealer says. You should be fine, 600 lbs bars will be fine,just dont try and pull em down to tight.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 06-23-2010, 10:02 AM   #3
The tires are marked 80 lbs cold "max"
GM were the people that said 50 lbs front, 80 lbs rear, not a car dealer.
My point is that if the front tires can be as low as 50 lbs, then why not the rear tires be lower. As I said the ride is rough, and I worry that
the stiff suspension might crack the trailer frame or something.
Old 06-23-2010, 01:11 PM   #4
Running a lower tire pressure than "maximum" depends on several factors.
If the roads will be good, and the load on the tires is not anywhere near maximum, then tire pressue can be reduced.
However, "under inflated tires" can cause problems as well.
Use a pressure that your comfortable with, keeping in mind the tire temperatures, loads and speeds.
Yes, maxed out tire pressure, when not needed, stiffens the ride, as well as transfers more road shock, to the trailer.
Unfortunately, there is no absolute definitive answer to your question, unless your absolute travel parameters are known.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 06-23-2010, 01:17 PM   #5
_
weigh the rig, set the tv tires pressures accordingly.
without the scale info no1 can provide appropriate inflation numbers.
this is covered ad infinitum here.....
some might suggest ad nauseum.
with NO brand/model tire listed in the op there's not much point in linking the inflation tables...
besides they've been linked already many times.
__________
IF these are E rated tires on the van they can accept a WIDE RANGE of pressures based on load...
and many folks fiddle with the tables and inflation.
however there's plenty of evidence that running these tires SOFT...
is a NEGATIVE for handling/braking/control and generates MORE tire heat which is also bad.
but for those buying into the "let's make the stream ride sloppy and wallowing"...
that evidence is usually ignored.
__________
IF there is no need for E rated tires on the van
go to something else with adequate load/capacity but without EXCESS capacity.
a D rated LT tire can be more optimally inflated IF/AFTER weighing the rig.
or get some nice whitesidewall touring tires, like KINGS/crowns or these...
Radial Tires- Wide White Walls- www.WhiteWallTires.com
then cruisebabycruuuuze...
it's 3/4 ton van so E rated tires fit the vehicle profile but perhaps NOT your needs.
cheers
2air'
Old 06-23-2010, 03:06 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Saying & posting are different
...What would Andy say????
More like, "What would Andy post?". Andy understands liability, and if he has a commercial license related to this question he knows he could be sued for offering guidance based on the limited information presented here if bad events should ensue.
My tow vehicles have stickers mounted on the driver's side door jamb which give recommended tire pressures for my LR E tires for given situations. My TV's tires are inflated according to this guide.
None of the tires are inflated to maximum pressure as listed on the tire's sidewall.
Tom
Old 06-23-2010, 04:25 PM   #7
Maniacal Engineer
barts's Avatar
Lopez Island , Washington
Personally, I find the increased traction and sidewall stiffness due @80psi to be a big win, so when towing anything substantial I run 80psi in our F250 rear tires.
- Bart
Bart Smaalders
Lopez Island, WA
https://tinpickle.blogspot.com
barts is offline   Reply With Quote
Tire Pressure Gauges- Pressure Varies! Ray Eklund Tires 19 07-03-2019 09:19 AM
tow vehicle tire size Randjg1 Tow Vehicles 6 01-05-2009 09:42 AM
Tire Wear on Tow Vehicle grannyred Tow Vehicles 5 02-08-2006 02:34 PM
Tow Vehicle Tire Pressure overlander63 Tow Vehicles 17 04-30-2004 11:43 PM
tire pressure Land Yacht Deb Tires 1 01-18-2004 12:50 PM
