Old 03-11-2006, 09:29 PM   #1
Daisy2's Avatar
1969 23' Safari
Miami , Florida
Tow Vehicle, should I? or Shouldn't I?
There is a vehicle up for sale that I'm looking at to tow my A/S. It is the same year as my A/S, and the color I want, and looks in mint condition. But that is not what is important, I guess. My question is: Is it capable of towing my '69 safari 23'? The vehicle is a '69 Deville with a 472 engine. I haven't taken the short trip to look at it yet, just wanting to know if it'll do the job of towing my Silver House before I go talk to the owner.
Of Peace, D
Follow on twitter @mbodyspirit
www.mbodyspirit.com
Daisy2 is offline   Reply With Quote
Old 03-11-2006, 11:29 PM   #2
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
HI there, we are talking Caddy right ? Well, full frame, good sized engine, you'll need a W/D hitch for it. I don't see why it wouldn't tow a 23 ft. AS.
Things you'll need to look into before buying -
Has the transmission been serviced regularly
does it have a transmission cooler
what is the rear differential gear ratio - helps to know this, the higher the ratio, the better for towing IE; 2:80 ( not so good ) 3:73 ( much better ) 4:11 ( good ) With a lower ratio (2:80), going up hills will be a bit slower.
You'll need a brake controller and some wiring done
plus at least a class three hitch
If this car doesn't have these things, check into how much it will be to get them installed.
Hopefully some GM folks will chime in here.
I used to have a Lincoln Continental about the same vintage. I know that car would tow my AS just about any place I wanted to take it.
I'd say go take a look at it, talk to the owner. Can't hurt.
How cool would that be, towing your 69 AS with a 69 Cadillac !
Chris
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 03-12-2006, 01:20 PM   #3
Daisy2's Avatar
1969 23' Safari
Miami , Florida
Great info! Thanks so much. I think I will take a drive to check out the car. I never thought of buying a vintage to tow my A.S. until I joined this website. I thought all I could get was an SUV. I'd much prefer a vintage!
Thanks again.
Of Peace, D
www.mbodyspirit.com
Old 03-12-2006, 01:22 PM   #4
Daisy2's Avatar
1969 23' Safari
Miami , Florida
Oh, did I mention it was convertible? WooHoo!!!
Of Peace, D
www.mbodyspirit.com
Old 03-12-2006, 01:59 PM   #5
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Daisy2!
In all probability, the DeVille that you mention will be a good candidate to tow your Safari-23. From the factory, it would have had the 472 cubic inch V8, Turbohydramatic 400 transmission, and its standard differential ratio would likely have been 3.07. Several optional differential ratios were available, including an "economy" 2.73 ratio.
With a pre-1970 engine, my biggest concern would be the potential for valve recission as the '69 motors weren't equipped with the special hardened valve seats to accommodate unleaded fuels. For a "show and cruise" collector vehicle that is under minimal stress there may be no particular problem, but it doesn't take much towing to produce stesses and result in valve recission -- it took less than 1,000 miles towing with my '65 Dodge 383 cubic inch V8 before recission became evident -- the cost for a total valve job with new hardened inserts was just under $2,000 in 1980. The 1970 and later engines had factory hardened valve seats, so it would be possible to install a later set of heads if necessary.
Since the DeVilles of this era were rear wheel drive, it shouldn't be a tremendous problem to change the gearset; but when I checked into this two years ago, my mechanic indicated that the particular differential used in the late 1960s early 1970s DeVilles didn't have a large number of ratios available when new or aftermarket. With my Eldorado, I found a recored radiator to be a virtual necessity -- ended up going with a custom to get the most cooling capacity utilizing a 4-row heavy-duty core -- the car now runs cool under all conditions. I also went with a large Hayden transmission fluid cooler as well.
You will need to find a hitch fabricator as there aren't any stock-bolt-up hitch platforms for Cadillacs of this era. Locating a hitch fabricator was among my two biggest problems in outfitting my '75 Eldorado Convertible as most hitch installers no longer do fabrications -- the kits are available, but for various reasons (liability most often cited) the shops don't want to undertake such projects. I finally found my fabricator through my regular mechanic -- the shop specialized in agricultural welding and would handle hitch fabrication in the "down" periods.
I love driving my Cadillac convertible both solo and when towing -- it has no particular problem with my Overlander, but it is at the top end of what I would want to tow with the car and is also at the top of the 6.000 pound trailer tow rating published in the car's owners' manual. Had I been planning on towing when I purchased the car, I would have held out for a DeVille convertible as the Eldorado had 2.70 Final Drive ratio that is cost prohibitive to change with the only other ratio being 3.07 (due to its front wheel drive configuration) -- not to mention the virtual impossibility of finding wheels for the FWD Eldorado that aren't bent to a degree that they produce vibration when driven. The DeVille has wheels that are shared with other GM divisions so there shouldn't be a particular problem finding a replacement wheel if one or more should need replacement on the vehicle that you are considering.
Good luck with your investigation!
Kevin
The photo below is of my '75 Eldorado with the '64 Overlander:
The phot below is of my '75 Eldorado with the '78 Minuet 6.0 Metre:
The photo below shows part of the Reese Weld-Up Receiver that was fabricated for the vehicle:
Kevin D. Allen
AIR #827
Old 03-12-2006, 02:31 PM   #6
Daisy2's Avatar
1969 23' Safari
Miami , Florida
wow, that's alot of information, I'll have to ask the owner for all this info on his car. Thanks for taking the time to write me with such great detail.
The A.S.'s you show on your pics are a beauty. Looks so cool with the vintage car. I hope to have this combo myself one day soon.
Of Peace, D
www.mbodyspirit.com
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 01:58 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 07:04 AM
4x4 tow vehicle... or not? Cheryl Tow Vehicles 11 08-22-2002 11:00 PM
