Old 07-18-2004, 10:20 PM   #15
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
Originally Posted by Silvertwinkie
Good input...thanks wingfoot1!
Is your 2500 a standard cab, extended or crew? If it's extended or crew do you haul 2-3 kids? If not what do you think about hauling kids in a 2500 crew or extended 2500 pickup?
Mine is extended. My kids are 31 & 35. I think kids would do fine up to about 15 years old. But, I would say it is a 200-250 mile seat for small people only. I have had three men in back seat for 100 miles with no complaints? Maybe they were being polite or free ride?
Also, crews with long beds are a pain to park. When we go to a restaurant, they are nice for people space but, big to park.
wingfoot321 is offline   Reply With Quote
Old 07-18-2004, 10:39 PM   #16
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Thanks Charlie and Wingfoot1. I appreciate the input.
Old 07-19-2004, 07:59 AM   #17
JohnG's Avatar
I tow with a 1/2 ton GMC PU with extended cab and 5.7 Vortex motor. I have a 7 year old and this combination works fine for me. Tow capacity is 7500 lbs and I have it beefed a little also. The 1/2 ton will work fine in our applications and its advantage is that it will get better fuel milage that the 3/4 tons will. I get around 21 MPG around here in local use and get around 16 MPG when towing.
If you have a few kids or if they are older kids you might be better off with a Suburban because it really has tons more room. If you go that route you may want to go with a 3/4 ton for higher towing capacity, but stay away from the 4 wheel drive option. That will burn more gas. People argue back and forth on that because of having free wheeling hubs, but the engine still turns the transfer case for the 4 wheel drive and it eats more gas. At least all the folks I know with them say so.
I have a friend with a new Dodge and it is for sale right now. Has like 30K on it. Reason, less than 10 mpg when pulling the trailer and only 14 without a trailer.
Just some more data from another GM Man.................
Just adding my 2Ę worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-19-2004, 10:57 AM   #18
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
eric
you know where i stand on this issue, having had nothing but pickups all my adult life!
thinking back, i have only owned two cars!
the suburban will provide a more car like ride. however, my extended cab four door silverado will seat 5 adults comfortably. they made the cab larger in '99 and the rear seat better. havent had any complaints so far.
as for the 4 wheel drive, get it. you will be glad you did even if you only use it once or twice a year. sure beats asking for help and the tow strap!
i know you are car guy, and don't want to look like a farmer driving around in chi town. but give the pick up truck idea some thought!
add a nice truck topper and you have a good place for the pooches and all the other "stuff".
john
you call them ferrets, i call them weasels.
Old 07-19-2004, 11:13 AM   #19
Aluminut
2004 25' Safari
. , Illinois
Thanks for the info guys. It really helps.
Old 07-19-2004, 12:16 PM   #20
RoadKingMoe's Avatar
2001 34' Limited
The State of , Ohio
You know how I feel about trucks as well. Some thoughts...
Think about where you're gonna put those two Honda EU2000s, and the gas cans for them, in a Suburban (or the safer trailer interior).
I know you can put bicycle racks up high on the Suburban, and maybe carry the greasy BBQ grill and/or nasty tote tank between two bikes up on a roof rack, but I'd rather carry 3-4 bikes on top of a hard truck bed tonneau cover, and the grill and tote tank under it... with the generators. Not as far to lift things.
At 8600 lbs GVWR, the 2500 Suburban is more equivalent to a 1500HD than a 2500HD. Does it have full-floating axles?
The Suburban has quite a bit of overhang for its 130" wheelbase when thinking about stability. Admittedly, it would be a little easier to manuveur in parking lots than a crew cab/short bed.
With the 60/40 front bench seat, my extended cab can carry 4 adults and 2 children, 2 men in the front and 2 ladies in the rear, but those in the rear wouldn't be as comfortable after about an hour as they would with a crew cab. With 2 adults, 3 kids, and a dog, in a crew cab, I'd definitely split the kids up, with one in the front middle, and the dog in the rear middle seats. You can make a PVC frame that sits on the seat, but has legs that go to the floor behind the front seat. The dog can lay down on that between the two kids.
4WD is priceless if you're ever on dew-laden grass, or in gravel, where it helps keep the rear tires from spinning
While I prefer diesel, if I couldn't have that, I'd rather have the 8.1L that hits 440 ft-lbs peak torque at 3200 rpm rather than the 6.0L with 365 ft-lbs at 4000 rpm.
Maurice
Old 07-19-2004, 12:29 PM   #21
Midamrail's Avatar
1975 Argosy 26
Villa Ridge , Missouri
We currently pull with an F-250 crew cab long bed with the 7.3 diesel. We absolutely love the truck but were inches away from trading it in for a new diesel Excursion this week before changing our minds and backing out.
We don't have kids but have large Labradors, and our debate was how best to travel with the dogs. We have a topper on the truck with sliding, screened windows, and we travel with the dogs in the back most of the time. However, when it's really hot, we'd rather have them in the back of an Excursion with rear air than in the back seat of the truck.
But in the end, and particularly with our vintage trailers, we decided that the best solution was to keep the truck and put the dogs in the back seat. We planned ahead and got a truck with leather and then covered the back seat with a cordura cover and put down rubber floor mats to try to deal with the hair. The truck gives us SO much more flexibility in terms of needing to haul "nasty" things we wouldn't want to put in the back of a $50K Excursion, i.e. blue tanks, spare tires, jacks, etc. Many of those items are less of an issue with the newer trailers, but you never know what you'll need or find in the course of a trip. It's also nice to be able to put the dogs back there after letting them swim in a lake or river or if they've gotten muddy on a hike.
Admittedly, the Excursion would have been easier to drive on a daily basis, but we're used to the size of our truck. It only presents a problem in tight parking lots and on really tight turns, and even without kids, we use every inch of it on long trips.
I don't know about the Chevys/GMCs, as it seems the Suburbans and Yukon XLs really hold their value, but in the case of the Fords, the Super Duties seem to retain more of their value than the Excursions. Perhaps it's because there's a larger market for used heavy-duty trucks than there is for used heavy-duty SUVs.
Both Alex, my Argosy, and I are kids from Versailles, Ohio!
Midamrail is offline   Reply With Quote
Old 07-19-2004, 02:54 PM   #22
Aluminut
2004 25' Safari
. , Illinois
Not a bad point when it comes to the generators. That thought had not crossed my mind.
Def something else to consider when looking at a tow vehicle.
Thanks!
Old 07-19-2004, 06:40 PM   #23
Towdaddy's Avatar
2007 34' Classic S/O
Kalamazoo , Michigan
Tow Vehicles
Thanks!
I would add my 2 cents on the pickup. We pull with a F250 crew cab with the 7.3 diesel. It has the short bed and a Century topper on it. I had an Explorer previously (we pulled our Kodiak hybrid at the time with a E150) and I was always having to throw firewood or dirty items inside. It is very nice to be able to separate firewood, generators, fuel and other items into the bed of the truck and still have room for four adults.
The size is an issue and you do get used to it. One recommendation is to get a topper that is no higher than the truck cab. This way you can park in a standard garage or go through a car wash. The only thing I can't seem to solve is when I park away from everyone at the grocery store, why I have always have 2-3 cars parked next to me when I return!
Towdaddy is offline   Reply With Quote
Old 07-19-2004, 07:04 PM   #24
Midamrail's Avatar
1975 Argosy 26
I totally agree on the topper issue. We have a cab-height SnugTop on ours, and I wouldn't have gone any higher. As it is, our 4x4 won't fit in some car washes, garages, and parking garages. But the top is indispensible, and as we all pull Airstreams, having access to the bed for a fifth wheel is a moot point for most of us.
There are select car washes our CC long bed will fit in, and ones I know it won't fit in. And like you, I can never understand how I can pick one of the farthest spots in a parking lot away from everyone else and then come out to find the truck surrounded with cars!
We also have to watch site lengths at the state and National Forest/COE campgrounds, particularly with our 31-footer. The truck and Sovereign together are over 50 feet - almost the same as a semi-tractor with a short trailer.
I do get tired of the, "Hey, little lady, you can drive that big truck?" remarks, though.
Old 07-19-2004, 07:33 PM   #25
Davydd's Avatar
Tonka Bay
Images: 13
Extended Cab vs Crew Cab
I had a 99 Silverado extended cab which is essentially the same as the current Silverado models. The Chevy has the best captain chairs in the front of all trucks in my opinion. The rear seat of the extended cab was the best at the time and could haul three adults comfortably for short period of times. We actually hauled my sister-in-law from Minneapolis to Wyoming and back and she was comfortable. In saying that, I now own a crew cab and love it all the more. The Nissan Titan has the roomiest back seat leg room of all. I carpool a 6'-3" and 6'-5" pair there every day. No complaints.
I recommend the crew cab. It is like comparing a sedan (CC) to a coupe (XC) for comfort. Having four independent doors is a very positive plus. They are more convenient for passengers and for mundane things like loading groceries. You lose a few inches out of the truck bed (mine is 5'-7") but neither CC or XC is going to give you a lay down for a sheet of plywood unless you get the overly long bed model too big to park anywhere comfortably.
Davydd
2015 Sprinter Class B Camper Van
(Former 1971 vintage Airstream Owner)
Davydd is offline   Reply With Quote
Old 07-19-2004, 09:37 PM   #26
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
Suburban, Ext. cab & crew cab
I hear people on the forum giving reasons for why they selected the Suburban over the extended cab or crew cab 1500 or 2500 trucks and the main reason has been for the third row of seats for a bunch of kids or to stow a bunch of gear in the back. The third row of seats is nice IF you need them for more than 3 kids but I don't buy the second reason.
I took a trip recently to the other side of Atlanta from TN. which was 238 miles. Two of my kids went with my wife and myself. My 19 yr. old is 6'1 and 187 lbs. and my 17 yr. old daughter is a petite 5'4". Half way to our destination, my wife and daughter switched seating. My son stayed in the back seat of the extended cab and never complained. A third person in the back seat would probably change that scenario. It wouldn't in the crew cab pickup where you have an additional 10-12" over the extended cab. I got in and out of an extended cab and the crew cab 2500hd back seat more times than I care to admit on this forum to see how my 5'11 1/2" medium frame would handle each. The crew cab was a little more comfortable but in the end I could not justify the extra length since this was my daily driver and I thought it would be a drag. Add that additional large kid, he's 6'2" 170 lbs. to the back seat and I would have gone the crew cab. Add my 4th and last kid 6'2" 190 lbs. and it would have to be the Suburban or somebody's riding somewhere else.
Johnhd previously mentioned that you can put on a truck topper. A good brand would make the area weather tight and a place to secure your items. By the way, do you really want to tote your smelly generator in the back end of a Suburban or in an entirely seperate cargo area away from the kids should an accident occur. I'd rather buy a fiberglass or molded plastic cover from ARE, Snugtop or others and secure my gear that way. This gives me a clear shot of the front of the trailer through the rearview mirror. Why? I don't know but it sure is comforting.
Some of this is opinion but the 2500hd seating capacity between the ext. cab and crew cab was something I had to make a decision over. I made the right choice for me.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Tow vehicle advice needed.... crazylev Tow Vehicles 86 04-27-2007 06:11 PM
"New" Tow Vehicle!!! 66Overlander Tow Vehicles 22 02-28-2006 05:46 PM
What tow vehicle would you suggest? Kistler Tow Vehicles 63 09-27-2005 04:24 PM
Suggestions on new tow vehicle Diana Langley Tow Vehicles 3 07-08-2003 07:31 AM
