Old 04-10-2018, 08:27 AM   #29
2016 28' International
Sioux Falls , SD
Originally Posted by pteck View Post
-snip- There's very few diesel engines that make over 400hp, and only the very top shelf ones do. While there are many many gas motors that make over 400hp. Practically any 400hp+ gasser will get to the top of the hill before that diesel -snip- I'm from the SUV crowd. I don't believe you diesel guys really understand what your missing in terms of ride quality, maneuverability, and turbine smooth pulling power you can find in a modern SUV or 1/2 ton.
Understand that ANY motor below 52xx RPM is generating more torque than HP. Above 52xx the HP takes over as the ďpulling forceĒ.
Diesels rarely go above 5k RPM and new ones make over 800 pd-ft of torque, DOUBLE any gas. They pull far more and with greater ease. There is a reason big rigs do not run on gas.
I will give you the SUV / or 1/2 ton is more comfortable in ride. However, if you look at most people with diesels, they HAVE TOWED with smaller then upgraded. Many of those that thump the smaller TV drum have NEVER towed with a diesel truck. Until you do, you will never know why so many have upgraded.
No one ever said it wonít work with a smaller TV.
Diesel truck owners just know it can be done much easier.
2016 Int. Signature 28' w/ ProPride 3P-1400 Hitch
Mich. LTX w/ 16" Sendels, Centramatics
2017 Ram 2500 4x4 Diesel, CG1800 Bed slide, Leer topper
Better to live one day a lion than a lifetime a sheep. Camp hard, camp often
DBinSD is offline   Reply With Quote
Old 04-10-2018, 11:08 AM   #30
2012 19' International
Southeastern MI , Michigan
Originally Posted by DBinSD View Post
Understand that ANY motor below 52xx RPM is generating more torque than HP. Above 52xx the HP takes over as the “pulling force”.
There is a difference in gear ratio between the two. 400 hp is 400 hp. Torque is more fun but power and torque are two different units of measure. One doesn’t “take over” above a certain rpm. 5252 is a multiplication factor, using torque and rpm, to determine an engine’s power output.
Torque can be multiplied with gears. Power cannot. Gas engines have a lot lower cylinder pressure and do less work per revolution of the crankshaft. Hence more revolutions per minute to pull a given load at a given speed. Torque of an engine is measured at the crankshaft, before the converter or transmission. It is a twisting force, hence the term “foot-lbs”. Horsepower is lb-ft per unit time. Two completely different units. You need one to have the other.
With that said, the diesel version of my truck has quite a bit more power than the gas engine I have.
Countryboy59 is offline   Reply With Quote
Old 04-10-2018, 11:27 AM   #31
Sioux Falls , SD
5252 is the RPM at which most engine power bands cross over and has nothing to do with gearing.
An engine designed to rev Above 5252RPM the HP will ALWAYS exceed it’s torque value after that RPM. Thus above 5252 rpm (gasser going up incline) the HP does take over.
Yes, I do know they are different.
Old 04-10-2018, 11:30 AM   #32
Sioux Falls , SD
Additionally, if the motors designed max rpm is less that 5252 rpm (Diesels) it's torque will ALWAYS be higher than its HP.
In an engine, you can NOT have HP WITHOUT torque but, it CAN have torque WITHOUT HP.
Old 04-10-2018, 11:48 AM   #33
Ayr , Ontario
Originally Posted by LessOrdinary View Post
We are looking to buy an AS 27í or 30í Flying Cloud or Classic. What type of tow vehicle should we get? We are considering Ford F-150 or F-250 and Chevrolet Silverado 1500 or 2500. Car dealerships have advised us to get the bigger of the two models. We will be driving all over the U.S. all year long.
All advice and opinions are welcome and appreciated on the tow vehicle and model of AS. Thanks!!!
You obviously need at least an F350 or 3500. Nothing else will do. Just to be sure get the F450.
gator.bigfoot is offline   Reply With Quote
Old 04-10-2018, 12:06 PM   #34
2015 30' FB FC Bunk
Point Pleasant , New Jersey
2 things I like about my diesel truck.
1. Exhaust brake. Makes stopping way better in my opinion. I have driven my sister gasser F350 and her SOB trailer and its night in day difference and not for me.
2. Diesel lanes to fill up. Some places have the nice RV lanes but if not the trucker lane is fine by me. Don't have to worry about navigating a busy fuel island and cars going in every direction. So with a 36 gallon tank the kids/wifey usually need a pit stop before I need fuel.
thoreau2104 is offline   Reply With Quote
Old 04-10-2018, 09:58 PM   #35
2007 27' International CCD FB
San Diego , California
t
Countryboy59 is spot on. While an interesting observation, there is nothing truly special about 5252 that you're making it out to be in regards to power.
You know how as a kid we learning about multiplying anything with 0... equals 0. That's your beautiful 800 ft lbs of torque without rpm. 0 big fat horsepower. It's towing nothing and going nowhere.
Torque only make power (hp) when allowed to act through a distance (rpm). So while diesels can't spin as fast, they do need to spin! Just that their torque band is very narrow relative to gassers, so their torque falls off early.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
pteck is offline   Reply With Quote
Old 04-10-2018, 10:09 PM   #36
I have no argument that one has to use the right tool for the right job. For a larger AS, say 30ft+, it's not only about the motor. We agree that one has to have a vehicle with the right motor AND structure. Yet that also means that a little Ecodiesel under a Jeep won't do the job.
Some people here, when they say diesel, mean the big hairy chested 3/4 ton diesels. Yes, they are badass. Yet others start thinking their baby diesel (without any engine brake equipment I might add), might do the job too. And because they make 400+ ft lbs, while making barely a bit of hp over 200, will out tow a big block gasser. And that's why we run in circles.
Old 04-11-2018, 08:34 AM   #37
Sioux Falls , SD
LoL
An "observation" ? You are arguing and call it an observation? It is a mathematical given FACT. ANY engine that is designed to exceed 5000rpm will have torque overcome by horsepower at THAT RPM. It does NOT change! Keep in mind...it is just math.
Just the same fact applies to when I said an engine designed for lower RPM will ALWAYS have the highest output as TORQUE not HP.
Additionally, my example of torque without HP illustrates the separate but combined relationship. Torque is what is measured, HP is what is calculated, from that torque.
Feel free to disprove the torque / HP crossover @ 5252 RPM given. I'll wait
Old 04-11-2018, 11:50 AM   #38
t
Torque is a force measurement. It is static. Force applied at a speed to do work is power. Itís a tough concept for non engineers. Itís like volts and watts. I gave up trying to explain it to people after I got out of college, and that was a long time ago.
2018 International Serenity 27' FB
Michelin 16Ē tires
Hensley Arrow hitch
Tow Vehicle: Ram Laramie 2500 crew cab, Cummins 6.7 Turbodiesel
Old 04-11-2018, 12:37 PM   #39
Yup. Hard for layman to not conflate the different parameters.
Which is why marketing is such an art. Have to talk about things at a digestable level. Like keeping it to peak torque and HP. Big number must be mo better.
Old 04-11-2018, 02:09 PM   #40
Sioux Falls , SD
Conflate? Even though above, I stated the SEPARATE yet combined relationship in an engine? OKAY
Perhaps your "understanding" of the applied concept is not good enough to explain to such low lives, would be my assumption?
While being a "engineer" you lack the applicable understanding of gas engines Torque/HP cross -over and dismiss the RPM of 5252 as an "interesting observation" all while still thinking that HP does not take over past that RPM? EVEN using YOUR OWN examples (Titan XD video) I pointed this out to you!
Perhaps you need it feed to you at a more digestible level?
P.S. I am still waiting
If you would like to continue to try and disprove what I have said above then do so, with a fact! Instead of trying to impress us (ASSumed) low life, concept conflating, laymen mortals with how much you think you know.
Otherwise, lets move on hopefully without stooping to insults again.
Old 04-11-2018, 03:04 PM   #41
You're out of your element and arguing the wrong thing. I don't owe you any explanation on the "magic of 5252". I've said enough and you've proven that you're only looking to argue. So I'll bow out and let you figure that out yourself on the internet.
The simple matter is that any motor, even a diesel, is doing work with horsepower.
Torque only describes how it goes about making that horsepower.
Old 04-11-2018, 03:07 PM   #42
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
27' thru 33' AS; I would recommend the 3/4 or 1T truck. I like the F250 6.7L diesel but 6.2L works well also. The 3/4 and 1T trucks are well equipped for good size payload, which includes passengers, gear in back, and tongue weight of your AS. It will also provide great torque for pulling and control for an AS that size. The diesel has the added advantage of the engine braking system which I am sure you will come to appreciate if you plan on driving in any mountainous areas... Good luck and always ask for advise here on the Forum...were all "full of it"! (just kidding)
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 01:55 PM
tow vehicle advice needed for 2006 19' Bambi ghatfield Towing, Tow Vehicles & Hitches 18 06-10-2014 07:05 PM
Tow vehicle advice needed raysay Towing, Tow Vehicles & Hitches 9 02-12-2013 10:27 AM
Tow vehicle advice needed.... crazylev Tow Vehicles 86 04-27-2007 07:11 PM
Tow vehicle advice needed! snackdragon Tow Vehicles 9 08-24-2005 08:52 PM
