Old 01-03-2007, 10:36 PM   #15
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by Marshall
I found I did not really need an equalizer hitch with the big Fords. A swaybar was a good idea but even without it no fishtailing.
Sorry Marshall -- not picking, but bells go off with this statement. Let me clarify some terminology. We are speaking about after-market items that are not part of the OEM trailer A-frame or hitch and they are not inherent in a tow vehicle's receiver. WD & antisway are incorporated into the combined mechanism of many brands; eg, Reese Dual Cam, Equal-I-Zer has their own system, Hensley Arrow though expensive is the very best, Blue Ox, and many lesser "house brands" at dealers and so on...
Weight Distribution (WD) gear: Spring bars that when activated will apply torque to the tow vehicle (TV) frame so that not all the hitch weight is carried by the rear TV axle; ie, some of the hitch weight is actually transferred to the front axle. With passenger and other TV cargo, hitch weight might otherwise put a rear axle over its rated load rating. Measure to the top of all four TV wheel well enclosures before hitching. After hitching and engaging the WD gear the same 4 reference points should all settle by approximately the same amount.
Antisway: A variety of methods. First -- friction antisway is seen less commonly with new equipment and can be unreliable when you need it most -- in wet weather. Antisway works to dampen swing of the trailer if the tow vehicle makes a sudden lateral move. It helps keep the trailer in line with the tow vehicle and is not usually called on during 99% or more of routine towing. It is an invaluable aid for the inevitable, but it buys only a margin of safety and will not prevent loss of control in extreme maneuvers.
Now take a look at Don in E Texas' avatar pic. Some tow vehicles naturally don't need weight distribution. I can make a blanket statement that the greatest majority of us will always want to utilize WD & antisway gear. I have seen my antisway function in a situation where the trailer would not have been put in harms way. I definitely want antisway providing a margin of safety for stronger emergency avoidance and braking situations.
5 meter Langford Nahanni
Old 01-04-2007, 11:58 PM   #16
Clayton , North Carolina
Here's a tow vehicle for ya... wonder what it's tow rating is....
Saw it in person at the Smithfield Christmas parade.
Paul NC is offline   Reply With Quote
Old 01-05-2007, 08:45 AM   #17
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Suburban, 454, 3:73
mine is a 93, tows and stops my 32 footer just fine. Honest 10 mpg, comfortable and lotsa room inside.Sure it might be a little overkill for you but as you have a max of 8K to spend you should be able to find one, well where you live the body will probably be rotted out, expand your range look for a clean vehicle in one of the non snowy states.The old TV seem to me to be a bargain.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 01-11-2007, 11:50 AM   #18
Full-timer
1971 27' Overlander
Pumpkintown , South Carolina
This is the tow rig of choice for hauling my '71 27' Overlander through the Rockies. Originally, the tow rating of the '83 Wagoneer was something like 3,500#, and even that may have been optimistic. After grafting-on 3/4-ton drivetrain, suspension, brakes, etc., building a fuel-injected (a big help at altitude) AMC 360 with around twice it's original power, ditching the silly slushbox for a proper manual tranny (the only way I'll tow), fitting 3.73 gears, adjustable shocks, equalizer and sway control, it finally pulls whatever is asked (I've done 8,000 lb over 12,000' passes with ease). Fuel mileage ranges from 10 MPG for hard towing to 20 unladen at altitude, which is about twice what the rig was capable of when new. Of course, it's now a $10,000 Jeep worth maybe five hunnert bucks, but it works for me, or did until it became the property of My Dear Wife's New Boyfriend.
It's not the heat, it's the stupidity.
Foureagles is offline   Reply With Quote
Old 01-11-2007, 12:20 PM   #19
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
1 ton B350
we have a 1994 1 ton Dodge Van, B350 (shorty, not the big extendo version). Better brakes, 5.9L V8. Paid $7500 for it 3 years ago. Still running strong.
Marc
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 06:11 PM
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 01:58 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 12:18 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 07:04 AM
