Old 04-02-2015, 06:28 PM   #1
1972 27' Overlander
bremerton , Washington
Tow vehicle mod on an older Suburban
I have a 1969 1/2 ton suburban. I have touble towing, and stopping my 3 ton air stream. What would anyone suggest I do? Getting rid of this truck is not an option, what can we do to improve this trucks use?
criswellrl is offline   Reply With Quote
Old 04-02-2015, 06:39 PM   #2
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Any idea what the rated towing capacity is of your Suburban? So far, all I can offer is to make sure the brakes on the trailer are as good as they can be to help get it stopped.
What engine, transmission, and rear end ratio?
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-02-2015, 06:52 PM   #3
1972 27' Overlander
thanks for your quick response. I have been told that this truck should be able to handle it. But I've also been told switch to a 3/4ton.
Old 04-02-2015, 06:55 PM   #4
1972 27' Overlander
I have been told that there are some mod's that can improve it's towing and stopping. what do you think? Is it possible?
Old 04-02-2015, 07:02 PM   #5
PaulnGina's Avatar
Good Ol' , USA
You first indicated that you won't get rid of the 'Burb. My 1st inclination is keep the 'Burb, get a 3/4-ton to tow the trailer. By the time you upgrade the 'Burb, you could buy a decent used 3/4-ton vehicle. If you're going to keep the 'Burb, I don't think you'd go wrong with upgrades......
Oh, what to do???
1987 Avion 34W
Old 04-02-2015, 07:03 PM   #6
1972 27' Overlander
I know there are things I can do to upgrade it. I just need some advice about how to go about doing it, and whether I can do this without spending a whole lot of money. Has anyone done this? And was it successful?
Old 04-02-2015, 07:07 PM   #7
1972 27' Overlander
Thank you for that info. My wife and I just bought it. We thought that it would be really cool pulling a vintage air stream with a vintage truck, from the same era.
Old 04-02-2015, 07:12 PM   #8
1972 27' Overlander
I know that my brakes will need modified. But I'm not sure how to go about boosting my engines horsepower. Any suggestions?
Old 04-02-2015, 07:16 PM   #9
PaulnGina's Avatar
Good Ol' , USA
I agree, it's a neat combination. Seems like the easiest "upgrade" would be a rear-end ratio change. Is the 'Burb struggling just to get going? Are your trailer brakes good?
1987 Avion 34W
Old 04-02-2015, 07:57 PM   #10
1994 34' Excella
Warren , Manitoba
Give us a little more info on the TV. Engine, transmission, rear axle ratio??? How many miles, and is it worn out? Do the trailer brakes work? All of these items are importand information needed to give you any help or guidance. Chris
WBCCI #7394
2002 Chev 2500 HD Duramax
1976 31' Gone but fondly remembered
CBWELL is offline   Reply With Quote
Old 04-02-2015, 08:37 PM   #11
1974 27' Overlander
Twisp , Washington
Just how tired is your 'Burb? I also have a 27' Overlander, a '74, when we got it, I had a '78 1/2 ton Suburban with a well worn 350 and TH 350 trans to tow it with. Towed it from Tacoma to Bothell, then from there to Twisp, the only place it struggled was going over Blewett Pass. Since then, I've had 3 other 'Burbs as tow vehicles, a '79 3/4 ton and an '88 1/2 ton, both with 350's and automatics, and my current TV is Suburban #4, a '96 3/4 ton with a 454 and auto trans (don't like manuals for towing). The current beast doesn't even know it's there, but none of the others had any issues, either, and they were all stock trucks. If yours is struggling, there's something wrong that needs to be addressed, before you start throwing money at "upgrades". Properly working trailer brakes and a good brake controller are also very important. Good luck!
Dave
daved20319 is offline   Reply With Quote
Old 04-02-2015, 08:58 PM   #12
mnmhays's Avatar
1973 Argosy 26
1966 30' Sovereign
Southern , Wisconsin
We have a '96 K1500 Suburban with a similar towing capacity. Our Argosy tips the scales at 3800# give or take dry weight with an additional allowable of 2400# for a total of 6200 GVW...well under the Suburban's capabilities. Our Sovereign is about 400-500# heavier dry weight with a similar GVW...still well within our TV's capabilities. I added spring assist rear shocks to help the towing stance.
What kind of gear ratio & transmision do you have?
All that is gold does not always glitter...those who wander not always are lost....
mnmhays is offline   Reply With Quote
Old 04-03-2015, 12:50 AM   #13
2007 25' Safari FB SE
Suburbia , Sunny So Cal
Disc brake conversion and swap in a higher HP engine with a trans that can handle the higher HP and towing.
You could get a more specific answer if you told us what engine and trans you have now.
I'd rather be boon docking in the desert.
WBCCI 6731 FCU
AIR# 13896
CA 4
Goin camping is offline   Reply With Quote
Old 04-03-2015, 05:02 AM   #14
Gainesville , Florida
Are you using a brake controller? What rear ratio on the burn? Peace,jim
Older Suburban Wanted Pam Airstream Classifieds 0 05-12-2014 03:59 PM
Older Suburban DanielB Tow Vehicles 7 12-01-2010 11:31 AM
Resources to purchase an older/vintage Suburban?? kdenault Tow Vehicles 4 07-02-2006 10:28 PM
