Old 04-09-2005, 06:46 PM   #57
Towdaddy's Avatar
2007 34' Classic S/O
Kalamazoo , Michigan
We are pulling a 30' Safari LS with an 01 F250 CC Powerstroke. This is also my daily driver. I get 14-15 around town and 18-20 on the highway. A solid 14 pulling the Airstream.
Diesel is running around $2.30 in SW Michigan - same as regular unleaded.
Jeff
Jeff/Vickie
Air #5970
2001 F250 CC 7.3 PSD 4x4 ("Bubba")
2007 34' SO Classic ("Betty Lou II")
Towdaddy is offline   Reply With Quote
Old 04-09-2005, 07:22 PM   #58
Confused & Wandering
Theo's Avatar
1993 34' Excella
Right here, , where ever I wake up
Send a message via AIM to Theo
I am getting about 11 towing the 34 ft.. This is good enough, I think - It would be a lot less, if I had a motorhome, so I am happy.
Theo
'05 Cargo hauler gooseneck, carrying an '05 Jeep TJ, all hauled by an '05 C4500 Kodiak Truck
Theo is offline   Reply With Quote
Old 04-09-2005, 07:51 PM   #59
Steve Heywood's Avatar
1997 30' Excella
Waddell , Arizona
Images: 13
I just returned from a 5 1/2 day trip from near Sacramento to Houston and return. Enroute to Houston I got a very steady 17.75-17.9 running 72-75 MPH (empty) with a very new (started with less than 1500 miles on the truck) Ford F250 Crewcab with a 6.0L Powerstroke diesel.
On the return trip I was towing my 30' Airstream which weighs about 7,800 lbs. West bound with the trailer I was fighting 25-45 MPH headwinds (Ah yes, spring time in the desert southwest!). My worst tank (worst winds!) was 10.27 MPG running 65 MPH in W Texas. Less wind at 65 MPH equaled 12.45 MPG. In CA (running 60 MPH because of the 55 MPH truck/trailer speed limit) I got 12.96 from the CA/AZ border through LA then to the north side of the Grapevine. My trip computer showed between .2-1.1 MPG better than the calculator. From the N-side of the Grapevine home my trip computer showed 14.1 MPG but I haven't filled up yet.
Steve Heywood
Waddell, AZ
1999 19' Bambi (SOLD)
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 04-09-2005, 07:54 PM   #60
AIR #6370
hmsteader's Avatar
2001 27' Safari
Bella Vista , Arkansas
Post Diesel Power
Stick with the Ford F-250 Powerstroke. The little more one pays for diesel fuel more than offsets the cost and less mileage of gasoline engines.
I run a 2000 Dodge Ram with Cummins 359 ci engine and 4-speed automatic transmissison. Running solo on the highway at 1875 rpm, which is about 68 or 69 mph, I log in at the 21+ mpg; and on rare ocassions 22 mpg. When towing my 25' Excello, fully loaded, I get about 15+ mpg. When bucking an extremely strong headwind, I got about 12+ mpg. The best I've ever gotton was driving idea flatland interstate highways with no wind, and that was a hair over 17 mpg. Oh, I've got about 84K on the truck now; just broken in.
The Good Sam Club recommends that one not run more than 70% of maximum towing capacity. For example, my truck is rated at 9,990 lbs (10,000 lbs). Therefore, I try not to exceed 7000 lbs. Although my previous SOB was closer to 7800 lbs fully loaded.
From the charts I've seen and read, an internal combustion engine with be down to 70% at 7000ft of its rated power. For every 1000 ft beyond that, it will continue to loose another 10% per thousand feet. (Personally, I think if one runs near the top of your engine's torque curve, you can't go wrong.)
So, for whatever this info is worth, take 79 cents and buy yourself a cup of coffee.
Keep the shiny side up. And good luck.
hmsteader is offline   Reply With Quote
Old 04-09-2005, 09:05 PM   #61
North Central , USA
7.3 Power-Stroke Diesel
2003 F250, 2-WD, CC, 7.3 PSD w/'04 25' Safari = 14.xxx (xxx=<.5 ) when all is said and done except for long climbs/high altitudes.
RivetED is offline   Reply With Quote
Old 04-10-2005, 10:41 AM   #62
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
2005 Suburban, 2500, 8.1 liter gasser, 4WD, 4.10 ratio = 11 mpg city not towing, 9.8 mpg towing a 2005 28' CCD (with a case of Guinness in the fridge)
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 04-10-2005, 12:31 PM   #63
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Talking 1992 Dodge 3/4 ton 4X4 Cummins
1992 Dodge W250 3/4 ton club cab 4X4 turbo Cummins diesel with 4 speed automatic OD and 3.54 axles, pickup shell over bed = 19 mpg solo and average 15 mpg towing a 1964 19' Globe Trotter that weights about 3,250 lbs. loaded.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 04-10-2005, 01:00 PM   #64
Images: 59
Does anyone have a Nissan Frontier? The 2005 model has a longer wheelbase (125.9", same as F-150) and a beefier engine (265hp, 284 ftlbs). Tow rating is 6500#. It looks like the Frontier is growing into a half ton pickup.
Would this be a suitable tow vehicle for a 4000# trailer?
Old 04-10-2005, 04:07 PM   #65
Craftsman
Guest
Posts: n/a
2001 2500 Suburban with the 8.1. Averaged 9 mpg on a recent 1500 mile round trip to Georgia. Not towing and averaging 80 mph. Just keeping pace with traffic.
Old 04-10-2005, 06:16 PM   #66
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Talking
2003 Duramax with the Allison transmission. 1977 20' Minuet about 3000lbs loaded to the gills.
These things have a gas milage punishement point at about 1800 RPM or 61 MPH
below that 18.1 MPG empty, 16.8 towing our rig.
Above that and you get 15.7 MPG empty @ 70 MPH and 14.7 MPG towing @ 70 MPH. The faster you go the more it eats, and it goes real fast if you push it.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 04-11-2005, 11:54 PM   #67
Hippo's Avatar
Battle Ground , Washington
Last weekend I pulled our inclosed cargo trailer 20 footer to Ocean Park,Wa with our F250 4X4 Crewcab V-10 gas engine. We averaged 12.0 mpg. The same on the way home. Gas at the beach was $2.47. I filled up at Costco today for $2.29.
Chuck
Hippo is offline   Reply With Quote
Old 04-12-2005, 07:36 AM   #68
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
LOL! I see that one bit of cargo represents most of the major food groups and is a HUGE weight saver! Heck if you had to load food and clothes, you might have only seen 8mpg towing Hut!
Old 04-12-2005, 10:31 AM   #69
58BUBBLE's Avatar
What's the deal with diesel being $2.50/gallon? I drive a 2003 GMC Duramax crew and it costs over $60 to fill up. I usually use 3 tanks a week, (if I'm lucky). I recently picked up a little Toyota pickup to use as my daily driver because of the rising prices. Anyway, I thought diesel was an unrefined alternative fuel to gas meaning, IT SHOULD BE CHEAPER. Out here where I am there are a lot of diesel trucks and it seams like we are getting screwed, the gas companies raise the price on diesel just to keep up with gasoline. Atleast we finally woke up and realized we need to start drilling in Alaska.
58BUBBLE is offline   Reply With Quote
Old 04-12-2005, 11:12 AM   #70
Aluminut
2004 25' Safari
. , Illinois
You're right it should. When I was looking for a new truck I went gasser cause the prices of fuel were getting near the same. In some cases diesel costs more than regular unleaded.
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Tow vehicle advice needed.... crazylev Tow Vehicles 86 04-27-2007 06:11 PM
"New" Tow Vehicle!!! 66Overlander Tow Vehicles 22 02-28-2006 05:46 PM
What tow vehicle would you suggest? Kistler Tow Vehicles 63 09-27-2005 04:24 PM
What's your Gas (or Diesel) Mileage? 85MH325 Tow Vehicles 29 04-04-2004 06:40 AM
