Old 01-06-2007, 08:29 AM   #1
Boondocker's Avatar
Profile:  1968 24' Tradewind
on the road , walking to and fro about the earth
Airstream Registry
Send a message via Yahoo to Boondocker
Tow vehicle electrical problem
My 1991 F150 (302 engine) is loosing charge on the battery. I have replaced the battery and the gauge for the alternator is reading in the normal area albeit on the lower end (on the N and O to be precise). What is the next step? Ideas? This is also my daily driver so I need to get this one worked out soon.
Rodney
Visit my photography page
or my travel site: theboondocker (new) or the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is online now   Reply With Quote
Old 01-06-2007, 08:40 AM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Airstream Registry
Test the alternator with an external amp meter to determine if it is putting out a sufficient charge to keep the battery up. If that checks out, take the battery and have it checked. Sometimes even a brand new battery could have a bad cell.
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 01-06-2007, 08:45 AM   #3
Profile:  , Minnesota
Images: 59
Airstream Registry
If you haven't replaced the serpentine belt lately, now would be a good time.
Old 01-09-2007, 10:35 PM   #4
Profile:  1960 24' Tradewind
santa barbara , California
rodney ,sounds like your alternator is not charging .If you turn your ignition key to the on position (not cranking not running ) just so your gauges and stuff come on ,look at your gauge noting its position ,then start it ,does the needle move higher? if it doesn't ,alternator is not charging .Really
you need to have the running voltage checked at the battery and alternator
if its battery voltage when running ,not charging .A poorly charged battery
can cause your volt gauged to read low ,yet its charging some .Even if its new .According to you N and O of the normal on the gauge it sounds like its not charging ,could be alternator time .Id also suggest Napa as a good source
for the part.
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 01-10-2007, 04:49 AM   #5
steelbird312's Avatar
Profile:  1989 29' Excella
1956 22' Safari
Crossville , Tennessee
Images: 11
Rodney,
All good suggestions, some for maintenance, some for troubleshooting, however, Scott is right on. If you don't have all that available, you can start the engine, and then unhook the ground cable from the battery. If it dies, it's the altenator. If it continues to run, then it is the battery. By all means, Scotts's suggestion for NAPA is good. If you live in the south, Auto Zone sells a lifetime altenator, and they don't haggle when you take it back. I did it not more than 4 months ago.
FOR ANYONE READING THIS, DO NOT DO THE ABOVE TEST WITH A GM PRODUCT_IT RUINS THE BUILT IN REGULATOR.
This is a simple remove/replace situation.
Now, if you think something is staying on, or that there is a short, get a cheap 12v test light. Go to the fuse box, and pull the fuses one at a time. If the light burns when you test across the two fuse receptacles, unless it should be pulling power all the time (computer, brain for sound system, clock etc) then you have found your drain.
Good luck.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 01-10-2007, 07:26 AM   #6
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
Good luck.
Do not do this with that alternator, either. It also has an internal regulator, and will suffer the same fate as the GM alternator.
On that vehicle, they had a tendency to melt the connector plug where it plugs into the alternator. Check the inside of the plug when you take it off. If it looks warped, distorted, or charred, make sure you replace the plug with a new one (you can get it at Napa).
(No Longer at Inland RV)
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
introduction // need help deciding tow vehicle jmeredith Our Community 9 09-29-2002 05:39 PM
On The Road-Expedition as a tow vehicle Princer On The Road... 2 09-23-2002 06:43 AM
The QUEST for 20-25 Miles Per Gallon Mr Jody Hudson Tow Vehicles 32 08-04-2002 05:16 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
