Old 02-14-2015, 05:52 PM   #15
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
I changed my dodge front and rear diffs with sun 75-90 and trans along with transfer case with syn trans fluid at 50000 miles ,all is well
Old 02-14-2015, 08:26 PM   #16
1998 30' Excella 1000
Livingston , Texas
Originally Posted by Jammer View Post
Nomenclature. Most mechanics call the sealed, internally lubricated gearcase assembly that contains the differential, ring, and pinion an "axle." If it's a "solid axle" then the assembly will include the half shafts and possibly wheel bearings. Otherwise the half shafts and CV joints are outside the case, but the case is still the axle and contains axle fluid, which lubricates not only the diff but also the R&P set.
GM says I'm supposed to replace mine and I do.
The modern synthetic fluids last a very long time and with light to moderate use can easily last 100,000 miles or so which is as far out as the maintenance schedules go. All automakers are trying to minimize maintenance and have a goal of zero maintenance other than oil changes for the first 80,000-100,000 miles or so. Which is why we have dexcool. In that light the axle fluid is being dropped from the maintenance schedule in some cases where it perhaps should not be.
Usually the fluid requires replacement due to contamination before it fails due to shear. Water and grit from wearing parts are the two main contaminants. Limited slip diffs produce more grit. Water is more of a problem when there's high humidity and temperature extremes. There will be more wear and therefore more contamination and more shear if you work the axles hard. I live in Minnesota and have a plow on my truck and a gov-lock rear. So axle and transfer case fluid changes are a must for me. If you live in Arizona and don't play in the mud then maybe you can run the same fluid for 200,000 miles.
Jammer, excellent discussion. You taught me lots. Thanks-
Siegmann is offline   Reply With Quote
Old 02-14-2015, 08:54 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Dealer said.. "well, you don't have to replace the fluids... unless you plan on keeping the truck."..
All fluids changed before 50k... and will be changed again before 90k. Oil changes before 'recommended' spans.
Peace and Blessings..
Channing
WBCCI# 30676
How do you handle your vehicle maintenance on the road? BoldAdventure Full-Timing 20 01-15-2015 03:23 PM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 12:55 PM
Vehicle Maintenance on the road Uncle Bill Towing, Tow Vehicles & Hitches 2 01-24-2014 04:25 AM
Tow Vehicle Maintenance Safari Tim Tow Vehicles 14 07-01-2007 12:46 PM
