Old 09-21-2004, 06:32 PM   #29
Craftsman
Guest
Posts: n/a
Well said. We went from a Golf TDI that we got an average of about 45 mpg to this gas guzzler. I've done my time for the enviroment after six VW's. and a Saturn: although I did have a Range Rover Cassic for a while as well as a 1975 Land Rover. You cant tow an Airstream with a bicycle. Or can you?
Old 09-22-2004, 11:09 PM   #30
Hippo's Avatar
Battle Ground , Washington
I tow my 25' AS with a Ford F250 4x4 v10 gas engine. Towing on the level I get 10.5 and in the hills 9.5. Without the trailer it gets 15.5.
Hippo
Hippo is offline   Reply With Quote
Old 09-22-2004, 11:34 PM   #31
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I've been thinking of adding a cold air intake and a throttle body spacer. A few places I've been to on the web have indicated about a .5 to 1 mpg improvement and seat of pants folks say throttle response is also up with these two toys. Anyone done either or both that can comment on a truck?
Old 09-29-2004, 01:48 PM   #32
I'm amazed at how little mpg's have improved in almost 20 years for gas engines.
My carburated, 3spd auto, 3.73 '86 2500 Suburban 454/7.4L gets 8.5-9mpg towing 5600lb car hauler, loaded.
Newer ones are getting a tad more than that but I don't have a loan payment or full coverage insurance. I'm curious how toaster drops only 1mpg towing. I get 8-9mpg daily mixed use, and11.5 mpg highway, same as him but only 8.5-9mpg towing at 65mph. I'd be ecstatic if I got anything over 10.0mpg towing!
Whats the secret?
y5e06 is offline   Reply With Quote
Old 09-29-2004, 02:58 PM   #33
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
running interstate speeds I get 12.5 mpg towing a 34' with my old dodge cummings. I can get 22 solo. The ford excursion powerstroke pulling the same rig ( we took a 7000 mile trip together) gets about 1 mpg better pulling hard (rocky mountains) and about 1 mpg less pulling of level ground. I would think that you could get 13.5-15 mpg pulling the safari.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 09-29-2004, 03:03 PM   #34
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
With only 1,600 miles on the odometer I'm getting 11.8 mpg around town and 10 mpg towing my 28' CCD. It's an 8.1 liter, 4.10 gear ratio, 2500 Suburban. No slap, just smooth power.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 09-29-2004, 03:03 PM   #35
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Whats the secret?
I notice big mpg improvements at low altitude and below 62mph.
My mileage drops to 10.5 or so when I go to altitudes over 400ft, and try and keep a speed over 65mph.
Trailering speed limit in CA is 55mph, and the altitude where I usually go is zip, nada, maybe 100ft or so. I get up to 12.5 mpg
Up to 1500ft, nothing changes, then i notice the truck getting slower, and the mileage dropping.
Uwe
www.area63productions.com
Old 09-29-2004, 03:27 PM   #36
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
With my 8.1 Avalanche - I get a consistant 11-12 mpg towing my 75 25' Tradewind. I never go above 62 mph (except when following Uwe ) and I tow in 3rd. Gas mileage drops dramatically above 65
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 09-29-2004, 03:50 PM   #37
Tarheel's Avatar
Images: 21
I get 12.5 pulling a 34' with my Dodge 22 mpg solo. My friend pulled a similar rig with his 454 chevy 4door and got 7.5. He switched to an excursion powerstroke (2001) and gets the same mileage as I do, but with more power than my 92 dodge. Our rigs weigh in just under 10k lbs. I would think you should get 13.5-15 mpg or better
WBCCI # 348
Old 09-29-2004, 04:28 PM   #38
AirConditioner's Avatar
I must be doing something right, I'm just not sure what it is! I'm getting a hair over 15mpg pulling my '72 Overlander with an '04 Toyota 4-Runner AWD, V8, high-test gas, 55mph, sea-level with a few mountains here and there.
AirConditioner is offline   Reply With Quote
Old 09-30-2004, 10:54 PM   #39
Hippo's Avatar
I had a Chevy w/454 1998 pickup 4x4. I put high output plug wires, plugs, dist cap and rotor and a high output spark controller. The truck got about 1 more mile per gallon. Probably a AEM air intake would help.
Hippo
Old 10-01-2004, 08:05 AM   #40
1993 30' Excella
1969 18' Caravel
Lovettsville , Virginia
I agree with sticking with the diesel. I consistently get 12 mpg towing my 30' Excella with my '02 Ford F-350 PSD. The only negative about a diesel that I've found is a lack of engine compression braking going down long steep hills, but I've learned to fine tune my driving habits (lower gear, firm short stabs at the brake) to compensate for that.
takenitez is offline   Reply With Quote
Old 10-04-2004, 11:47 PM   #41
Hippo's Avatar
The wife said if you have to worry about MPH then you can't afford to drive the thing or have any AS fun camping. Her words are sell the thing and stay home. She said she would buy a small motorhome for her and the dogs and I can stay home and stew about MPG.
Hippo
Old 10-05-2004, 06:31 AM   #42
2004 Ford PSD 6.0
The new 6.0 PSD has an amazing transmission that is easily manipulable to get an engine braking effect. We strongly recommend it. Towing our 9100 lb. Safari 28SO we're getting 13.5+; 12.5 in the mountains. Can't recommend it strongly enough. It has great acceleration, runs very smoothly and the noise isn't very bad. We love it.
Tom, and Frank.
Tom and Frank
Evanston, Illinois
2004 Safari 28 ft Slideout "Lucy" 4 HI CAMP
2004 Ford Excursion 6.0 PSD PWRSTRK,
and Brittany, the Nova Scotia Duck Tolling Retriever
PWRSTRK is offline   Reply With Quote
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 09:14 PM
Tow vehicle advice needed.... crazylev Tow Vehicles 86 04-27-2007 06:11 PM
"New" Tow Vehicle!!! 66Overlander Tow Vehicles 22 02-28-2006 05:46 PM
What tow vehicle would you suggest? Kistler Tow Vehicles 63 09-27-2005 04:24 PM
What's your Gas (or Diesel) Mileage? 85MH325 Tow Vehicles 29 04-04-2004 06:40 AM
