Old 02-02-2009, 08:02 AM   #15
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Question
Haven't done/needed to do any research on the new air suspension system's. Just how do they improve, better control suspension for towing? I've read here that some feel they actually do more harm than good.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-02-2009, 08:31 AM   #16
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
Front hitch for bikes...
365 hp
650 lb/ft
15mpg towing
24-25 mpg unladed
What mods could possibly help?
Bill
*Life is Good-Camping all around the Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 02-02-2009, 08:52 AM   #17
hampstead38's Avatar
1967 26' Overlander
Upperco , Maryland
My brother runs air suspension on his Toyota Tundra pulling a 26' "box" with slide-outs. I haven't made a final choice on a TV, let suspension tweaks. He likes the air bags, in part because the stock suspension is a little soft, in part because he does a lot of boondocking off the hard road. He thinks the bags give him a way to "tune" the suspension for his daily driver. As always, your mileage may vary.
hampstead38 is offline   Reply With Quote
Old 02-02-2009, 09:37 AM   #18
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
Bigger open exhaust to reduce EGTs and avoid melting the turbo down, boost and exhaust temp gauges, aftermarket class IV hitch, Cipa extendable towing mirrors, rear view camera to aid in hitching up, and changed all fluids to synthetics including the differential. Naturally there's always plans in the works for a few more gadgets here and there.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 02-07-2009, 04:24 AM   #19
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Advertisers make grand promises of additional power with "Bolt On" engine mods; however, I would be wary of such claims. My experience with sports cars indicates otherwise. To prove this to myself I put my Corvette on a dyno before and after various "Bolt On" mods and found only a slight 7hp gain after various mods i.e. air cleaners, headers, cross pipes and mufflers. You may find that a change in base power plant and gear ratio work best and that may be easier accomplished by the obvious. I'm certain that other 'gearheads' can chime in here with more detailed advice for you. Good luck.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 02-09-2009, 06:49 AM   #20
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
I've fooled around with cars for a long time. Experience is that sometimes an increase is seen, but there is no free lunch accompanying it. As above, most mods take a tremendous amount of miles to pay off.
Overall, stiffer rear gears do the most. The tradeoff is a lower cruising speed for the same economy.
My truck is geared with a 3.73 limited slip. Great balance of power, great rpm range in each gear (manual transmission truck; and that is a narrow range compared to a gas motor), great performance (power AND economy) when towing or solo . . . but only if I keep the solo cruising at about 66 mph, the top end of the rpm "sweet spot".
My "economy" (fuel mileage solo, only) would improve if I went to numerically lower rear gears. But I would lose the great blend I have now.
The reason I chose a 2003-4 Cummins powered truck is that the balance was about as perfect as it could get. Not many tow vehicles see 19 mpg around town.
Tow vehicle help...please pamelake Tow Vehicles 8 11-06-2005 06:59 AM
Get the right tow vehicle woolygums Airstream Motorhome Forums 0 09-19-2004 06:45 AM
new tow vehicle whistler On The Road... 10 04-14-2004 07:07 PM
Towing Vehicle Performance Modifications docbluedevil Tow Vehicles 32 11-10-2003 05:31 PM
Tow Vehicle Myrjer Tow Vehicles 10 07-03-2003 07:55 PM
