Old 03-08-2004, 06:31 PM   #1
crazylev
LEV ZEPPELIN
crazylev's Avatar
Profile:  2004 19' International CCD
Chicago , Illinois
Tow vehicle advice needed....
Greetings.
Let's just say hypothetically I was looking for a replacement TV for the VW Eurovan sometime, but not real soon, as I don't want be living at a storage facitlity with our new AS. Just looking for ideas, not trouble...
What would be your choice of a new tow vehicle for the 'ol crazylev? Here are my perameters:
1. I'm thinking SUV, but the wife doesn't like 'em on principle, so a truck is not out of the ?
2. Though the VW Toureg is really cool, the 40-50k seems to high, which brings me to:
3. I'm thinking of either Ford or Chevy. Parts and repair places seem to be more accessable if your are stranded in the middle of Utah than with a VW.
4. Maximum length can not exceed 17 feet (204") so I can get it in my garage. Can't be wider than 7 1/2 feet.
5. Should have enough guts so that if we upgrade to a 25-28 foot trailer, I don't have to go shopping for another tow vehicle.
6. Keep in mind that this would also be my main driving vehicle in Chicago.
7. I can assume that I would be looking at an 8 cylinder something or other, right?
8. It will be just my wife and I in the vehicle 90% of the time.
9. What sort of power am I looking for?
Any and all suggestions greatly appreciated.
I've got to go hide now.
Jonathan
I'm out of my mind right now, but will be returning shortly......
crazylev is offline   Reply With Quote
Old 03-08-2004, 06:42 PM   #2
Big Dee
Big Dee's Avatar
Profile:  2004 30' Classic
San Jose , California
Images: 24
Crazylev,
My advice would be to test drive the big three BUT be sure to test drive GM's Quadrasteer. I would bet the ranch that it will take only one testdrive to hook you. Like they say "quadrasteer is the biggest advance in towing since the WD hitch."
And driving the streets of Chicago, you will want nothing else. It is simply awesome!
"It's the journey."
NorCal Spring Rally, Casini Ranch, April 10-12 2009
NorCal Summer Cararally, Lassen to Lava Beds, August 5-9 2009
Click here for rally info.
NorCal Fall Rally, Jackson Rancheria, October 2-4 2009
Come rally with us.
Big Dee is offline   Reply With Quote
Old 03-08-2004, 07:24 PM   #3
Silvertwinkie
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Northern Suburbs , Illinois
You could try a Trailblazer with a V8...the wheelbase is not that long for a longer coach...but look at what I'm doing...so I'm no one to really throw stones, however the SUV does have a higher center of gravity. The Trailblazer V8 is a great SUV, wouldn't be my first choice, but beats your current VW hands down. The other VW you mention, as you know is very pricey and frankly I wouldn't tow more than a 22' coach with it, so if 25' might be in your future, I personally wouldn't consider it.
On paper the V8 Trailblazer could even tow a larger coach and it might fit your specs.
In the end though, I don't subscribe to the V6 towing large coaches. I believe a V8 should be considered standard equipment when towing larger than a 19'...maybe if I reach a 22'.......
Eric
Old 03-08-2004, 08:01 PM   #4
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
The Chevys
Unfortunately the Trailblazer that you can get the V8 is the extended model that is 207" long. A better bet would be a Tahoe. It is 199" long and can tow more than the Trailblazer and comes with a V8. I have the I-6 engine in my 197" long Trailblazer and it is rated to tow 6,200 lbs. so theoretically it should pull my 25 ft. Tradewind with a dry weight of about 4,300 lbs. It just doesn't feel that heavy duty enough to me for the long haul or in the mountains. I think the Tahoe is a helluva an SUV.
But, I have my desires set on the Chevy Avalanche--the SUV/TRUCK hybrid that one reviewer dubbed a SU/CK. It is the same length as the Suburban (221") but shorter than a Silverado extended cab truck so would not fit in your garage. If I go the 2500 I could get a tow rating of 12,000 lbs. That should pull any Airstream.
Davydd
Pleasure-Way Plateau Sprinter B Camper Van
2004 Nissan Titan LE Crew Cab
(Former vintage Airstream Owner)
http://www.tonkawoods.com
http://www.porktenderloinsandwich.com
Davydd is offline   Reply With Quote
Old 03-08-2004, 09:50 PM   #5
j54mark
Profile:
Crazylev,
The Tahoe might barely fit in your garage, as will the Durango, and both might, MIGHT just barely tow a new 28' Airstream (it will be marginal, though), but both of those look an awful lot like an SUV to me.
For a guy who finally wants to move up from a Eurovan, doesn't want a SUV, and has to stay under 204" in total length, there is really only one option: a Mercedes Benz Sprinter van, now sold under the Dodge label. 196", turbo diesel engine that will seem like a hot rod to a Eurovan driver, 30 mpg, and 5,000 lb. towing capacity.
Granted, its not going to pull your hypothetical 28 footer, but nothing that will fit in your garage is really a good candidate.
Mark
Old 03-09-2004, 01:11 AM   #6
jjonesnc
jjonesnc's Avatar
Profile:  Cary , North Carolina
Images: 8
No more than 20lbs per square inch in a gas motor. The transmission is the BIG issue. I had a Dodge Ram 1500 5.9 (360 CID)
360x20=7200lbs
The engine pulled my 1980 31' AS just fine BUT the 1500 series trans got COOKED. The 360 in the 1500 and 2500 series Dodge trucks is the same, the 2500 has better gearing in the rear end for towing and a much heavier trans.
If towing alot especially in summer, a trans cooler of at least 6 passes and regular transmission flushes and services are a MUST. I say flushes AND services because a "service" usually means just dropping the trans pan and installing a new filter/screen, new gasket on the pan and topping off the fluid which means only about 20-30% of the fluid is replaced. The fluid up in the torque conveter and valve body stays in whereas with a "flush" ALL the fluid is replaced.........
Also the rear wheel bearings will cook on a 1500 series (half ton) tow vehicle. 3/4 and 1 ton tow vehicles really are a must when towing the bigger campers.
jjonesnc is offline   Reply With Quote
Old 03-09-2004, 08:20 AM   #7
DreamStream
DreamStream's Avatar
Profile:  2005 19' Safari
West Palm Beach , Florida
Crazylev,
IMHO, the best choice that conforms to all your specifications is the newly updated 2004 Dodge Durango SUV. At 200.8 inches OAL, it will fit in your garage. It has a respectable 119.2" wheelbase and when ordered with the tow package, Hemi V8, and the right rear end ratio, it will have plenty of guts to haul your 25 to 28 in the future. In the April 2004 Car and Driver magazine, a Dodge Durango Limited just won the large SUV shootout beating out the Chevrolet Tahoe Z71, the Ford Expedition XLT, the new Nissan Pathfinder Armada SE and the Toyota Sequoia SR5.
OR
With a small 2' extension built on to your garage ...
I would recommend the Dodge Ram 3500 Quadcab single rear wheel pick-up with the Cummins high output turbo-diesel at only 228" long.
Stephen & Miriam
2005 Bambi Safari 19 LS with Sofa
2006 Harley-Davidson Road King Custom
2005 Dodge Ram 3500 CTD QuadCab SRW Long Bed
Sir Wooferman Wellington, Cock-a-poo Watch Pup
DreamStream is offline   Reply With Quote
Old 03-09-2004, 10:21 AM   #8
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Thank you all for your input. I went to the Chevy website and there was a pull down menu for their trucks, and their had to be 150 different option packages...my head is spinning.
In the long run, I'm thinking an SUV would be more practical, and fit in the garage, as well as parking spaces in the city. Got to convince the honey, though.
I do have to make this point: I come from a family that has always bought into the German engineered "quality" concept. It seemed that American products were just built shabby. In fact, I went over to a Ford dealer not to long ago and looked at the new F150. When you close the door on that thing, the whole side of the truck shakes!
You also pay through the nose with the european stuff.
The Avalanche also interested me, because of it's half and half status, but it sounds like it woiuldn't fit in the garage.
As far as the Sprinter, I don't think I would consider another van. Just don't need that much of a vehicle.
The Trailblazer and Durango sound like they would meet the high standards of contributors to the AS Forums...and what ever we decide it is definately going to be an eight cylinder+.
Old 03-09-2004, 12:17 PM   #9
norbert
norbert's Avatar
Profile:  1993 30' Excella
chicagoland , state of confusion+north of cheddar curtain
Images: 24
crazy,
im a ford man myself....rather then accept my suggestion, here is a spot for you to go to....
www.trailerlife.com/
norby
ps, im reediting this i hope it works
Illegitimous noncarborundum(dont let the bastards wear you down)
The only true nobility is found through giving good food to your friends- Anton Careme
beauty is in the eye of the beerholder-cosmo fishhawk
if something is too good to be true, its usually gone before i get there-mister boffo
norbert is offline   Reply With Quote
Old 03-09-2004, 12:46 PM   #10
Davydd
Davydd's Avatar
Profile:  Tonka Bay
Images: 13
Consumer Reports magazine just came out today and is now ranking American cars higher than European but still under Asian.
Davydd
Old 03-09-2004, 01:18 PM   #11
ColtSAA45
ColtSAA45's Avatar
Profile:  Golden Valley , Minnesota
I have a Yukon Denali that I like alot but I am interested in the Nissan Titan.
2004 Nissan Titan
The Titan, Nissan's first entry into the full-size truck category, is built on an all-new pickup platform, featuring a newly designed 300-plus horsepower Nissan Endurance 5.6-liter DOHC V8 with a torque rating of more than 375 lb-ft. The new Titan also offers a standard 5-speed automatic transmission and a towing capacity of up to 9,400 pounds. Titan will be available in both King Cab and Crew Cab models with a choice of 2-wheel and 4-wheel drive. The Titan Crew Cab model will be shown for the first time at the New York International Auto Show in April 2003.
The new Titan, which was conceived, developed, styled and engineered primarily in North America, will be assembled at Nissan's new $1.43 billion manufacturing facility in Canton, Miss., with its Nissan Endurance V8 assembled on an all-new line at Nissan's advanced engine production facility in Decherd, Tenn. The new Titan is scheduled to go on sale at more than 1,100 Nissan dealers nationwide in late 2003.
Charles
1979 Avion Model M 28'
2005 Ford F-150
1962 Land Yacht Safari 22'--sold
1999 Yukon Denali Silver--sold
ColtSAA45 is offline   Reply With Quote
Old 03-09-2004, 01:40 PM   #12
RoadKingMoe
RoadKingMoe's Avatar
Profile:  2001 34' Limited
Beavercreek , Ohio
I'd want at least 130" wheelbase for potentially towing a 25-28' trailer in the future.
Maurice
AB8XA
WBCCI 5446
The Long, LONG Trailer
Old 03-09-2004, 04:03 PM   #13
1985air345
airstreammotorhomes.com
1985air345's Avatar
Profile:  Charleston , West Virginia
The Nissan Titan would be great for 25' units but not for the new 28' units due the the hitch weight of the 28' units. See the other thread about the Titan. I looked at the Crew Cab. NICE! Lots of power. Probably the nicest 1/2 truck on the market.
Nissan Titan
Fred H.
No Airstream Anymore..
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 03-09-2004, 04:05 PM   #14
crazylev
LEV ZEPPELIN
crazylev's Avatar
Chicago , Illinois
Greetings.
Did a little research, and it is looking like the Chevy Tahoe LT with a V8 might just be the beast. The LT come pretty loaded, but then again it is listing at over $41,000. The LS model has a V6 engine.
Any Tahoe owners out there that can share your experiances???
Jonathan
