View Poll Results: how often do you check your tire pressure?
Monthly, and before every trip towing 21 67.74%
Monthly 1 3.23%
Before towing, or when I get the oil changed 8 25.81%
It's been a while... 1 3.23%
Voters: 31. You may not vote on this poll
Old 03-31-2004, 10:47 AM   #1
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Question Tow Vehicle Tire Pressure
How often do you check the tire pressure on you tow vehicle? It is recommended to check at least monthly, I wonder how many actually do it?
Do you check pressure before towing?
Once again, enquiring minds want to know.
Old 03-31-2004, 10:58 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Terry!
Ever since I had a wheel/tire/spring failure (it was never determined which happened first, but the result was a 180 degree spin in the middle of a busy secondary highway) on my Brand X travel trailer in 1982, I have been very cautious about my tires and wheels on both trailer and tow vehicle. I carry a samll 120 Volt AC compressor as well as 12-volt compressor so that I can check the tire pressure in each of the tires on my coach as well as tow vehicle as part of my pre-departure ritual each day. I find that additional air needs to be added about every third day when traveling in the mountains, but less frequently when traveling in the plains.
Kevin
Kevin D. Allen
AIR #827
Old 03-31-2004, 11:21 AM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
On the MH I go by the 7 day rule. Before a long drive or if it has not moved for 7 days I check the tires. Otherwise I do it monthly on all the cars and the MH.
I also check all fluids, etc before we leave on any trip of 50 miles oir more.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 03-31-2004, 03:53 PM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I too check the tire pressure monthly....sometimes every other fillup when the weather fluctuates since outdoor temps do play with the pressures pretty good. In winter, 44psi might be 48 or 49 when it finally hits 50 degrees out. Other issue when it's warm and then it gets cold out, the pressure is usually too low. One last thing is that somewhere here on this fourm, is a thread talking about how and when to check your pressure. I believe that it talked about not simply checking before you leave..but also checking when on the road for an hour or two as the tire heats the pressure increases or something like that. I personally found on the car, that it says that at 44 psi the tire can handle 1800 some odd lbs. Well, after being on the road the 44 psi shot up to about 49 psi. I took a few lbs out. Only issue is that until they get warm again, they are about 5 lbs under the 44lbs recommended.
I also check all fluids before a trip and torque the lugs.
Eric
Old 03-31-2004, 04:01 PM   #5
2003 25' Safari
Eden Prairie , Minnesota
Always check tire pressure cold. Do not remove air from a tire that has driven a few miles! The heat from sidewall flex will always cause the pressure to rise... but that is factored into the cold pressure recommendation. See Article
Dan
dmac is offline   Reply With Quote
Old 03-31-2004, 04:04 PM   #6
2004 19' Bambi
Denver , Colorado
Images: 32
Just a word of caution ...
You should always check your tire pressures when they are cold (tire stationary overnight), never when they are warm. Inflation guidlines in your tow vehicle owner's manual will state this specifically.
If you make a habit of always checking your tire pressures each time you couple your trailer you can rest assured that they will be on the mark, at least while you are towing. I have a checklist that I made up and keep in the tow vehicle for coupling/uncoupling the trailer. Tire pressure check is on that list. Keeps me from doing stupid things like trying to drive away from a campsite with the rear stabilizer jacks still deployed (which I nearly did last summer - disaster averted thanks to the watchful eye of a fellow camper)
COLORADO_CAMPER is offline   Reply With Quote
Old 03-31-2004, 04:11 PM   #7
Aluminut
2004 25' Safari
. , Illinois
Then that is good news. I can only check once...and if it's at 44 for the car and 65 for the coach, even if I drive for 2 hours and the pressures are 49 and 70, that is ok? If so that really save me some extra steps while on the road!
Old 03-31-2004, 04:23 PM   #8
Well Preserved
1993 21' Sovereign
That is correct, Eric. Cold tire pressure is defined as stationary overnight, and not having been driven over 1 mile. I would check before moving it, anyway. Kind of like checking the oil in the morning, before starting your car. If you run the engine for a few minutes, some of the oil is up in the engine, and it will read low on the dipstick, even though there is a proper amount in it.
Old 03-31-2004, 04:28 PM   #9
Aluminut
2004 25' Safari
. , Illinois
Good to know! Thanks all for setting me strait. I was checking all the time when towing. Before going, an hour in, a few more hours in...etc. What a PITA that was!
Old 03-31-2004, 04:48 PM   #10
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I always add air in the rear tires of my 2500 hd to bring them up from 55 psi to 70-72 psi for towing. I checked the air in the trailer tires this past Friday before pulling out Saturday morning and found each to be in the 45-50 psi range so brought them up to 62 psi for the trip.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-31-2004, 07:15 PM   #11
This is cheap (as in free) insurance. In my case, I check the trailer tire pressure before every trip. If the trip is extended, I check every few days (no telling when you will pick up a nail). I have to pump up the tow vehicle quite a bit to tow, so I check it every trip.
alan is offline   Reply With Quote
Old 03-31-2004, 08:51 PM   #12
RivetED's Avatar
North Central , USA
I'm very diligent about checking the COLD tire pressures of both my tow vehicle & A/S. I carry a small A.C. compressor in the pick-up while we are on-the-road for morning 'top-offs'!!
RivetED is offline   Reply With Quote
Old 03-31-2004, 09:16 PM   #13
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
Tire pressure
I am with Ed I always check both before I leave and take an air pump with me to top off any low tires. It makes tires last a long time.
Andrew Selking is offline   Reply With Quote
Old 04-01-2004, 06:24 AM   #14
Just an old timer...
85MH325's Avatar
Tipton , Iowa
Images: 37
Safety checks
After finding all four sidewalls cracked while towing the Behemoth, and being caught up in the Firestone Steeltex recall, I have become much more tire-conscious. I check them regularly.
I found my tires to be self-destructing on a walk-around of the truck and trailer. I do it every time I stop, just to make sure that we're not dragging something that shouldn't drag (like the bumper... ).
I heartily recommend that routine to anyone who tows. It's a good safety habit to check the hitch, chains, tires, and give the entire rig a visual check all the way around every time you stop. I've found a number of minor problems (including a falling belly pan on the Bambi) that way before they became disasters.
Roger
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Tow vehicle advice needed.... crazylev Tow Vehicles 86 04-27-2007 06:11 PM
tire pressure wb13798 General Motorhome Topics 16 01-27-2007 12:31 PM
Suggestions on new tow vehicle Diana Langley Tow Vehicles 3 07-08-2003 07:31 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
