Old 06-18-2014, 08:17 AM   #29
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
If you are considering the minivan approach, I would encourage you to contact another member of this forum (MrUKToad.) He lives in southern Ontario (relatively flat) and tows a 25 or 27 with his minivan and is quite happy with it. I have a heavy 27 footer and plan to be on the road a lot and go out west (think Rockies) so I would not consider a minivan, but since you are going to be a weekend warrior and have a relatively lighter unit (the 23) this might work for you. I'm sure there are limitations with a minivan-based setup (such as hill climbing) but MrUKToad can probably help you think this through.
Bob Martel
WBCCI# 5766
Old 06-18-2014, 08:43 AM   #30
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
I haven't contributed to this thread as the OP said that he was after a truck. If the original idea has shifted then yes, I can speak about my experiences with the 2011 Toyota Sienna minivan and our 2011 28' International Serenity.
First off, our TV has had the Can Am treatment with a beefed up hitch, WD, sway control and the works. Also, the TV suits our needs; it's our daily drive and is quite easy on the juice when not towing. We're largely weekenders and do travel very light, even with the kids and don't haul a generator or canoes or firewood or bikes.
AABob is quite right to point out that we're in flat southern Ontario but I don't fear for the Sienna's pulling power; as others have shown, it'll go up just about any hill, albeit that it's not going to win any races doing so. We've towed through the hills in New Hampshire and Tennessee without issue.
I've not weighed our setup when fully loaded but I know that it has a high tongue weight, which gobbles up a big chunk of the payload. That said, apart from people, we don't haul much stuff in the van so even if we're close to the limit, or even slightly over it, it's not caused us any problems.
The Toyota published tow limit is, in my view, a red herring. When set up and loaded we sit level, pull and stop comfortably and handle as well as anything else towing a few tons of trailer. The Sienna is low slung, wide and handles well, even when braking. Over three and half seasons we've had no mechanical issues with the TV and reports from my local Toyota dealer don't highlight any abnormal wear during the service schedule.
The issue as I see it is not with the numbers but your use of the TV. If you're going to haul those heavy and dirty items like a generator or firewood, then a minivan won't be for you. If you do travel light and you want a TV that is reasonably economical when not towing, then maybe a minivan will suit your needs.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 06-19-2014, 08:02 PM   #31
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
MrUKToad, Thanks for contributing. A while back I read a fair amount of your blog (old and new) and that was one of the reasons I had considered the Honda in the first place.
Taking everything into consideration, I pulled the trigger on a 2012 F-150 5.0 V8 with the 7350 GVWR package (over 1600 lbs of load capacity) and an integrated brake controller. Only thing I would have liked would have been the 3.73 rear instead of the 3.55, but I think the 3.55 will do.
Took the truck home today.
Now I need something to tow!!
SCOTTinNJ is offline   Reply With Quote
Old 06-20-2014, 05:23 AM   #32
N/A , N/A
That's a good pick. Seems the 5.0 V8 will get you roughly the same MPG as an EcoBoost engine, yet the engine is not turbo, and hence with fewer components should be more reliable (Good idea to stay away from the cutting edge technology until the glitches are fixed). You also have more payload that a minivan (and a longer wheelbase), and less of an operational cost than ML350.
rostam is offline   Reply With Quote
Old 06-20-2014, 08:37 AM   #33
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Yes. I hope so!
The 5.0 is a pretty proven engine from what I read. Plus it's a 6-speed tranny which may very well prove to be one of the last repairable transmissions. I understand that the newer 8 speed+ transmissions cannot be rebuilt. They go, so does a huge chunk of change.
Excuse the poor cellphone picture, but here she is. Beauty if you ask me.
Old 06-20-2014, 09:08 AM   #34
N/A , N/A
Looks great. Congrats!
Old 06-20-2014, 09:10 AM   #35
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
You'll do fine with the 3.55, after lots of reading there are plenty of folks who don't see much of a slow down. It's a very mild difference between 3.73 & 3.55, not the same as 3.55 vs 4.10.
Nice choice of truck there, with the payload you should be good to go.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 06-20-2014, 09:59 AM   #36
Chelsea , Michigan
Images: 12
You can never go wrong with a Ford truck!
Bob Martel
WBCCI# 5766
Old 06-20-2014, 11:13 AM   #37
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Haha. Yours is like the big brother of my truck.
Old 06-20-2014, 11:33 AM   #38
Nomadic , USA
Except for when it's Found On Road Dead. Just make sure you Fix Or Repair Daily.
Old 06-20-2014, 08:24 PM   #39
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
I hope you aren't speaking from experience...
Old 09-03-2014, 10:39 AM   #40
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Reporting back, we just finished our first trip with the new Airstream (25' Flying Cloud) and the F-150. 2,500 miles from New Jersey to Arkansas and back.
The 5.0 did admirably. Could I have used more power on some of the roads, particularly in the Asheville, NC to Knoxville, TN area - yes. But who wouldn't say that?
Returned 12.5 MPG for the trip. Pretty consistent too. Highest I saw was the run from Hershey Park in PA back to Jersey, 13.2 MPG. Favorable tailwinds I suppose.
2013 Serenity 23D Interior Efficiency adiben 2011 - 2015 International 27 08-19-2017 08:50 PM
New orners: 2013 Int Sig. 23D Rrrobertskit Member Introductions 8 06-23-2013 01:56 PM
2013 airstream 23d flying cloud premium travel trailer brand new! eBay Watch Airstreams on eBay 0 06-06-2013 01:20 PM
2013 airstream 23d flying cloud premium travel trailer brand new! eBay Watch Airstreams on eBay 0 05-27-2013 06:40 PM
New 2013 airstream 23d flying cloud light weight air stream travel trailer eBay Watch Airstreams on eBay 0 05-15-2013 03:50 PM
