I have not worked with an air suspension system while setting up a hitch but my first thought would be the air system would have to be turned off while setting up the hitch.
Filter the information you will get here looking only to those who have set up such a system because conflicts between the hitch and suspension are to be expected.
I would also consider going to a Cat scale before and after set up
2004 Excursion 4x4
