Old 06-25-2019, 10:04 AM   #1
Thomasville , Georgia
Tow truck running hot when A/C on
Good afternoon all,
This is my first post so please be nice! My wife and I bought our first airstream at the beginning of June. It is a 2006 20' Safari with a UVW of 3,693lbs. I am using a 2006 Dodge Dakota Quad Cab 4.7l v8 with tow package to tow.
The specs lead me to believe this was a suitable tow vehicle however when towing and running the a/c the truck tends to run a bit hot.
Truck specs:
http://trailers.com/tow-capacity/ind...emplate=normal
I took it to the local a/c guy who said everything looks fine from the a/c side of the house and he thinks the truck may be undersized. This doesn't seem right to me.
Is it common for a truck to run a bit hot when towing like this? When I turn off the a/c the temp returns to just a bit above normal. Any help or where to start would be greatly appreciated. I'm open to anything at this point. Thanks.
rechewjr is offline   Reply With Quote
Old 06-25-2019, 10:49 AM   #2
Kevin245's Avatar
Im not going to go into the specifics of your towing combination. You say that things look good from the AC perspective, but have you looked at the engine cooling system? Your TV is 13 years old, as such Id check the radiator, cap, thermostat, belts, and hoses. A thorough system flush and inspection would be my course of action.
BTW... Were always nice.
Eleanor Roosevelt
Old 06-25-2019, 11:31 AM   #3
2018 30' Classic
Jacksonville , Florida
What does "run a bit hot" mean? Is it overheating or not?
Overstreet is offline   Reply With Quote
Old 06-25-2019, 11:34 AM   #4
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
How hot? Does the tow package include a transmission cooler if it is a auto trans? I do not think it ought to “run hot” when towing. If it were me I would consider a bigger truck. Or a new radiator, WP, hoses, belts, etc and re evaluate it. And certainly a transmission cooler if an auto. I had a v 6 Dakota years ago. Ride terrible. No power. I liked the used f 150 that replaced it a lot better. Modern radiators corrode fast and can not be really cleaned or fixed. I would feed it a radiator if I liked the truck. It probably needs it anyway. Last year I put a radiator, WP, hoses, and belt on my 11 year old TV. Good for peace of mind on the road.
I guess I can not really answer your question. If the gauge goes up a little on pulls and drops back to normal on flats that is probably fine. You are putting a significant load on it. My justification for work that may or may not be absolutely need at the time is “would I rather do it here or on the interstate with the trailer in tow”
My best guess is that you do not have quite enough truck.
Old 06-25-2019, 11:45 AM   #5
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Your dash gauge, real gauge?
A tool that might be of interest to get a digital engine temp plus three additional engine functions from a long list is a Scan Gauge It plugs into OBD port and then position where you want it. Go thru setup select monitored and displayed functions and start driving.
It taps into vehicle system and reports what the system is seeing also reads codes and slices tomatoes really thin. Kidding.
Ive got one on my Bug and use it in particular to monitor engine temp.
Next diagnostic tool if youre a DIY guy an IR temp gauge very helpful in sorting out temp issues brake and tire temps and checking the skillet for pancake temp.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 06-25-2019, 12:23 PM   #6
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Originally Posted by Kevin245 View Post
I’m not going to go into the specifics of your towing combination. You say that things look good from the AC perspective, but have you looked at the engine cooling system? Your TV is 13 years old, as such I’d check the radiator, cap, thermostat, belts, and hoses. A thorough system flush and inspection would be my course of action.
BTW... We’re always nice.
Yes, this. On a 13 year old truck it could be any number of things including radiator fins blocked by debris and bugs, a cooling system that has never been flushed, thermostat not quite working right, low coolant levels etc. This will all be discovered and sorted with an inspection and system flush.
By the way, your engine will work a little harder when the a/c is running, so if everything is not up to snuff, this will cause the engine to run hotter when the a/c is on. I always turn my a/c off when pulling hills to keep things a little cooler and get a little more power from the engine as it is not operating the a/c pump.
thewarden is offline   Reply With Quote
Old 06-25-2019, 05:10 PM   #7
From what other people have said, it would probably be a good idea to start with a ODB Link to get an idea of what temperatures it is actually hitting. It normally runs below halfway on the temp gauge w/o trailer. With trailer and ac running it goes up to almost 3/4 of the temp gauge. When I turn the ac off it comes back down...
Old 06-25-2019, 05:23 PM   #8
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
Originally Posted by rechewjr View Post
Good afternoon all,
Truck specs:
My vehicles run pretty much the same engine temperature, around 200-210F on the gauge, towing or not, AC on or not. Today when the ambient was in the high 90's, and yesterday up to 102F, I did not see any significant change.
The exception to heat gain in my truck is when towing up a steep incline. The transmission will go from normal ~180-190F up to ~230F towing up a 5% grade for miles.
PS:
Welcome to the AirForums
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 06-25-2019, 05:51 PM   #9
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Good afternoon all,
Truck specs:
You need a larger radiator to run cooler.Not a big expense and easy to replace.
Old 06-25-2019, 06:13 PM   #10
ITSNO60's Avatar
Tucson , AZ
Yes you definitely need a real gauge, or if your ECM reports coolant temp read it that way, some vehicles do not use ECT for ECM reference but rather oil temp in which case you will get an erroneous reading from the OBD system for ECT. You could try Torque Pro first, $5 for the app and a $15 ELM327 Bluetooth adapter from ebay and you are in business. Course if your ECM does not report ECT you will have to install a mechanical gauge (I went with DiPricol but they are out of business now, Isspro would now be my choice)
Many factory dash gauges are stepped, they are not actual gauges at all but merely have several steps and when you cross a threshold the needle moves to the next step. Historically automakers don't want you to know too much to avoid un-necessary warranty complaints but I noticed more new vehicles actually have real temp gauges with numbers on them.
As others have said you are working that truck hard, you might just have to turn off the AC when climbing and as needed.
Brian
ITSNO60 is offline   Reply With Quote
Old 06-26-2019, 11:01 AM   #11
1973 29' Ambassador
Woodward , Oklahoma
Good afternoon all,
Truck specs:
It has been my experience that the most common cause for overheating, assuming cooling system is clean and functional, is the fan clutch. I have had No luck with aftermarket clutches. bite the bullet and get one from Dodge.
ddhisself is offline   Reply With Quote
Old 06-28-2019, 08:17 PM   #12
1999 28' Excella
Lake Mary , Florida
You most likely need a new water pump and new , and larger, radiator.
When towing, the engine works harder and gets hotter, so the radiator gets hotter, then the AC Condensor that is mounted right in front of the radiator runs hotter and you get less cooling in the cab.
suncoasteng is offline   Reply With Quote
Old 06-29-2019, 06:34 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ever clean the radiator fins??? Many bugs in there and dirt will restrict. Need real temp to know. If AC not working well, you need to address the problem while you are at home, not on roadside without cell service
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-29-2019, 07:26 PM   #14
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
No one has mentioned payload, the oft overlooked variable in towing.
Are you carrying a lot of gear, people, dogs, tools, bikes, water, etc, or is your load pretty light?
I ask because sometimes people don't consider if they are maxing out the specs as loaded.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
EU2000i running in truck bed Wingeezer Generators & Solar Power 19 03-04-2011 07:23 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
