Old 04-05-2015, 08:17 PM   #29
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I believe the 69's came with several engine options. 230ci, 292ci L6, 283,307, 350, 396 ci V8. If you have the 292, there are several things that are bolt on that can give you 80-100 RWHP. If you have the thriftmaster 230, it will run like it has asthma no matter what you do.
All of the SBC engines were underbuilt, and are a great foundation for low buck performance upgrades.
The type of transmission will affect how well your vehicle tows. A well maintained Automatic, IMO works the best. The reason being is that you get Torque Multiplication with an automatic on the order of X1.5.
With that said, Engine/Trans/Rear Ratio have to be considered as a "package". You cant stuff a wild cam in it and expect a miracle. The most dramatic change you can do without breaking the bank is to change the rear axle ratio by installing a new Ring and Pinion Gearset. You would have to go with a numerically higher (lower ratio)gear to achieve breakaway torque, and desired sustaining torque. Sounds complicated but it's not too tough. Let us know what you are running, Eng, Trans, Rear Ratio, 2/4WD, Coil Spring or Leaf Spring, and the weight of your AS, and I will work out a couple of options for you that will have the power that you need.
If you are interested, I replaced the vacuum brake system on my GMC Sprint to the Hydro boost system. PM me and I will send you the pics and parts that you will need.
That car can bury the speedo (120) in 15 seconds, and it use to be a terror to stop. Not any more.
I think it's awesome that you want to tow with an older Surbuban. Just want to see you happy AND safe.
Clayton
NavyCorpsman is offline   Reply With Quote
Old 04-05-2015, 09:33 PM   #30
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
An earlier post said "the answer to your question is a 350 engine with a quadrajet 4 barre l carb. and a 350 transmission."
Sounds like a great place to start.
"Long lay the world in sin and error pining
Till He appeared and the soul felt its worth"
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 04-06-2015, 03:41 PM   #31
Regular Guy
1978 31' Sovereign
A MOST EXCELLENT PLACE TO START. Properly tuned, and with a good tranny cooler set up, you will be just fine. A lower stall speed torque converter helps to get it rolling easier, and will help drop the fluid temp a bit. If your engine is stone stock it makes about 260 hp and 280 ft/lbs TQ. Its not a stretch to make a street-able engine that makes 375 HP on pump gas.
Old 04-06-2015, 05:17 PM   #32
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
As was stated above, changing the rear ratio to a lower 4:10 or 4:30 will help. If you have an automatic, it's probably a 350 version, which needs a lot of help. Rebuild with a good kit and for sure add a Transgo Tugger Shift Kit. In addition, a $120 extra tranny cooler is in order. If it is a 4-speed manual, then you are stuck with it but you can still change the rear end ratio for better towing. Lastly, for about $350, you can install a set of rear air bags that will help your tired springs and re-align the "Burb" with the AS. Brakes are marginal and the fronts can be switched to disc first and then the rears if you get the bread. All in all, the '69 Burb is a groovy ride if set up right.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Older Suburban Wanted Pam Airstream Classifieds 0 05-12-2014 04:59 PM
Older Suburban DanielB Tow Vehicles 7 12-01-2010 12:31 PM
Resources to purchase an older/vintage Suburban?? kdenault Tow Vehicles 4 07-02-2006 11:28 PM
