08-10-2017, 10:30 AM
#61
Vancouver
, British Columbia
Originally Posted by lynnsr
Is any one using a tow Vehicle (Diesel) that is quiet, with no diesel smell?
I'm looking for a new TV.
Lynn
In my experience (had several diesels) they are much quieter than they used to be. Still noisier than a comparable gasoline engine. But quiet is a relative term.
The smell is still there, but it isnt so much exhaust these days as refuelling. Some wear disposable gloves.
08-10-2017, 05:33 PM
#62
some town
, PA
First trip in Big Blue today. 230 hilly miles, a mix of highway and back roads. We averaged 18.4 MPG. I thought that was pretty good for a new engine.
08-10-2017, 05:43 PM
#63
2016 28' International
Long Beach
I believe the GMC has triple insulation that makes the cabin quiet - I have no complaints and am sensitive to repetitive noise. I would also recommend a diesel. I had a gas 1500 Chevy Suburban and it was a bummer on the hills and if I needed to accelerate to pass someone.
The Wood Family
Mike Lisa & Aidan
2016 International Signature 28
2017 GMC Denali 2500HD Duramax Diesel 4X4 Crew Cab Z71
WBCCI #21506
08-10-2017, 06:50 PM
#64
Seattle
My 2016 Silverado 1500 is very quiet inside, so I imagine this one is too. GM has made lots of improvements since 2015 to the interior fit, finish and sound isolation of their truck interiors. I’m very happy with my truck.
08-10-2017, 07:37 PM
#65
some town
, PA
This is my first Chevy truck but I can say that my 2500 diesel is very quiet on the road. Even outside the truck with the engine running is not loud at all.
08-10-2017, 10:57 PM
#66
Cloudland2
2016 25' Flying Cloud
Trenton
, Georgia
Payload capacity
Philly, just curious as not familiar with GM 3/4s. What is the payload listed on the driver's door pillar?
Thanks!
Dave
08-11-2017, 07:28 AM
#67
Anna Maria
Diesel smell and noise sounds rather retro to me. About twenty years ago.
Today's diesels are no more noisier than the rumble from any high performance car. As to the smell, gasoline is not exactly odorless either. Ever get some on your hands ? It stinks just the same.
I spent over 40 years of my working life around diesel engines. I kind of like the old time smell of diesel engines and the rumble early in the morning. I look at gasoline driven things as kind of puny wannabes.
08-11-2017, 07:39 AM
#68
2018 33' Classic
Newport
, Pennsylvania
Diesel way better than gas
Earl
08-11-2017, 02:19 PM
#69
Long Beach
Mine is super quiet I remember reading about the extra sound insulation in the sales brochure around the doors, never smelled anything exhaust wise even when idling while hooking up.
The Wood Family
Mike Lisa & Aidan
WBCCI #21506
08-11-2017, 04:09 PM
#70
2007 28' International CCD
Springfield
, Missouri
Drive a new diesel from GM or Ford and see for yourself.No diesel smell and extremely quiet.And they have more pulling power at idle speed than most gas engines at 4500-5500rpm.Not all applications require a diesel but if you are pulling a larger trailer they are a good choice.
08-11-2017, 05:06 PM
#71
Tampa
Originally Posted by VernDiesel
My lil 3.0l economy diesel is made by VM Motori and is holding up fine after 340,000 plus towing TTs daily.
I just had to interject because the post was so off base.
Wow! Good for you. I had to look up VM Motari and discovered it's an Italian diesel made by Fiat (currently) 340,000 Miles? You might hold the record.
I owned a Fiat. Once.
Then I see your sig is Vern Diesel so I guess I should have expected a diesel fan.
My post was so far off base? Sorry, but I have broad shoulders, I can take it.
08-11-2017, 05:16 PM
#72
Vancouver
, British Columbia
Originally Posted by Moflash
Drive a new diesel from GM or Ford and see for yourself. No diesel smell and extremely quiet.
Yes, the extra sound insulation is required because the engines are noisier. The manufacturers well understand this. It is easily measurable, it isn't a debate. And note that the sound insulation only addresses the noise in the cab, not that heard outside the vehicle.
My comment about exhaust was that you won't notice the smell on a modern diesel (unless of course you are a pedestrian or cyclist, then it is often noticeable, but more the particulates than the smell). The smell that you can't get away from is when refueling. But you can wear gloves if necessary, that helps. They are there at the pumps for a reason.
08-11-2017, 06:47 PM
#73
Springfield
, Missouri
Actually you are incorrect on the exterior noise level (these are very quiet engines compared to the older versions) and smell and I do not get diesel on my hands when refueling.
Another negative and derogatory comment from someone who evidently has not owned or driven a current platform diesel.....
Please post the emissions stats and sound decibels generated at idle and highway speed for a 2017 6.7 diesel compared to your current personal tow vehicle.We would all be interested in learning the difference.......
Gasoline due to it now being mostly chemical additives (now clear)and not all Dino fuel (was pink)anymore is actually harder to wash off than diesel fuel due to its current low emissions hwy refining process and formula.
08-11-2017, 07:36 PM
#74
Vancouver
, British Columbia
I fully agree that these engines are quieter than earlier versions. I posted so. They just aren't as quiet as gasoline engines. That is why people regularly post things like "quiet for a diesel". It is why manufacturers spend the money on additional sound insulation. It is why so much money is being spent developing injectors with multiple injection events, managing the engine noise. If they would just reduce the compression ratio and use a spark plug, they could get them as quiet as a gasoline engine. But then they wouldn't get the other benefits of a diesel engine.
I am happy for you that you don't notice the fuel smell when refuelling. Despite your experience, fuel suppliers spend money giving away disposable gloves to manage this concern. Maybe they are all wrong. I know that with my diesels, my spouse didn't want to refuel them. After my owning several diesels, she just wasn't interested. And it wasn't a capability issue, she has driven everything up to 100 ton capacity off-road trucks.
I am happy you like your diesel. I don't have a current diesel pickup, but have driven many. I also worked with diesel equipment and trucks for decades, and that included conducting witness tests and customer acceptance tests that included sound pressure levels. I got to work on the development of next generation power trains (engines that aren't out yet, so newer than current platforms). Noise was an interesting one, as the company was developing dual fuel systems that, as a byproduct, had less noise due to the use of multiple injectors. It beat multiple injection events. Watch for them in future products.
My current tow vehicle has an inline six gasoline engine. It isn't a pickup. And so is irrelevant to the discussion. We are discussing noise, smell, and now emissions of diesel vs gas engines. You should know the figures, they are generally available. When you find figures that show lower noise for gasoline engines than diesels, let us know.
It is nice that you like your new pickup. But perhaps you could consider the basic facts and features associated with different designs without trying to make it personal, or feeling that your choices are being threatened. It doesn't help the poster who asked the question.
08-11-2017, 07:47 PM
#75
Vancouver
, British Columbia
Another negative and derogatory comment from someone who evidently has not owned or driven a current platform diesel......
The smell I referenced was not exhaust, but during refuelling. I was unaware that current platform diesels don't actually use the same diesel fuel and diesel pumps as previous platforms. It is amazing the things you learn from experts on the interwebs.......
Quick poll for you. How many diesel engine owners use gloves when refuelling? How does that figure compare to gasoline engine owners when refuelling? More, or fewer?
08-11-2017, 08:24 PM
#76
2018 27' International
Southeastern MI
, Michigan
Lol. Ummmm no they don't. They are nice though!
08-11-2017, 08:27 PM
#77
Southeastern MI
, Michigan
Huh?
Actually both smells last all day on your hands. And it's all Dino fuel. Gas is just a different point in the refining process.
This thread is awesome
08-11-2017, 08:55 PM
#78
Springfield
, Missouri
Tow vehicle comparison...opinions wanted!
Originally Posted by Countryboy59
Huh?
I have a friend that was a senior chemical engineer for Exxon Mobil who's job had been to create fuel blend additives for many years.He explained that with the additives they can take 1 gallon of Dino fuel and make 3 gallons of today's gasoline and that is why the fuel is no longer pink as it was until the 80's and is now clear.He also stated that the chemical additives make it much harder wash off than the Dino fuel we used to know.The gasoline that we are currently burning is mostly a blend of chemical additives.We first met when he bought a new Lamborghini from me and we became friends over the years.
08-11-2017, 10:13 PM
#79
some town
, PA
Thanks!
Dave
Here is my payload info.
08-11-2017, 10:26 PM
#80
2022 25' Flying Cloud
2015 30' FB FC Bunk
2012 25' FB Flying Cloud
Golden
Congratulations!!
2022 25RBT FC, 50A Dual AC, Awning Package, 270W Solar, Convection Microwave. Ceramic Coat, Grand Lounge, 3" Lift, 16" Michelin RIBs, Multiplus II, Battleborn 400A, MPPT 100/50, Orion-TR 30, EasyStart (2), Easy Touch, AirKrafters jenRack, Onan 2500i, Truma Aquago Confort, Starlink, Pepwave, Parsec
