Old 07-25-2006, 10:27 AM   #15
FT RVing
lebolewis's Avatar
1976 31' Sovereign
Always searching for a place w/low Humidity , FT RVing, N & S, E & W, & in between
Eureka!! Stopped the Clapping, Karma to Terry!!
I finally found the two wires Terry referred to in his post #7. Not at the location he mentioned but close to where the clapping noise was coming from, over near the fan motor. They came out of a large bundle on top of the AC/Heater housing and dissappeared over the back near the clapping noise source. I tried to unplug them from the top, through the glove box hole, but just couldn't get at them. Went under the bottom and managed to unclip the plug lock and "walah", got it unplugged. I was praying that it was the correct two wires and plug because there is ZERO chance that I could ever get that plug reconnected.......well maybe possible chance with the help of a mirror....
I think that now disabled clapping motor operated the door to the fresh air intake port. If that is correct, then that door is now closed and I now have no FRESH AIR access through the Heater or the AC. Can anyone confirm that?
The MAX AC (recirc), Defrost and Heater all seem to still work as they should. If I need fresh air, I can open a window!
Kudos and Karma for Terry! Thanks to all for your comments.
Is this a GREAT website, or what!! Bill
lebolewis is offline   Reply With Quote
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-18-2005 11:47 PM
introduction // need help deciding tow vehicle jmeredith Our Community 9 09-29-2002 05:39 PM
On The Road-Expedition as a tow vehicle Princer On The Road... 2 09-23-2002 06:43 AM
Tow questions ALANSD Airstream Motorhome Forums 3 05-28-2002 09:51 AM
