Old 10-16-2002, 03:21 PM   #1
wlanford
Profile:
Tow Vehicle Options
At retirement, my wife and I are considering the purchase of a 28' or 30' Airstream Excella for nationwide touring. For a tow vehicle, we are considering the Suburban/Yukon XL 3/4-ton with the 8.1L engine. This vehicle would also be our 2nd car and would be driven in-town when we're not "on the road". I 'm not sure whether the 3.73 or 4.10 rear-axle would be the best choice! It seems to me that the 3.73 would be fine, but I have seen several posts which stated that "you can't have too much tow vehicle". But I worry that the 4.10 would drink too much gas when driven around town! Recommendations?
Thanks in advance!
wlanford is offline   Reply With Quote
Old 10-16-2002, 04:43 PM   #2
Les Gilliam
Les Gilliam's Avatar
Profile:
I pull a 28ft Excella with a 3/4 ton Suburban 8.1 and 3.73. I am sure the 4.10 would pull better, but mine handles very well and I am quite satisfied with it. The mileeage isn't all that good averaging 9 mto 12 gph with tow and 11-14 without tow. A lot depends, of course, on speed and terrain. My dream tow vehicle would be a 3/4 ton Suburban with a Duramax engine and an Allison transmission. Too bad they don't make them.
Les
Les Gilliam is offline   Reply With Quote
Old 10-16-2002, 04:58 PM   #3
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
My '01 Chevy 2500HD extended cab truck has the 8.1, Allison trans and 3.73 rear end. It pulls my 31' Excella 500 fine. I get either side of 15 mpg on the interstate without AC and 10 in town with AC running. I get 12-13 towing. If you are running LT245-75-16 tires then the 3.73 rear is fine, helping get better gas mileage when not towing. If you plan on putting on taller tires such as LT265-75-16 or LT285-75-16 then I would go with the 4.10 rear. These recommendations would hold with your Suburban as well. If I decided to tow nationwide then I would probably get the same truck I have now but get it with the Duramax diesel available in the 2500HD for better gas mileage.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-16-2002, 04:59 PM   #4
j54mark
Profile:
3.73 vs. 4.10
The 3.73 should be fine for any 28 or 30 foot Airstream - except perhaps the 30 foot slide-out model. The nice thing about a 3.73 is that it runs at highway speeds at a lower and quieter rpm. And the gas milage is better too.
The only exception would be if you actually live in and frequently tow in mountains.
Mark
Old 10-16-2002, 05:01 PM   #5
John
Profile:
I went from FL to BC,Canada towing a 1994 28' Excella with a 2000 K-1500 5.3L with 4:10. I got 13 mpg on the hwy and 10.5 mpg in the mountains. It's in the rear greaing. Of course on those steep grades, I traveled at 35 mph @ 2500rpm.
Good Luck, John
John is offline   Reply With Quote
Old 10-16-2002, 08:21 PM   #6
jlovelady
'65 Caravel 17'
jlovelady's Avatar
Profile:  2001 34' Limited
1965 17' Caravel
Lufkin , Texas
I traded in a Dodge 2000 with a Cummins engine and a 3.54 rear end on a Chevy Crew Cab Silverado with an 8.1 L. It has a 4.10 axle.
I love the truck. It is very quite and roomy. I miss the torque of the diesel but not the noise. Like you, I use the truck as a second vehicle at 13 mpg on the road without a trailer. When I pull my 34' 1993 Excella I get 10.2 mpg whether I am on flat or mountainous terrain.
I would now prefer a 3.73 for better milage when I am not pulling. I don't think it is available with the 8.1L gas and an Allison transmission.
The transmission is the best. It will respond to braking and stay on a constant downhill speed. You can then let off the brake and let the automatic transmission do the work without actually having to downshift.
Excessive oil consumption is a problem on the 8.1L. Mine uses 1 quart each 1,000 miles. GM says that is normal. We are now under an oil consumption test. It does not seem to effect performance.
Best of luck.
jlovelady is offline   Reply With Quote
Old 10-16-2002, 08:59 PM   #7
RoadKingMoe
RoadKingMoe's Avatar
Beavercreek , Ohio
Given same tires, Allison tranny, and 3.73:1, the 8.1 in fourth gear is putting about the same torque to the ground as the Isuzu Duramax is in fifth, and the 8.1 in third gear is about the same as the diesel in fourth. The gas engine both gets its peak torque at 100 higher rpm than the diesel gets its peak hp, and the gas engine can be run at that rpm a lot longer than the diesel can. Of course, that's partially why it uses a lot more fuel.
If you tried to calculate its GAS mileage, you'd get a DIVIDE BY 0 error.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 10-16-2002, 09:46 PM   #8
davidz71
davidz71's Avatar
Seems about right Maurice.
Craig
AIR #0078
3.73 rear end
Old 10-17-2002, 07:49 AM   #9
davidz71
davidz71's Avatar
3.73 and 4.10
jlovelady,
The 8.1 with Allison and 3.73 is available in the 2500HD 2WD and 4X4 in the reg. cab, ext. cab and the crew cab. It is not available in the 3500 2WD or 4X4.
Craig
AIR #0078
3.73 rear end
Old 05-23-2005, 09:54 AM   #10
'63 princess
Profile:
tow vehicle for a '63 Overlander
I have a 26' 1963 Overlander. Do I need all that? The Duramax engine, the Allison tranni and the 4.10 rear end?
I understand that the transmission is the most important element when deciding on towing vehicles...
8.1, what does that mean, V8? Do I need that much? Wouldn't 5.3 cylinders be alright for the 26'?
Granted; I plan on putting a lot of cool stuff in it including a 60's fridge and possibly an older stove.
'63 princess is offline   Reply With Quote
Old 05-23-2005, 12:18 PM   #11
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 104
Tow Vehicle Options
Greetings '63 princess!
I tried skimping on the tow vehicle that preceeded my current K2500 Suburban with the 7400 VORTEC and 4.10 differentials (7.4 liter predecessor of the 8.1 in use today). My previous tow vehicle, a K1500 Chevrolet Club Cab Z-71 pickup with the 5.7 Liter V8 and 3.73 differentials, was overwhelmed by my '64 Overlander -- fully loaded for an extended vacation, my Overlander tips the scales at 6,100 pounds (Empty Weight 4,440 pounds) and that was more than 94% of the factory trailer tow rating for that particular K1500 pickup truck.
Particularly if you are planning on adding additional options/accessories that will increase the weight of your coach, a large displacement V8 with 4.10 differential gears will be a noticeable improvement in towing comfort (IMHO). The slight difference in solo fuel economy wasn't worth the trade-off in towing performance (IMHO). In fact, my Suburban with the 7400 VORTEC produces better fuel economy figures both solo and when towing than my K1500 Chevrolet pickup ever did in the 45,000 miles that I drove it (the Suburban just turned 142,000 miles yesterday from day I took delivery in 1998).
Good luck with your investigation!
Kevin
Kevin D. Allen
AIR #827
overlander64 is online now   Reply With Quote
Tow vehicle advice needed.... crazylev Tow Vehicles 86 04-27-2007 06:11 PM
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 9 09-30-2004 11:05 PM
Air Spring Options for Softly Sprung Tow Vehicle? overlander64 Towing, Tow Vehicles & Hitches 15 11-29-2003 08:49 PM
Suggestions on new tow vehicle Diana Langley Tow Vehicles 3 07-08-2003 07:31 AM
Tow vehicle rating femuse Our Community 21 03-22-2003 07:16 PM
