Old 12-11-2013, 12:47 PM   #29
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Originally Posted by jornvango View Post
We're trying to decide between the following 2 trucks:
1) 2006 Ford F-350 4x4 dually long bed with the 6.0l turbo diesel and 192K miles. Dealer is asking $15,900. The infamous engine issues (EGR valve and catalyst converter) have been fixed.
Very good condition, King Ranch edition with nice leather interior.
2) 2008 Dodge RAM 3500 4x4 dually long bed with the 6.7l turbo diesel (24V) and 191k miles. Dealer is asking $16,900.
Not as nice on the inside; cloth interior with some stains.
Both trucks are under NADA value and around the 'good'/'very good' KBB value.
Which one would you pick? Based on the appearance we're more drawn to the King Ranch Ford, but based on what people are telling me about the engine ... the Dodge.
Any comments?
We have the Ford with that engine. I love the truck, but the coolant thing is annoying and likely to be an expensive repair if it hasn't already been bulletproofed. I know I'm wishing I'd found out about it beforehand.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 12-11-2013, 12:55 PM   #30
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Any comments?
I would avoid any 6.0L Powerstroke. They have had a checkered service history, and getting to anything major on the engine requires removing the cab. That's not something you want to deal with in a little country town in Guatemala!
David
Old 12-11-2013, 01:05 PM   #31
jornvango's Avatar
Is this what you're referring to: the need to use the 'correct' coolant?
https://www.fleet.ford.com/truckbbas...LANTINFOSS.pdf
jornvango is offline   Reply With Quote
Old 12-11-2013, 01:53 PM   #32
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Something tells me I don't want to read that link. If it's like what a dealer told my dad - "They're having problems with them because they're all putting chips in them!" - then it'd just be blaming the owners, and that's the last thing I want to hear.
The problem I am concerned about, well documented in this forum and elsewhere on the internet, is how EGR causes some kind of bizarre overpressure situation in the coolant, causing coolant to blow out the recovery bottle, possibly damaging head gaskets and other things along the way (oversimplified explanation; I don't need the corrected explanation, anyone). I carry extra gallons of coolant with me. I'm expecting the cost to fix it will be in the thousands of dollars.
Until we get it fixed, I'm half afraid to climb mountains with it because that's what gets it going - heavy load, big hill. Last time we did that we had to pull off because the damn thing blew out all of its coolant. This truck - or frankly any diesel 3/4 ton truck - ought to be able to tow our trailer over a mountain at highway speeds without losing all of its coolant. For regular trips we take, I can predict almost exactly how much coolant it will lose. Frustrating to say the least.
Just read the link: Yep, blame the owner. You didn't use MOTORCRAFT!
Old 12-11-2013, 02:04 PM   #33
jornvango's Avatar
Yeah, that's my major concern with the 6.0l, not many good reviews out there.
I can't find bad reviews (big recurring issues) about the Dodge Cummins.
I had the Ford checked by a mechanic and he said that the EGR valve and catalyst converter issues have been fixed on that truck and he said that the engine is very good once those issues have been fixed.
But yeah, will I find Motorcraft coolant in the middle of nowhere in central America or will they be able to work on the Ford?
Old 12-11-2013, 08:28 PM   #34
jornvango's Avatar
We went to test drive the Dodge this afternoon and took it to a mechanic to have a used car inspection done. Everything looks good mechanically.
I told the mechanic about our choice (the Ford or the Dodge) and he said to go for the Dodge. I called up another mechanic (who inspected the Ford last Friday) and asked him the same question: he said the same thing; avoid the 6.0l Ford engine and go with the Dodge. (Both of them did say that the earlier Ford engine, the 7.3l was an excellent engine)
So... we bought the Dodge! We're picking it up tomorrow afternoon.
2008 Dodge Ram 3500 DRW 4x4 with the 6.7l Cummins diesel.
Old 12-14-2013, 12:17 PM   #35
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Congrats on the Dodge I think you'll be pleased with it.
Can you find out if it has the TIPM? If yes research for anything that is a known TIPM killer or anything you can do or avoid to save it.
Use paper air filter, carry extra and an extra fuel filter or two on the big trip.
Good luck.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 12-14-2013, 03:35 PM   #36
2003 25' Safari
Riverside , California
Yes it has a tipm,but the bigger issue will be not having ulsd available and the long term effects it will have on the dpf.4x4 low range for extended time will also be a concern with the regen system
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
2015 Toyota Tacoma trd 4x4
2000 Jeep Wrangler 4x4
Bob4x4 is offline   Reply With Quote
Old 12-18-2013, 03:33 PM   #37
JFScheck's Avatar
Rockville , Maryland
Images: 33
ULSD is everywhere (as is DEF but you don't need that). You should be good to go and congrats, of course a picture to be posted is necessary at this point....
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 12-18-2013, 04:39 PM   #38
jornvango's Avatar
Here it is. We're very satisfied with it so far: truly a powerful machine. Yesterday we drove 85 mph on the toll road next to Austin (yes, 85 is the speed limit!), the engine barely had to make an effort at 2,000 rpm and we got 15 mpg!
We're heading back to Austin tomorrow to pick up our new truck camper for our trip through Central America. Since Airstream doesn't make truck campers, we got the next best thing: an all aluminum & composite truck camper: no wood, even the cabinets are alu & composite, so no rot ever and no steel, so no rust! We purchased the 2014 Livin Lite Camp Lite 8.6
Old 12-18-2013, 06:58 PM   #39
GCinSC2's Avatar
Originally Posted by JFScheck View Post
ULSD is everywhere
JFS
The OP stated the truck is heading to Central America. That is what my ULSD question was targeting, I don't know.
Gary
S/OS #001
Old 12-18-2013, 07:00 PM   #40
GCinSC2's Avatar
Looks good. In the Dodge community mileage is hand calculated. The overhead is a notorious liar about mileage.
Good luck
S/OS #001
Old 12-19-2013, 07:21 AM   #41
2003 25' Safari
Ulsd is extremely rare in Mexico and I am told worse in other s a countries
2003 25' Safari
2005 Ram 2500 4x4
1994 Ram 2500 4x4
Old 12-19-2013, 06:49 PM   #42
JFScheck's Avatar
Images: 33
Originally Posted by GCinSC2 View Post
JFS
Gary
Thanks Gary, half asleep on that one...
Great looking truck, post a pic when you get the camper installed please!
**I Love U.S.A.**
