Old 06-19-2019, 03:50 PM   #1
2019 25' Flying Cloud
Wilmington , North Carolina
Tow Haul Button - does it matter?
Okay, here we go newbie stupid question #2...
I have a 2019 Ram 2500 (4x4 Crew Cab) with a 6.4 L Hemi towing a 25 foot Flying Cloud. I know the Tow Haul button changes the shift points (holds them longer?) but once I get rolling and up to speed, does that really matter?
Should I push it in and just leave it in for the entire duration of the tow or just when accelerating to speed?
Advice and knowledge is welcome! Thanks
etojeo is offline   Reply With Quote
Old 06-19-2019, 03:55 PM   #2
lancaster , California
since i'm moving toward getting a Ram myself, i'd like to know the answer to this. i'd imagine it's a button you leave activated for the duration of your trip.
Aluminaut is offline   Reply With Quote
Old 06-19-2019, 04:15 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Mine is a 2007 Ram diesel. I run it in tow-haul always when pulling. Changes the shift points and makes the shift more positive. In the mountains when running 55 or less I go to the next step, OD off. I think using the tow haul is easier on the transmission. On flat ground it makes no difference if you cut it off while at speed so there is no point to doing that. Your trailer is probably right at the bottom of the weight that actually needs tow haul. But I think using it will preserve the transmission.
Old 06-19-2019, 04:16 PM   #4
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
For me in my gas Silverado 2500, unless I am in the mountains, I leave it off, and enjoy another mile per gallon.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 06-19-2019, 04:17 PM   #5
Mollysdad's Avatar
I always activate it.
I forget when I get gas and it defaults to off, but usually I catch up.
Yes, it changes the shift points much higher, so you'll stay in a lower gear longer.
2015 Tundra.
Old 06-19-2019, 04:40 PM   #6
mikeinca's Avatar
2018 30' Classic
Santa Rosa , California
I have a 2017 F250 diesel but I don't imagine the tow-haul feature on my truck works that much differently than it does in the Dodge.
Staying in each gear longer while accelerating is one aspect of the tow-haul feature as is the transmission kicking down into a lower gear earlier under load. The Powerstroke in my truck has so much torque that I don't find that the transmission downshifts excessively. The most important feature of tow haul, IMHO, is that the transmission will shift into successively lower gears when the brakes are applied. This is especially useful while descending a grade and helps with speed control.
On the straight and level I don't find much difference in how the transmission shifts so I leave it in tow-haul mode most of the time, including when the cruise control is activated.
“The good thing about science is that it's true whether or not you believe in it.”
― Neil deGrasse Tyson
2018 30' Classic Twin
2017 F250 4x4 6.7 max tow Platinum
200W portable solar
240Ah LifePo4 upgrade
mikeinca is offline   Reply With Quote
Old 06-19-2019, 05:52 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Turn it on whenever you are towing. Fiddling with it while in motion is a distraction you very much do *not* need.
Old 06-19-2019, 06:23 PM   #8
dznf0g's Avatar
Oswego , Illinois
Do some research for your brand, but for GM, it not only raises shift points, activates decel down shifting, but also raises line pressure to keep more clutch application force. GM recommends using it when gcw is at or above 75% of rated gcwr.
-Rich-
Old 06-19-2019, 06:23 PM   #9
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
Found this in my ‘19 Ram 1500 owner’s manual - sounds like it’s “as needed” but as other posters have said, I leave it engaged when towing.
Automatic Transmission
The DRIVE range can be selected when towing. The transmission controls include a drive strategy to avoid frequent shifting when towing. However, if frequent shift- ing does occur while in DRIVE, select TOW/HAUL mode or select a lower gear range (using the Electronic Range Select (ERS) shift control).
NOTE: Using TOW/HAUL mode or selecting a lower gear range (using the ERS shift control) while operating the vehicle under heavy loading conditions will improve per- formance and extend transmission life by reducing exces- sive shifting and heat build up. This action will also provide better engine braking.
Tow/Haul Mode
To reduce potential for automatic transmission overheat- ing, activate TOW/HAUL mode when driving in hilly areas, or select a lower gear range (using the Electronic Range Select (ERS) shift control) on more severe grades.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB (traded)
2019 Ram 1500 Laramie Sport, Blue Ox 1000#
2020 Retirement Plan
jeffmc306 is offline   Reply With Quote
Old 06-19-2019, 06:31 PM   #10
r carl's Avatar
Lin , Ne
x 2
Old 06-19-2019, 06:36 PM   #11
SilverWind's Avatar
2017 25' International
1968 17' Caravel
Los Osos , California
From what I understand the Tow/Haul button in my 2016 RAM also tells the engine control unit to downshift on grades while towing and activate the anti-sway features, among other things.
SilverWind is offline   Reply With Quote
Old 06-19-2019, 07:07 PM   #12
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I use tow haul when I am towing in the hills is because it engages grade braking when needed. Without tow haul turned on it does not, according to my owners manual.
At other times I will use tow haul in stop and go traffic because it seems to be easier on the transmission and keeps the RPMs higher, at the top of the power curve, at low speeds
When I am in the flat lands I'll switch it off so that it will go into the higher gears easier for better fuel economy.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 06-19-2019, 07:44 PM   #13
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
MY 2013 Ram 2500 Cummins will not go into 7th gear in Tow Haul resulting in slightly less fuel economy which, in my mind, is more than offset by the advantages mentioned by the others. I always (unless I forget at a fuel stop) use tow haul when towing.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 06-19-2019, 09:16 PM   #14
bolerama's Avatar
2017 30' Flying Cloud
2008 23' International
Saskatoon , Saskatchewan
Images: 30
Another nice feature is that it prevents your vehicle from lurching when you are hooking up. We had a steep driveway. Whenever I'd line up the vehicle for hitching, and then put it in park, it would lurch forward. Frustrating. Tow/haul mode prevents that. It holds the vehicle in the right place while you lower the trailer. Maybe this is less important when one person is lowering the trailer for you while your foot is on the brake, but it's really useful when you are doing it by yourself.
Lisa
Lisa and Paul
2008 23' Int. CCD "The Atomic Pod" https://atomicpod.wordpress.com
2002 Chinook Destiny | 1973 13' Boler (fiberglass egg) "The Boiler"
WBCCI #23223 (=23 CCD)
bolerama is offline   Reply With Quote
Does Size Matter ? LisaP Member Introductions 40 06-13-2009 06:59 AM
Does tank size matter? Sheridan LP Gas, Piping, Tanks & Regulators 4 08-26-2008 08:21 AM
Does size matter when towing? safari57 Tow Vehicles 8 03-06-2007 09:25 PM
Size Does Matter... aviontt Refrigerators 5 02-26-2005 11:45 PM
Does Airstream location matter? yukionna Buyer Guidelines 5 09-21-2003 11:54 AM
